  • slowpoke
  • slowpoke
20 Nov 2025 17:29
Mesa - Can unused step & direction outputs be used as o/p's for other purposes?
Category: Driver Boards
If yes, where do I find them in HALSHOW?
I'm making a little interface board and have some leftover space, so I could gain a few extra o/p points if I can take advantage of these, perhaps drive a few SSR's.
Mesa 7i96s
20 Nov 2025 17:14
Replied by tommylight on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Is that "missing amd gpu firmware something or another"?
That is not a fault, just a warning about missing firmwares for older GPU's.
  • kn612
  • kn612
20 Nov 2025 17:08
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
I am getting an error on startup after adding the lines about offset mode.  I attached error report and current hal.
Machine jogs around well.  Its when I hit the power button in qtplasmac that enables the motors that they move/jump a little bit.  Offset mode would  correct/dampen that I assume?
  • Hakan
  • Hakan
20 Nov 2025 17:00
Replied by Hakan on topic an CIA402 Stepper/Servo as Spindle
Category: EtherCAT
Yes there is an example. Two normal stepper drives and one stepper motor spindle.
In the example directory.
  • Red_D85
  • Red_D85
20 Nov 2025 16:59
Replied by Red_D85 on topic an CIA402 Stepper/Servo as Spindle
Category: EtherCAT
Hi Hakan
thank you
What should the whole thing look like in the hall and ini? is there an sample?
  • PCW
  • PCW's Avatar
20 Nov 2025 16:54
Replied by PCW on topic Servo Driver Plasma Retrofit
Category: Plasmac
Yes, you would have to set it manually in HAL, something like:
setp hm2_7i97.0.pwmgen.00.offset-mode true
  • Hakan
  • Hakan
20 Nov 2025 16:50
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I think you hit all problems.
"raspi-firmware: missing /boot/firmware, did you forget to mount it?"
apt remove raspi-firmware
  • Hakan
  • Hakan
20 Nov 2025 16:48
Category: EtherCAT
You can use this component instead of the standard cia402 component.
github.com/MetalMusings/cia402pv
The drive uses PV (Profile Velocity) mode which is more suitable
for a spindle motor as it has its own speed ramp up and down.
  • unknown
  • unknown
20 Nov 2025 16:47
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
You can search Debian install amdgpu fault via Google or you can try the text installer.
  • Aciera
  • Aciera's Avatar
20 Nov 2025 16:11
v2.9 and not the perpendicularity of X and Y
1. Remove 'loadrt matrixkins' from your hal file
2. The KINEMATICS entry of the [KINS] section in your ini file needs to look like this (matrixkins does not support the 'coordinates' parameter):
KINEMATICS=matrixkins
  • Muftijaja
  • Muftijaja
20 Nov 2025 14:57
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
Hi rodw, Im sorry to bother you - the link to your doc in google docs is deleted, can you please tell me where I can find this again actually? I'm again struggling with packet losses.
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing is deleted.
Thanks for your efforts!
Hanno
  • abs32
  • abs32
20 Nov 2025 14:37 - 20 Nov 2025 15:04
Colleagues,
I installed the kernel 5.4.290 + the linuxcnc 2.9.4 build that came with it
With the kinematics option KINEMATICS = trivkins coordinates=XXYYZ, everything starts and works.
We have a description here -
linuxcnc.org/docs/devel/html/man/man9/matrixkins.9.html
the example section of hal + ini files is empty.
We also have a description here -
github.com/LinuxCNC/linuxcnc/blob/master...ents/matrixkins.comp
where examples of specifying matrix elements are indicated.
However, there are no examples for hal + ini.
I tried to do the following by analogy with other methods -
HAL -
#2025-11-20 для версии 2.9.4
#loadrt [KINS]KINEMATICS
#программная коррекция
#https://linuxcnc.org/docs/devel/html/man/man9/matrixkins.9.html
#https://github.com/LinuxCNC/linuxcnc/blob/master/src/hal/components/matrixkins.comp
loadrt matrixkins
setp matrixkins.C_xy 0 # Skew Y axis towards X axis
setp matrixkins.C_xx 1 # X axis scale
setp matrixkins.C_xz 0 # Skew Z axis towards X axis
setp matrixkins.C_yx 0 # Skew X axis towards Y axis
setp matrixkins.C_yy 1 # Y axis scale
setp matrixkins.C_yz 0 # Skew Z axis towards Y axis
setp matrixkins.C_zx 0 # Skew X axis towards Z axis
setp matrixkins.C_zy 0 # Skew Y axis towards Z axis
setp matrixkins.C_zz 1 # Z axis scale
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0,0
INI -
[KINS]
JOINTS = 5
#2025-11-20 для 2.9.4
#KINEMATICS = trivkins coordinates=XXYYZ
KINEMATICS=matrixkins coordinates=XXYYZ
When you try to launch it, it drops and shows an error -
Debug file information:
./t.hal:16: Can't find module 'matrixkins' in /usr/realtime-5.4.290-rtai-amd64/modules/linuxcnc
1485
Stopping realtime threads
Unloading hal components
for kernel 5.4.254, the situation and error are exactly the same (with corresponding linuxcnc + linuxcnc-dev)
how to fix this?
I note an error in man - there is no [KINS] section in the HAL file, there is such a section in ini, st 149 -
  • lorenzing
  • lorenzing
20 Nov 2025 14:36
Replied by lorenzing on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Many problems have been solved by assigning numbers instead of the axis letter (e.g. X) in the .hal file probably generated errors as there were two motors for one axis.
# --- load components ---
# load EtherCAT xml then drivers
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
loadrt cia402 count=5
# --- add functions to servo-thread ---
addf lcec.read-all            servo-thread
# read from cia402 drivers (one per joint)
addf cia402.0.read-all        servo-thread
addf cia402.1.read-all        servo-thread
addf cia402.2.read-all        servo-thread
addf cia402.3.read-all        servo-thread
addf cia402.4.read-all        servo-thread
# motion stack
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
# writes: cia402 then lcec
addf cia402.0.write-all       servo-thread
addf cia402.1.write-all       servo-thread
addf cia402.2.write-all       servo-thread
addf cia402.3.write-all       servo-thread
addf cia402.4.write-all       servo-thread
addf lcec.write-all           servo-thread
# estop
net estop-out  iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in
# JOINT 0  (X)  -> cia402.0 -> lcec.0.0
#config
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale -3600
#from servo(ethercat) to cia402
net 0-statusword      lcec.0.0.srv-cia-statusword => cia402.0.statusword
net 0-opmode-display  lcec.0.0.srv-opmode-display => cia402.0.opmode-display
net 0-drv-act-pos     lcec.0.0.srv-actual-position => cia402.0.drv-actual-position
net 0-drv-act-velo    lcec.0.0.srv-actual-velocity => cia402.0.drv-actual-velocity
#from cia402 to servo(ethercat)
net 0-controlword         cia402.0.controlword => lcec.0.0.srv-cia-controlword
net 0-modes-of-operation  cia402.0.opmode => lcec.0.0.srv-opmode
net 0-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.srv-target-position
#from motion to cia
net 0-enable    <= joint.0.amp-enable-out => cia402.0.enable
net 0-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault
net 0-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd
net 0-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb
# JOINT 1  (Y1) -> cia402.1 -> lcec.0.2
#config
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale -3600
net 1-statusword      lcec.0.2.srv-cia-statusword => cia402.1.statusword
net 1-opmode-display  lcec.0.2.srv-opmode-display => cia402.1.opmode-display
net 1-drv-act-pos     lcec.0.2.srv-actual-position => cia402.1.drv-actual-position
net 1-drv-act-velo    lcec.0.2.srv-actual-velocity => cia402.1.drv-actual-velocity
net 1-controlword         cia402.1.controlword => lcec.0.2.srv-cia-controlword
net 1-modes-of-operation  cia402.1.opmode => lcec.0.2.srv-opmode
net 1-drv-target-pos      cia402.1.drv-target-position => lcec.0.2.srv-target-position
#from motion to cia
net 1-enable    <= joint.1.amp-enable-out => cia402.1.enable
net 1-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault
net 1-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net 1-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb
# JOINT 2  (Y2) -> cia402.2 -> lcec.0.1
#config
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 3600
net 2-statusword      lcec.0.1.srv-cia-statusword => cia402.2.statusword
net 2-opmode-display  lcec.0.1.srv-opmode-display => cia402.2.opmode-display
net 2-drv-act-pos     lcec.0.1.srv-actual-position => cia402.2.drv-actual-position
net 2-drv-act-velo    lcec.0.1.srv-actual-velocity => cia402.2.drv-actual-velocity
net 2-controlword         cia402.2.controlword => lcec.0.1.srv-cia-controlword
net 2-modes-of-operation  cia402.2.opmode => lcec.0.1.srv-opmode
net 2-drv-target-pos      cia402.2.drv-target-position => lcec.0.1.srv-target-position
#from motion to cia
net 2-enable    <= joint.2.amp-enable-out => cia402.2.enable
net 2-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault
net 2-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd
net 2-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb
# JOINT 3  (Z1) -> cia402.3 -> lcec.0.4
#config
setp cia402.3.csp-mode 1
setp cia402.3.pos-scale 3600
net 3-statusword      lcec.0.4.srv-cia-statusword => cia402.3.statusword
net 3-opmode-display  lcec.0.4.srv-opmode-display => cia402.3.opmode-display
net 3-drv-act-pos     lcec.0.4.srv-actual-position => cia402.3.drv-actual-position
net 3-drv-act-velo    lcec.0.4.srv-actual-velocity => cia402.3.drv-actual-velocity
net 3-controlword         cia402.3.controlword => lcec.0.4.srv-cia-controlword
net 3-modes-of-operation  cia402.3.opmode => lcec.0.4.srv-opmode
net 3-drv-target-pos      cia402.3.drv-target-position => lcec.0.4.srv-target-position
#from motion to cia
net 3-enable    <= joint.3.amp-enable-out => cia402.3.enable
net 3-amp-fault => joint.3.amp-fault-in   <= cia402.3.drv-fault
net 3-pos-cmd   <= joint.3.motor-pos-cmd  => cia402.3.pos-cmd
net 3-pos-fb    => joint.3.motor-pos-fb   <= cia402.3.pos-fb
# JOINT 4  (Z2) -> cia402.4 -> lcec.0.3
#config
setp cia402.4.csp-mode 1
setp cia402.4.pos-scale 3600
net 4-statusword      lcec.0.3.srv-cia-statusword => cia402.4.statusword
net 4-opmode-display  lcec.0.3.srv-opmode-display => cia402.4.opmode-display
net 4-drv-act-pos     lcec.0.3.srv-actual-position => cia402.4.drv-actual-position
net 4-drv-act-velo    lcec.0.3.srv-actual-velocity => cia402.4.drv-actual-velocity
net 4-controlword         cia402.4.controlword => lcec.0.3.srv-cia-controlword
net 4-modes-of-operation  cia402.4.opmode => lcec.0.3.srv-opmode
net 4-drv-target-pos      cia402.4.drv-target-position => lcec.0.3.srv-target-position
#from motion to cia
net 4-enable    <= joint.4.amp-enable-out => cia402.4.enable
net 4-amp-fault => joint.4.amp-fault-in   <= cia402.4.drv-fault
net 4-pos-cmd   <= joint.4.motor-pos-cmd  => cia402.4.pos-cmd
net 4-pos-fb    => joint.4.motor-pos-fb   <= cia402.4.pos-fb
# End of HAL
  • Beovoxo
  • Beovoxo
20 Nov 2025 13:55
Replied by Beovoxo on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Hi all, i tested again today with a fresh download of  2.9.4 from the main page. And now i am stuck as all the other ones are at, the missing "amdpgu fault".
Was there a solution on that fault ?, i cant decipher if there was one, on all the other forum posts with that fault.
ibb.co/G4FrwL3t
If there is not a solution i will try the "mint" Tommylight uploaded :)
  • DemonClaW
  • DemonClaW
20 Nov 2025 13:44
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Category: EtherCAT
Displaying 10966 - 10980 out of 11532 results.
Time to create page: 0.327 seconds
