  • ihavenofish
  • ihavenofish
06 Mar 2025 05:25
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
so vid is vendior id and pid is product?
== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000083
Product code: 0x00000006
Revision number: 0x00020001
Serial number: 0x1001007d
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3318981850 0 0
1 MII up open yes 1 3318984170 2320 560
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1800/256, TX: 0x1c00/256
Supported protocols: CoE
General:
Group:
Image name:
Order number: R88D-KN02H-ECT
Device name: R88D-KN02H-ECT G5 Series ServoDrive/Motor
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: yes
Flags:
Enable SafeOp: yes
Enable notLRW: no
Current consumption: 0 mA
  • rodw
  • rodw's Avatar
06 Mar 2025 04:41
Yes, I only shared the main hal file.
You need to run Ethercat slaves -v and get the vid and pid for your drive.
the main registers will be in the cia402.comp example. Mainly the registers with the 0x6000 addresses
The 2000's are vendor specific. So do the basics, then add in the vendor specific ones you need from your drive manual.
Note my drives have 4000 encoder counts per rev and on a 5mm pitch balls screw gives a scale of 800 per mm
note the byte data is in lo high format  so 0x0102 will be formatted as 02 01 when setting SDOs
  • ihavenofish
  • ihavenofish
06 Mar 2025 04:30
ok, that was my error. now it says failed to execute sdo download.
i think this is cause of course i dont have your servos/config (only one drive connected).
So i guess now i need to edit it to match my own?
  • kzali
  • kzali
06 Mar 2025 04:26
My bad
Okay so when I was looking up the schematics and pcb files I realised that I had inserted the Tang nano in the wrong direction ,  when I fixed that tand powerd the bob a bright red led light up on the w5500 module and the Lan link was connected to the host,  when I pressed test gui button the select target popped up for udp 192.168.10.194.   pressed ok  and tested wled selecting the 3 boxes lit up the wled on the bob and tested all colors worked like a charm. There was this warning in the terminal (dont know if it is important)  connection via: UDP
IP: 192.168.10.194
PORT: 2390
WARNING: can not set timeouts: timed out
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 10551690, major code: 40 (TranslateCoords), minor code: 0
RIO-TestGui is great. Next step power the 5axis bob and setup some test hardware and usb power the China Bob. Great work Olly. Me super excited. Thank you Robert and Oliver for your quick responses.
Cheers
Kam
  • ihavenofish
  • ihavenofish
06 Mar 2025 04:16
tried your file, i get this
Note: Using POSIX realtime
lcec_conf: ERROR: unable to open config file ethercat-conf.xml
./VMNmillQT.hal:15: waitpid failed lcec_conf lcec_conf
./VMNmillQT.hal:15: lcec_conf exited without becoming ready
Could not open command file 'shutdown.hal'
23902
Stopping realtime threads
Unloading hal components
  • behai
  • behai
06 Mar 2025 04:10
Replied by behai on topic Mesa 7I96S and Proximity Switches
Category: Driver Boards
I bought 8 NPN NO switches, I tested with only one switches, I set it to max-x, I was able to get HALShow to recognise the switch. I made a short clip to show it working:
Thank you all for your helps... I have learned a lot so far, still much more go to, but without this forum, I would not be able to get this far.
Best regards,
...behai.
  • cmorley
  • cmorley
06 Mar 2025 02:57
Help,How to customize language of QtDragon's interface
Category: Qtvcp
It was intended to be placed in CONFIGURATION FOLDER/qtvcp/screens/qtdragon_hd/languages/ but there is a bug.
Place it in CONFIGURATION FOLDER/qtdragon_hd/languages/ until I fix the bug.
Chris
  • unknown
  • unknown
06 Mar 2025 01:27
Replied by unknown on topic Ethernet Settings for Raspi4
Category: Installing LinuxCNC
Thanks Pete
I've added your post to the RPi sticky in the Installing Linuxcnc Section.
  • unknown
  • unknown
06 Mar 2025 01:21 - 06 Mar 2025 01:23
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Simple Mesa Setup
Thanks to PWC
You definitely do not want DHCP and you do
need to set a static address.
You might try this:
auto eth0
iface eth0 inet static
address 10.10.10.100
netmask 255.255.255.0
DO NOT set a gateway or nameservers
05 Mar 2025 23:56
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
3 Probably because QtDragon does not use the same enable pin as GmoccaPy, although if that is the case, i would really insist on fixing that in QtDragon.
Can you upload config files for both GUI's?
  • vre
  • vre
05 Mar 2025 23:41
Category: Qtvcp
I have installed master and done qm file with linguist how to install it to qtdragon_hd?
  • Tim1
  • Tim1
05 Mar 2025 22:43
LinuxCNC using Ethercat on Raspberry Pi5 controlling Stepperonline A6 Servo
Category: EtherCAT
I checked that thread and I haven't seen anything to address the Sync manager Watchdog.
  • noqui
  • noqui
05 Mar 2025 21:37 - 05 Mar 2025 22:20
Replied by noqui on topic Custom Panel
Custom Panel
Category: AXIS
I used Qt 5 Designer to modify Qtaxis.ui
Through these new 5 tab windows I will add some widgets to each tab window. One will have a Camera, another a simulation of the robot made in FreeCAD, etc.
Any help would be many steps forwards. Thanks a lot.
Displaying 18136 - 18150 out of 18599 results.
Time to create page: 0.445 seconds
