  • atrex77
  • atrex77's Avatar
14 Mar 2025 21:47
Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC
i dont think all functions are able to handled with one pico, i have more time now for testing because the first PCB-s are only shipped on mar.23 and the components is in the coming week.
  • atrex77
  • atrex77's Avatar
14 Mar 2025 21:42
actually not using PIO now, the UDP data transfer runs on core0 and all io handling runs on the second core, i use the W5100s-evb-pico for the project with the wiznet library (using arduino ide) (for PIO testing i make a frequency generator (later stepgen) and send velocity from 1 of linuxcnc joint to it, it makes 2Mhz signal but dont have a fancy scope to find its jittering. Shock settled on my face, and a small smile appeared at the corner of my mouth when I saw the signal on the scope.
  • andypugh
  • andypugh's Avatar
14 Mar 2025 21:15
Looks promising. Many LinuxCNC hardware interfaces run at 1kHz, and that works fine for most purposes.
Are you using the PIOs to handle the communications? Maybe there are gains to be made there?
Does the Pi-Pico handle UDP natively?
  • besriworld
  • besriworld
14 Mar 2025 21:07 - 14 Mar 2025 21:08
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
With the new processor, latency seems better. But the test started without internet (I had a problem with the internet).
File Name: 1741970242.lat.txt
File Size:1,007 KB
But it seems the main problem is the communication with the mesa card. Please see the attached picture.
I get this as soon as I start LinuxCNC. Why are ping times good, but in LinuxCNC it is so slow?
  • PCW
  • PCW's Avatar
14 Mar 2025 20:54
Replied by PCW on topic Mesa modbus and pktUart
Category: Other User Interfaces
A quick way to verify that you have fixed the divide by 0 issue
is to set the update rate to 0 in say halshow, and the set it back to say 1
If communication continues at 1 Hz, then the issue has been fixed.
(I say this because at least in a RIP installation the
mesa_modbus.c.tmpl file used is not the one in the
LinuxCNC sources)
  • NT4Boy
  • NT4Boy
14 Mar 2025 19:49 - 14 Mar 2025 19:51
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Delving into this in more detail, the AtoD conversion doesn't look very stable.
My digital voltmeter reads on a nominal mid position of XY feed pot a steady, non varying 1.666v
the 7i73 analog0 numbers flicker, not regularly, like on a timer, but with a fast random up and down.. With a slow-mo video
I actually get readings 1.565882,1.578824, 1.591756 the differences are exactly one bit. (3.3volts, 255 bits, ie 0.012941 volts per bit)
When the servos are on, then this flicker is actually audible.
Can you suggest anything that I can do to improve this please?
  • atrex77
  • atrex77's Avatar
14 Mar 2025 19:46
i make another test this time with raspberry pi4 (4gb)
14 Mar 2025 19:28
14 Mar 2025 19:26
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
To normal people, those numbers seem very far fetched as there is no pricing info for anything like that.
As Americans say: if you have to ask for the price, you can not afford it.
And when you do ask, be sitting with a glass of cold water in hand and 911 on speed dial.
Only when you have invoices in hand for such stuff, you start believing (coupled with the headache it induces) :)
See if you can find pricing for commercial license 5 axis CAM and report back here, if you can! :)
14 Mar 2025 19:15
Replied by tommylight on topic Funny message when reply to a topic
Category: Forum Questions
We (mods and admins) get e-mail notifications for every post, always, so from 50 to over 100 daily.
  • royka
  • royka
14 Mar 2025 18:44 - 14 Mar 2025 18:50
Replied by royka on topic Can't eek out that last bit of jitter
I think that you should enable HPC (High Performance Computing) to prevent it from lowering the cpu frequency. Possibly also core performance boost. And to see if the kernel parameter works: cat /sys/devices/system/cpu/smt/active
  • ihavenofish
  • ihavenofish
14 Mar 2025 18:10
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
my only contact is the sales lady
  • AlexMagToast
  • AlexMagToast's Avatar
14 Mar 2025 18:09
Replied by AlexMagToast on topic Arduino IO Expansion
Sure, but can you please expain what you would like to do?
  • LCR
  • LCR
14 Mar 2025 18:07
Category: EtherCAT
I've sent an email. We'll see. If anyone has a contact, please let me know.
  • sajurcaju
  • sajurcaju
14 Mar 2025 17:58
Replied by sajurcaju on topic An odd thing about jitter, and a question
Yes. What's holding me up is having blown up my parallel port :<
So I'm getting lost in details while waiting for the card (well, I bought two of them) to show up.
For other people's reference, the Dell Sunix 0GP385 cards work fine with LinuxCNC and are readily available on ebay.
Displaying 17596 - 17610 out of 18588 results.
Time to create page: 0.455 seconds
