  • unknown
  • unknown
19 Nov 2025 02:00
I would like to know how to connect GPIO to LinuxCNC’s E-Stop chain.
Category: Basic Configuration
Undo everything ChatGPT suggests and never ever use it again for anything related to Linuxcnc.
Far better to visit this thread
forum.linuxcnc.org/47-hal-examples/25861-external-e-stop#26684
You may have to invert the estop signal, as when you press the estop you are providing a 0v signal. You may also need to check whether the inputs to the estop are tied hi or low when the Estop is pressed.
  • Muftijaja
  • Muftijaja
19 Nov 2025 01:56 - 19 Nov 2025 13:10
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Thanks for your reply, Lcvette!
Okay, I think I have a (relative :) )rigid machine for a hobby CNC. All critical plates are made of 20mm 5083 aluminum, heavy profiles filled with cement, an 80x160mm filled portal profile, 20mm HGR guides. A good standard for  a 1000x500 machine.  I aligned everything using angles and a dial gauge. I placed a dial gauge on the end of the Y ball screw, which shows only 1/100 mm of backlash. Using a spring balance, I pulled with 20 kg on the spindle in the X and Y directions, with a maximum deflection of 0.06 mm, in the X less in the Y direction. I think the mechanics are OK, as this deviation of almost 0.5 mm cannot be explained.
Ok, You say, my settings are correct. What is the reason for motor alarms at the reduction of FERROR from 1.0 to 0.1 and MIN.FERROR from 0.1 to 0.01?
19 Nov 2025 01:53
  • EdWorks
  • EdWorks's Avatar
19 Nov 2025 01:46
My SetupRaspberry Pi 5 8GBByte2Bot Parallel Port Raspberry Pi HatByte2Bot 5 Axis CNC Interface Adapter Parallel Breakout Board For Stepper Motor DriversPicture 1My wiring is as follows:Picture2
The motors move, the home switches register as functioning, the probe is not hooked up and the eStop appears to do nothing.From LinuxCNC V2.9.7 Documentation PDF Page 1854.9.3.7 External ESTOP button The standard_pinout.hal file assumes no external ESTOP button. For more information on an external E-Stop see the estop_latch man page.Yet from 2 pages earlier in LinuxCNC V2.9.7 Documentation PDF Page 183 I see this line in the HAL file:# create a signal for the estop loopbacknet estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in I assume “man page” is a typo and this is unnecessary if I am trying to connect it to  GPIO25. A search of the document looking for “estop_latch” only reveals this on page 254Picture 3So my estop is on pin10, but that is GPIO25 on the Pi 5. I must refer to it as such.In my .Hal file I have the following lines:loadrt hal_gpio inputs=GPIO7,GPIO8,GPIO25,GPIO12,GPIO13 outputs=GPIO5,GPIO6,GPIO11,GPIO9,GPIO10,GPIO23,GPIO16,GPIO17,GPIO19,GPIO20,GPIO21,GPIO22,GPIO24,GPIO26net estop-out   <= hal_gpio.GPIO25-in  ornet estop-ext <= hal_gpio.GPIO25-in Using tools I can identify that all my limit switches are being read, but I have nothing to suggest the estop is being read.I have added“Addf gpio-input servo-thread” as recommended by ChatGPT, and that is not read by the programThe advice I am looking for is:
I would like to know how to connect GPIO25 to LinuxCNC’s E-Stop chain.I have tried:
net estop-out hal_GPIO.GPIO25.out => iocontrol.0.emc-enable-inand any variation thereof I could think of, failed.Eventually, I lost control of my servos and only when I removed all lines I gained control of F1, which controls the estop and F2, which powers the servos.
  • mooser
  • mooser
19 Nov 2025 01:21
7i84u Powering was created by mooser
7i84u Powering
Category: Driver Boards
I'm hooking a 7i84u to a 7i96s and I'm unsure about the power for the 7i84u
From what I understand reading the manual (page 2) there is an onboard switching power supply that will take FIELDB voltage down to logic level if W1 jumper is in the left hand position. So I can supply 24v to FIELDB and it's not going to hurt anything.
Or is that only if I was using 5V FIELD and anything above that I should be using a separate supply for VIN?
Also, from what I understand
Both field A and field B need to be powered regardless. I've hooked my 24v power (same that is being used on the 7i96s field) to one of the grounds (pin 8) and into pin 1 (VFIELDB) and then a jumper from pin 2 (VFIELDB) into pin 3 (VFIELDA) so they are both powered with 24v.
Right now I've got a 5v line coming over from the same supply that I use for the 7i96s into pin 5 (VIN) and the W1 jumper in the right hand position. That seems to work, I have a flashing green light (CR6 activity) and I can see changes on hm2_7i96s.0.7i84.0.0.imput-00 in HALshow if I power pin0 TB3 (either with 5c or 24v)
Before I let out the magic smoke....
M
  • dgdodo
  • dgdodo
19 Nov 2025 01:18
Replied by dgdodo on topic [SOLVED] Backlash issues on Y-AXIS
Thanks for all info so far.
I decided to change the Y-axis also with a M4-(screw) spindle drive (not M3 as I said before), as I did on the X-axis.
Had the (almost) same stepper-motor around, although after testing it needed 2 times more Volt to be powerful enough.
Now it all looks much better!
The old gear setup was too much worn out, I believe. And 2 (plastic) gears before driving the arm had 1.3 mm backlash is also kinda 'too much'.
PS. I thought I tried the write action at last position in the .hal file (base-thread), but was forgotten to change the .ini file accordingly.
It does run fine now and I am not (willing) able to build back the old situation to test this again, sorry for that.
And yes, I will cleanup my configuration files after this change, the X- and Y-axis are now the same.
Regards, DG.
  • ihavenofish
  • ihavenofish
19 Nov 2025 00:19 - 19 Nov 2025 00:22
lemontart - a call for help with s curve, ui's, and all the cool toys
I'm using and recommending jss (stepperonline) ethercat servos.
if people want to live in the past that on their own time hahaha :P
j/k
There's lots of ethercat offerings which is nice. JMC has integrated servos and steppers. The hitch with lemontart is the fit is tight, especially for the z.
Everything it coming together though nicely. I hope in january we can start seriously working on the control aspects.
18 Nov 2025 23:57
Looking for a freelancer to assist in drawing schematics for cnc plasma table
Category: User Exchange
That is a looooong list ! :)
Yet no machine dimensions, weight of moving parts, drive train, reduction, materials used, etc...
And just putting it out there, 1KW servo motors for a plasma machine is utter overkill, no matter how big or heavy. The biggest i have seen on old industrial machines were 400W, with reduction two of those could fling a probably 200KG heavy gantry at 18m/m!
  • ContinenteCNC
  • ContinenteCNC's Avatar
18 Nov 2025 23:55 - 18 Nov 2025 23:57
Replied by ContinenteCNC on topic Axis Modifications
Axis Modifications
Category: AXIS
This is a mod that allows using a single key to cycle through Program Run, Program Pause, and Program Resume.
I unbound the keys R, P, and S from their original commands and bound only the R key to a routine that handles the cycling.
If you’re willing to test it, please let me know if something doesn’t work correctly and I’ll fix it.
  • Cooped-Up
  • Cooped-Up
18 Nov 2025 23:50
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
I swapped around the inputs and outputs and that solved the issue. I was able to get all the buttons to function. I spent a while working on getting the gmoccapy jog buttons to move the axis but for some reason the only way I was able to get any of the axis to move outside of homing is to use the halshow to select the axis for jogging. Tried tying the ui pins to the pos and neg axis pins. Also almost done with the pendant with the mpg just need the rotary switches and wiring
  • ContinenteCNC
18 Nov 2025 23:47 - 19 Nov 2025 00:05
Axis Modifications
Category: AXIS
This is a mod for incrementally increasing/decreasing Feed, Rapid, and Spindle Overrides.
They behave similarly to the Jog Speed slider.
I unbound the keys `, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0
And bound:
1, 2 to decrease/increase Feed Override
3, 4 to decrease/increase Rapid Override
5, 6 to decrease/increase Spindle Override
Keys `, 7, 8, 9, 0 have no effect.
It follows the INI fine settings.
I have also implemented an exponential response to speed up changes. In principle, it works with any exponent, but so far I’ve had the best results with power = 3.0.
If you want linear behavior, set power = 1.0, and then each key press will change the value by one unit.
If for some reason a slider gets stuck at a certain value, set linear_threshold_rate to a value slightly higher than the stuck position. That will solve the issue.
It’s not as quick as a potentiometer, but it works quite well. If you want it to be even faster, try:
xset r rate 250 40
This doubles the key auto-repeat rate and cuts the delay before auto-repeat starts in half.
Try different delay and rate values. The downside is that if you set them too high, editing text files can feel awkward.
By the way, this mod is derived from this post: forum.linuxcnc.org/51-ot-posts/49830-com...ntrol-console#279421
  • tcbmetalworks
  • tcbmetalworks
18 Nov 2025 23:44
I wrote this up in chat gpt pretty quickly I think it just about covers all of the bases here of the project.
CNC Plasma Table – Electrical & Wiring Requirements
Project: Remote design of electrical system + wiring documentation for LinuxCNC plasma table
Client: TCB Metal Works
1. Project Overview
You will remotely design the complete electrical and control system for a custom CNC plasma cutting table powered by LinuxCNC.
You will create:
Complete wiring diagram set (schematic + physical routing)
Full Bill of Materials (BOM) with real part numbers
Wire gauge, shielding, grounding, and EMI mitigation plan
Bulkhead connector list + panel layout
Mesa board selection + full LinuxCNC I/O map
Integration notes for all components
Testing & commissioning checklist
This is a 100% remote engineering job — no physical inspection of hardware is required.
2. Available Power Sources
Near the machine:
220 VAC available
460 VAC available
No dedicated 110/120 VAC, which must be generated using a control transformer if needed
Engineer must design the incoming power strategy and transformer selection.
3. Motion Hardware
3.1 X & Y Axis – AC Servos (Provided)
3× A6 Series 1000W RS485 AC Servo Motor Kits
3000 rpm
3.18 Nm
17-bit absolute encoder
IP67 motors
Axis layout:
Y axis: 2 servos (dual-drive gantry)
X axis: 1 servo
Notes:
Motor-to-drive cables are already supplied by the manufacturer.
You do not need to design or evaluate those cables.
Engineer must:
Design AC mains wiring to each servo drive
Design control, enable, alarm, and ESTOP signal wiring between drives and Mesa
Include needed fuses, breakers, filters, and terminals
Provide cabinet layout and routing plan
Include proper grounding and shielding recommendations
3.2 Z Axis – Stepper Motor (Needs Driver + Cable)
PV267-D2.8AA stepper motor — Oriental Motor
Stepper driver not provided
Stepper motor cable not provided
Engineer must:
Select a compatible stepper driver suitable for PV267-D2.8AA + LinuxCNC step/dir
Define driver voltage supply requirements
Design:
Step/Dir wiring from Mesa
Motor wiring from driver to Z motor
Required cable shielding, gauge, and insulation
Connector type and strain relief
4. Control Electronics (Mesa + Power)
Engineer must select Mesa hardware capable of supporting:
3× servo axes
1× stepper axis
THC-AD
Ohmic sensing
All limit/floating switches
Plasma start / Arc OK
E-stop & safety I/O
Deliverables:
Recommended Mesa board combination (e.g., 7i76E, 7i96S, 7i85, THCAD, etc.)
Justification for chosen hardware
Complete LinuxCNC I/O mapping
Required DC power supplies (24V / 5V / others)
Proper AC distribution, fuses, breakers, and protection devices
5. Torch Height & Ohmic Sensing
5.1 THC-AD Integration
Engineer must design:
Raw arc voltage wiring from Hypertherm HT2000 to THC-AD
THC-AD signal wiring to Mesa
Required shielding and filtering
Scaling notes for LinuxCNC
5.2 Ohmic Sensing (Planned)
Engineer must:
Recommend a compatible ohmic board
Provide wiring diagram for torch → ohmic board → Mesa
Specify cable type and shielding
Document signal polarity & behavior
6. Hypertherm HT2000 Integration
Engineer must design wiring for:
Required signals
Torch start / trigger
Arc OK
Raw arc voltage (+/–) into THC-AD
Required protection
Isolation (if needed)
Surge suppression
Filtering
EMI protection
Routing rules
Arc voltage wiring must be kept separate from low-voltage control wiring
7. Limit Switches & Floating Head
X Axis
2 limit switches:
X-min
X-max
Y Axis (Dual Gantry Drive)
2 limit switches:
Y-min
Y-max
Engineer must propose a reliable gantry squaring / homing method for the two Y motors.
Z Axis
2 end-of-travel limit switches:
Z-min
Z-max
1 floating-head switch (touch-off)
Engineer must:
Select appropriate switch type (mechanical or prox)
Provide wiring diagrams to Mesa
Specify wire gauge, shielding, and cable routing
Provide LinuxCNC input mapping
Include any debouncing/filtering requirements
8. Wiring, Shielding, & EMI
Engineer must specify:
Wire gauges for:
AC mains
Servo drive feeds
Stepper driver feeds
Stepper motor wiring
Limit/floating/ohmic wires
Plasma signals
DC supply lines
Shielding requirements for:
Step/dir
Limits/floating/ohmic
Arc voltage
THC-AD lines
EMI considerations
Cable separation
Ferrite locations
Filtering recommendations
9. Grounding & Bonding
The engineer must design the grounding/bonding approach.
Important physical detail:
The water table, gantry, and control cabinet are three separate physical assemblies.
The engineer must account for this when designing:
Grounding/bonding layout
EMC/EMI mitigation
Plasma return path considerations
Ohmic sensing grounding
No grounding method (star, bus, single-point, etc.) is mandated — the engineer chooses the correct approach.
10. Control Cabinet & Bulkheads
Cabinet Layout
AC distribution, transformers, PSUs
Mesa boards
Servo drives
Stepper driver
Fuses, breakers, contactors
DIN rail layout
Ventilation/fans
Bulkhead Connectors
Used wherever practical for:
Servo cables (using glands or pass-throughs)
Z stepper cable
Limit/floating switches
Ohmic sensing
E-stop / operator controls
Ethernet access
Connector type
Pinout
Panel cutout style
Labeling
11. Documentation Package
Engineer must deliver:
11.1 Wiring Diagram Set
Full schematic
Cabinet wiring
Field wiring
Power distribution
Grounding/bonding
Bulkhead connector pinouts
11.2 BOM
Complete list of:
Mesa hardware
Stepper driver
Transformers / PSUs
Switches
Connectors
Wire/cable
Protection devices
Cabinet hardware
11.3 I/O Map
All LinuxCNC inputs/outputs
Axis definitions
THC/ohmic mappings
E-stop & safety signals
11.4 Commissioning Checklist
Power-up verification
Servo enable/jog
Stepper test
Homing / gantry squaring
Z floating-head test
THC test
Ohmic test
EMI/noise checks
18 Nov 2025 23:40
Category: QtPyVCP
What material is being milled?
You wont like this, but that can very easily be mechanical flex from aluminium parts, there is reason why cast metal is used for mills.
Still, a quick test for that is to make the same part much slower and check if the error is smaller.
  • Hakan
  • Hakan
18 Nov 2025 23:39 - 18 Nov 2025 23:39
Category: QtPyVCP
About the following error, there is no real position feedback, only position feedback from stepgen.
That P=500 is ok for your 2 ms servo-period?
  • Lcvette
  • Lcvette's Avatar
18 Nov 2025 23:32
Category: QtPyVCP
Mwchanical issue maybe or backlash of your acis settings are correct.
Displaying 11086 - 11100 out of 11531 results.
Time to create page: 0.358 seconds
