  • TheTinkeringMechanic1
20 Jun 2025 15:19
Replied by TheTinkeringMechanic1 on topic Reposition Preview grid.
Category: Basic Configuration
I believe I figured it out. I was looking at it the wrong way. I needed to set the max limit in the ini file and then set the offset to move the home position further into the grid. I'm not sure if this is the correct way of doing, it but it got me the desired result.
This image shows my new position in the preview grid.
  • Aciera
  • Aciera's Avatar
20 Jun 2025 15:06
Replied by Aciera on topic Reposition Preview grid.
I'm sorry, I still don't get it.
Are you saying that 'G0 x0z0' moves the tool to the machine home position despite having set a work offset (ie the blue circle instead of the coordinate system) ?
  • AdelRTP
  • AdelRTP
20 Jun 2025 15:04
Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
Category: Driver Boards
Using
mesaflash 3.4.9
 with a Mesa 7i76EU (IP
192.168.1.121
). Ping works, but:mesaflash --device 7i76eu --addr 192.168.1.121 --readhmid
Unsupported ethernet device 7I76EU at 192.168.1.121
No 7I96S board found
Also tried with IP
10.10.10.10
 after moving jumper W14 up
mesaflash --device 7i76eu --addr 10.10.10.10 --readhmid
Unsupported ethernet device 7I76EU at 10.10.10.10
Is the 7i76EU supported? How to fix "Unsupported device"?
  • unknown
  • unknown
20 Jun 2025 14:50
(SOLVED) hal_gpio: Operation not permitted fault cannot be solved
Category: HAL
And unless you disable SPI you can not use the SPI pins for GPIO in linuxcnc
  • unknown
  • unknown
20 Jun 2025 14:47
Category: HAL
The images are setup and no adding users to groups or messing around is needed.
Read the following thread and you'll find a link to GPIO info and a working example.
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
  • PCW
  • PCW's Avatar
20 Jun 2025 14:26
Replied by PCW on topic Lo ejes dejaron de moverse
The fact that it quit working after firing the torch suggest a grounding or EMI issue.
If communication work but you don't get motion, it may be they the step/dir
output drivers have been damaged. One way to check this is to disconnect the
motor drive step/dir signals and measure the 7I96S step/dir output voltages
The step and direction output voltages should be in one state when the 7I96S card is
first powered up, and in the opposite state when LinuxCNC is started.
That is the output voltage should be very close to 5V in one state and very close to
0V in the other state.
If the voltage does not change or you get any voltage that not close to 0V or 5V, this
indicates damaged to the 7I96S step/dir outputs.
  • bladekel
  • bladekel
20 Jun 2025 14:15 - 20 Jun 2025 14:19
Category: HAL
Hello to all.
I'm using Linuxcnc 2.9.4 on rpi5 debian bookworm that is installed from linuxcnc rpi5 image.
I have a problem on running my setup.
I tried many things like adding gpio to my user, creating a file 90-gpio-access that is mentioned on hal_gpio manual (linuxcnc.org/docs/devel/html/drivers/hal_gpio.html)
but I failed.
Here is my fault information;
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/cnc/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z A
KINEMATICS=trivkins coordinates=XYZA
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
Debug file information:
Note: Using POSIX realtime
Failed to register output pin collection
hal_gpio: rtapi_app_main: Operation not permitted (-1)
./my-mill.hal:4: waitpid failed /usr/bin/rtapi_app hal_gpio
./my-mill.hal:4: /usr/bin/rtapi_app exited without becoming ready
./my-mill.hal:4: insmod for hal_gpio failed, returned -1
2307
Stopping realtime threads
Unloading hal components
my groups are;
cnc@raspberrypi:~$ groups
cnc tty disk dialout sudo audio video plugdev users input render netdev i2c bluetooth gpio spi
  • Sekai
  • Sekai
20 Jun 2025 14:03
Replied by Sekai on topic LinuxCNC MillTurn
LinuxCNC MillTurn
Thanks for the reply.
For now i will work on the 3D model for the whole machine.
20 Jun 2025 13:28
That's the problem. It realigns the whole grid to wherever the home is set to. I can't find a way to move the grid itself. If I could keep the grid aligned with the physical home and off set the set home by 3-4 inches on the grid I would be happy. I can't seem to find a way to do that.
  • Johnnysacalu
  • Johnnysacalu
20 Jun 2025 12:40
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
Todas las fuentes de alimentación dan el voltaje correcto los motores se quedan frenados como si funcionaran pero no se mueven la verdad es que no se si se pudo aver quemado la placa.
Tengo cables blindados puestos a tierra aun que no si es una medida para que no se queme.
Que mas puedo comprobar?
  • Aciera
  • Aciera's Avatar
20 Jun 2025 12:39
All these elements are drawn to represent your machine limits and offsets:
The blue circle in the lower left corner is the home position.
The red rectangle shows the axis limits in respect to the home position (as set in the ini file).
The XZ coordinate system shows the current work origin (ie in your example you have an active work offset in x )
20 Jun 2025 11:57
I apologize if I wasn't clear.
In the image you'll see a blue and red arrow I'd like to move them up on preview grid closer to the middle, as you can see the program path takes it right to the limit of the preview grid.
  • Aciera
  • Aciera's Avatar
20 Jun 2025 11:49
Replied by Aciera on topic Fanuc-Style Toolchange
You don't really need the expanded tool editor for this:
Have a look at the sim config:
configs/sim/axis/lathe-fanucy
  • knipknap
  • knipknap
20 Jun 2025 11:09
Replied by knipknap on topic MESA 7i76E burning out issue
I finally found the real cause.
Today i got the amplifier fault on another joint (joint 0) and I found that it the problem happened whenever I turned on the spindle.
After several attempts to measure the ground connections the machine stopped in a position where I found the machine frame was not grounded.
The reason: The spindle connector got loose. The machine frame was grounded through the spindle cable, and that cable had become loose.
All I had to do was tighten the screw of the connector. Ground connection works reliably again and the machine runs well. Phew.
  • meister
  • meister
20 Jun 2025 10:55 - 20 Jun 2025 10:59
Replied by meister on topic EasyCAT Arduino shield
Category: EtherCAT
accidentally flashed my ethercat servo with something wrong, and restored everything with this tool and the original esi xml
so yes, it really works
I use it to configure my LAN9252 board
EDIT:
uhhh, found this site: markosankovic.github.io/2016/06/28/esi-to-sii-binary.html
i think i need to test this '
ethercat sii_write ...
I must have overlooked it somehow :)
Displaying 14941 - 14955 out of 15020 results.
Time to create page: 2.755 seconds
