  • rodw
  • rodw's Avatar
23 Feb 2025 00:05
Replied by rodw on topic estop issue
estop issue
Category: HAL
You should use estop-latch
There is an example in hal examples on the forum
and this video
  • PCW
  • PCW's Avatar
22 Feb 2025 23:55
Replied by PCW on topic 7i84 MPG input settings
Category: PnCConf Wizard
The default is 1X forward which should work for most MPGs
  • Jdolecki
  • Jdolecki
22 Feb 2025 23:43
7i84 MPG input settings was created by Jdolecki
It says 7i84 cab accept MPG inputs on pins16,17,18,19.
what do I set the inputs as?.
  • cmorley
  • cmorley
22 Feb 2025 23:31
Replied by cmorley on topic development of a qt version of ncam
Category: Qtvcp
There is a branch that I created for Qt_ncam:
github.com/LinuxCNC/linuxcnc/commits/qt_ncam/
As I said I haven't looked at it in a while so need to rebase on master and make sure it still works. I am not a proper programmer - I just hack till it works so the code right now is a mess.
The big problem is I never used Ncam so don't know how/what things worked before.
Some things work now but really I could use someone who knows the program to audit and prioritize what part to work on. That would help and motivate me more.
yes I have less time for linuxcnc too.
I would really like to get this working and in linuxcnc.
Chris
  • JT
  • JT's Avatar
22 Feb 2025 22:52
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
The jog buttons work as expected and the axis jogs as long as I'm touching the button on my touch screen on my BP and they work in Debian with a simulator. I'm assuming you're using jog plus minus joint buttons such as jog_plus_pb_0 for the X axis and Continuous is selected.
gnipsel.com/linuxcnc/flexgui/controls.html#jog-controls
Feedback is what keeps me going!
JT
  • Jdolecki
  • Jdolecki
22 Feb 2025 22:45
Replied by Jdolecki on topic Operating computers in the cold
Hard drives dont like cold.
And if you running them out on the floor make sure you have a backup of the HD cause one day you gonna turn it on and it’s gonna say no HD found.
  • unknown
  • unknown
22 Feb 2025 22:44 - 23 Feb 2025 08:12
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
No, it has nothing to do with the kernel module, disabling the kernel module won't stop the service running. The messages are coming from the service systemd is attempting to start.
One option is to mask the service and have no swap available.
The second option is as I've described and have a little swap if needed.
But it's not the kernel modules that are issue.
Not to be unkind but I didn't pull the solution out of my backside, I spent some time researching the issue, as to what was causing the issue, how to fix the issue and what was supposed to be happening.
The service is for setting up swap in compressed ram. Whilst there is a little overhead in compressing and decompressing the speed for accessing ram is far far quicker than accessing a drive of any sort. If no swapping occurs it will have no affect on latency.
And even before I offered up my solution I ran a few tests to make sure I had the method correct and there were no issues with latency or anything else.
And yes I should have been more vigilant when initially putting everything together.
PLEASE NOTE
all references to zram.service should be zramswap.service
  • NT4Boy
  • NT4Boy
22 Feb 2025 22:33
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Maybe as the Z axis, negative end is actually, when extended, and I my head I'm calling that max-z, in fact that end is really min-z, so it is connected?
  • unknown
  • unknown
22 Feb 2025 22:22
Replied by unknown on topic Linuxcnc hotspot on raspberry pi
That would work if network manager was the method used to manage the interfaces and network-manager-gnome was installed. But that's not the way the images are built.
And honestly if you don't setup a firewall as well.....
  • NT4Boy
  • NT4Boy
22 Feb 2025 22:20
Not really.
I started the whole config with mesact, then as the switches are 5volt, needed to use encoder channels, the index is inverted so have to not the signals, and then moved to pncconf. Lastly from one of the notes above copied what I thought was required homing code.
So the hoops, are just a mess I've got myself into.
If nothing is tied to max-z then even more mystified how its possible to home on it.
I guess that proves those three lines of code are superfluous.
  • Ozymandias87
  • Ozymandias87
22 Feb 2025 22:06 - 22 Feb 2025 22:06
Beckhoff KL4032 VFD Spindle speed control was created by Ozymandias87
Category: EtherCAT
Hi all! I am at the stage of procuring the required Ethercat modules to implement my CNC Router control topology and I am currently stuck on VFD speed control signal output. Is it possible to configure the HAL to use one of the analog ports on the Berkhoff 4032 Analog Output module to sent the speed signal defined in the front-end to the VFD, as in a conventional breakout board setup?
Best!
  • PCW
  • PCW's Avatar
22 Feb 2025 21:51
Replied by PCW on topic 7I97T joint following error
What PWM problem?
When PWM enable is true, the analog output voltage will match the PWM value number.
_but_ if you get a fault (as it looks like in your first data dump), LinuxCNC will go into the
machine-off state and disable PWM enable so no analog output is possible
Can you re-do the halcmd show all > all.txt with linuxCNC running in the machine on state
(if running axis, this means the power button is depressed = shows shadow border)
22 Feb 2025 21:50
Replied by tommylight on topic HURCO KMB-1 Control Update
Nothing is tied to max-z, everything is tied to min-z, so the only active pin is min-z input, and from your description even that is not set properly as you are getting joint 2 following error form the motor bottoming out.
Can you explain again why such hoops for home and limits on Z?
  • 109jb
  • 109jb
22 Feb 2025 21:49
Replied by 109jb on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I cannot thank you enough for doing all of this work for the FLexible GUI. I have been playing with it for a few days and it is very simple to create what you want visually.
That said, I have a question. I am setting up a Jog screen for use with a touchscreen monitor and cannot figure out how to make it so you can hold the on-screen jog button in a pressed state for continuous jogging. You can do it with a mouse, holding the mouse button down, but just holding your finger on the screen doesn't have the same effect.
I will say that I am experimenting with this in a virtual machine on my Windows PC using a simulated CNC machine. I don't currently have a touchsceen for the RPi I'll be using for LinuxCNC. Maybe that has something to do with it.
If anyone can help it would be appreciated.
  • COFHAL
  • COFHAL
22 Feb 2025 21:39
Replied by COFHAL on topic Deckel-Maho DMU 50T
Deckel-Maho DMU 50T
Could you post photos of the SIEMENS 611 controllers?
Displaying 18676 - 18690 out of 19013 results.
Time to create page: 0.545 seconds
