17 Mar 2025 16:24
Replied by tommylight on topic Migration von 2.8.4 auf 2.9.4
Category: Deutsch
If it works, don't mess with it.
I absolutely agree.
17 Mar 2025 16:22
PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
Had the same issue yesterday, PCI-E Sunix card, works perfectly but the error shows up whenever LinuxCNC is started.
Did not bother with it, but i did notice LSPCI does not show loaded module for it at all, but it does show all the other info with addresses and stuff.
  • gitin
  • gitin
17 Mar 2025 16:22
Replied by gitin on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Hi Tommy. I installed your build. It works well, loads quickly.
If in the ini file DISPLAY = axis, the screen does not load.
If this is replaced with DISPLAY = gmoccapy or with
DISPLAY = qtvcp qtdragon
PREFERENCE_FILE_PATH = WORKINGFOLDER/qtdragon.pref
it works fine. Maybe I don't understand something.
Translated in Google.
  • tommy
  • tommy
17 Mar 2025 16:20
STEPLEN STEPSPACE time for Bergerda AC servo driver
Parameter 82 did the trick! It was set to 600 by default, now I set it to 1000, and works perfectly up to 170mm/s velocity.
  • bnet
  • bnet's Avatar
17 Mar 2025 15:12
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Category: Driver Boards
That's what I'm starting to realize! Thanks for adding to my confidence on this route.
I have found some good encoders - I'm thinking of going with 10000 PPR for X and Z and 800 PPR for the turret and the live tooling motor as the latter won't need much in terms of resolution, while the Z and especially X will need as much as I can get/afford (maximum count rates of A-B Ultra3000 2.5 mHz).
  • scda
  • scda's Avatar
17 Mar 2025 14:53
Replied by scda on topic M19 and spindle-index-enable issues
Hi all
Not sure if this is still relevant. I am using this "new" orient comp from Andy (recompiled it as orient2). And I have to say, this actually works great!
The only thing I changed is: uncomment "is_oriented = 0" (otherwise I was not able to run multiple M19 commands in a row).
This changes the behavior of the -is-oriented pin --> So i use the oneshot function to make the signal stay true longer and activate the spindle brake and some other stuff. Might add another input to the comp, so the i"s-oriented" pin can be reset with M5 or an other signal...)
Before I saw this, I had to use tallas83 idea to orient a spindle (which requires much more signals/pins  & connections).
This should be added to the main fork in my opinion (maybe this was already done)?
One improvement in my setup would probably be to run the indexing only once (and then change the mode to 0) and after that do a few orientation commands. That should make it a bit faster as a constant rehoming is not necessary after every orientation (espescially if the spindle is not running in velocity mode in between).
  • Micha
  • Micha
17 Mar 2025 14:30
Replied by Micha on topic UHD Graphics 730 with RTAI Kernel
It works well in text mode.
I don't think there would be any Mini ITX Boards with onboard GPU and we don't have the space for PCIe GPUs in the system.
  • scda
  • scda's Avatar
17 Mar 2025 14:29
caxis.comp with stepper motor / gear connection to spindle
Category: HAL
Luckly I installed a disk brake on my lathe's spindle during the retrofit (brake is operated with pressurized air). This works pretty well for holding the spindle during cutting in a specific angle.
  • PCW
  • PCW's Avatar
17 Mar 2025 14:14
CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
Category: Milling Machines
Make sure the drive enables work so a runaway is stopped
before damage occurs. Alternatively, decouple the linear axis
from the motors.
A blind setup has about a 50% chance of a runaway because
either the encoder direction or analog output polarity are reversed
resulting in positive feedback = runaway.
  • Murphy
  • Murphy
17 Mar 2025 14:13 - 17 Mar 2025 14:14
Replied by Murphy on topic Testing CSS
Testing CSS
I have gotten the spindle to react in CSS it's doing the opposite getting slower as x moves in. But I'm more concerned about the spindle speed changing is not smooth. Everytime it's adjusting the speed it jerks and it's not smooth. Video clip below.
youtube.com/shorts/1r4Jos8_Y1k?si=ZHSdJYkjGlDulI3B
  • Aciera
  • Aciera's Avatar
17 Mar 2025 13:43
Replied by Aciera on topic New update on STMBL
New update on STMBL
As far as I understand, this v5 supports imput 220vac 4 kW 4.5 kW motors,
What makes you say that?
  • Mike_Eitel
  • Mike_Eitel's Avatar
17 Mar 2025 13:42
Warum ruckeln die Motoren bei langsamer Geschwindigkeit?
Category: Deutsch
It is long ago but as i remember there are accelation ramps for your handwheel that i programmed..
  • Overspeed
  • Overspeed
17 Mar 2025 13:41
Replied by Overspeed on topic New update on STMBL
New update on STMBL
As far as I understand, this v5 supports imput 220vac 4 kW 4.5 kW motors, but is it not suitable for mach3? Doesn't it provide 5v pulse/dir?
  • Aciera
  • Aciera's Avatar
17 Mar 2025 13:35 - 17 Mar 2025 13:36
New update on STMBL
As far as I'm aware V4 used an obsolete power semiconductor this (v5) is a forked project with a new design.
The origingal project is here but has not seen updates in a few years:
github.com/rene-dev/stmbl
Note that v4 does not support motors above 2kW either.
You might want to ask for updates over on this site as there does still seem to be some activity there:
app.gitter.im/#/room/#rene-dev_stmbl:gitter.im
  • Wischi
  • Wischi
17 Mar 2025 13:34
Replied by Wischi on topic Spindle PID RPM oscillates under load
Still no luck with that. I also get the feeling that testing under load might not be the best test.
My machine originally had a 18 speed gearbox. I reduced it down to 5 and did all the rpms inbetween using the vfd. Just switched that back to the original config and run the vfd/motor at its normal speed (2750 rpm). The extra torque from the gearbox keeps the rpm stable enough, so far I can live with that speed.
But still thank you for the answers!
Displaying 17446 - 17460 out of 18579 results.
Time to create page: 0.388 seconds
