  • Sandro
  • Sandro
10 Feb 2025 17:32 - 10 Feb 2025 17:33
THC with Beckhoff EL5101 and THCAD2 => encoder signal loss
Category: Plasmac
Hello everybody,
Thank you all very much for your inputs and recommendations. I can test most of them next weekend and report back to you.
I've tested the THCAD2 with a divider ratio of 1/128 and 1/64 already, but I can't remember if I also checked with 1/32. Will definitely try again.
I will also check the cabling again and the stability of the 5V power supply.
I think the frequency does not go to absolute zero but to less than 1 Hz (guess). I will also have a closer look at the duration of these drops. The EL5101 seems to provide some values for underflow, overflow and also the possibility to filter the frequency.
Warning: Spoiler!
I was also thinking of some moving average to filter the drops. But I don't know how I could implement this. Writing a custom HAL component?
  • unknown
  • unknown
10 Feb 2025 17:05
Replied by unknown on topic The dumification of humanity through internet
I'll just giggle at the irony of your opening post.
  • NT4Boy
  • NT4Boy
10 Feb 2025 16:59 - 10 Feb 2025 17:00
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Three axes moving. Not without a fight.
On enabling the servos, without me touching anything, the z axis would advance about 1mm, and trip out with joint follower error. Similar symptom to replacing an encoder and getting the a and b channels swapped. Took me too many hours to find in the heart of Tommy's tuning guide the answer, put a minus in front of the motor scale figure. (Required on all the axes.)
I've entered a default figure 20 for P and deadband.0001mm. Kind of surprised I cannot get it to error even at max jog speed.
Keep jacking up the P value, until it oscillates I guess, a job for another day.
  • Todd Zuercher
  • Todd Zuercher's Avatar
10 Feb 2025 16:46
Replied by Todd Zuercher on topic EtherCAT Testing?
EtherCAT Testing?
Category: EtherCAT
The real time kernels run, they just don't "work" as in the latency for real time tasks is about the same as running a non real time kernel.
  • IB_CnC
  • IB_CnC
10 Feb 2025 16:43 - 10 Feb 2025 16:52
ProbeBasic and sidemount, retractable 3D Probe
Category: QtPyVCP
Ahh yes, apologies I did misinterpret.
Yes that would be possibly I think, I did not see this possibility when I was drawing out concepts.
It would require a fairly large (stationary) support structure outside of gantry support, and access to table would be limited a bit, but other than that it should work.
I did already buy all parts for the carousel and got all the aluminum plates ready to route the holes, but its a good alternative option without loosing work area!
  • MaHa
  • MaHa
10 Feb 2025 16:34
Replied by MaHa on topic Z probing with G38.4
Looking at this table in the manual, G38.4 seems not possible without probing move towards piece.
10 Feb 2025 16:15
Replied by tommylight on topic The dumification of humanity through internet
Anyone against deleting this topic?
I failed to raise hell... :)
P.S.
I still maintain that calling silicium "silicon" is not smart, by any stretch of imagination. Sue me !
  • Hakan
  • Hakan
10 Feb 2025 16:05
Replied by Hakan on topic EtherCAT Testing?
EtherCAT Testing?
Category: EtherCAT
I tend to think that EtherCAT doesn't add any timing constraints.
Worthwhile to do a test. But you can't run a realtime linux kernel in a virtual machine, can you?
  • Hakan
  • Hakan
10 Feb 2025 16:01
Replied by Hakan on topic Ethercat + step/dir signals
Category: EtherCAT
Hakan's EaserCat 3000?
Experimental. Perhaps too experimental. I just bought EtherCAT stepper driver Rtelligent ECT60 and used my own IO card.
  • Reddiamonduk
  • Reddiamonduk
10 Feb 2025 15:59 - 10 Feb 2025 23:15
Replied by Reddiamonduk on topic Error starting gmoccapy with spindle speed display.
Category: pyVCP
It seems like you may be on to something, there is no pyvcp in that list. I have also added other photos in case there is something that may help.
Pins
custompanel.xml
hal files in 'ini' file
pyvcp_options.hal file
  • CADdy
  • CADdy's Avatar
10 Feb 2025 15:34
Replied by CADdy on topic Ethercat + step/dir signals
Category: EtherCAT
  • spontarelliam
  • spontarelliam
10 Feb 2025 15:24
Z probing with G38.4 was created by spontarelliam
I currently use a z probe routine that uses G38.2 to lower the tool into a metal puck until detecting continuity. This works 90% of the time, but there have been a few times this went wrong when either the wire to the puck had become damaged from use over time or the endmill had some plastic stuck to the tip or some resin from a wood cut, etc.
It seems much safer to manually drive the endmill down into the puck, then use G38.4 in the probe routine to move away from the puck. When I make this change and manually drive the endmill into the puck, I get a "Probe tripped during coordinate jog" error. Any ideas on how to avoid this error or how G38.4 is typically implemented?
Thanks!
  • PCW
  • PCW's Avatar
10 Feb 2025 15:18
need help! mesa 7i95 connection problem
Category: Driver Boards
Maybe you don't have a Intel MAC
lspci -nn | grep -i ethernet
Should list what you have.
Have you run a normal latency test?
  • Todd Zuercher
10 Feb 2025 14:58
EtherCAT Testing? was created by Todd Zuercher
EtherCAT Testing?
Category: EtherCAT
Is it possible to do any useful testing of EtherCAT hardware with a virtual machine running Linuxcnc?
I fully understand that Linuxcnc can't run with any realtime capabilities within a virtual machine.  But can an Ethercat configuration be set up, configured and connect to a real Ethercat device for testing purposes?  I don't want to set up and run a machine this way.  I would just like to see if I can read some IO modules, maybe configure/talk a drive and send it a command for bench testing.
What all could you expect this to do?  What things would be expected to not work at all?  What might sort of work?  Can Linuxcnc communicate with a Beckhoff PLC if so to what extent?
  • noqui
  • noqui
10 Feb 2025 14:16
error running telnet using linuxcncrsh
Hi,to my hal file: loadusr -W hal_manualtoolchangenet tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared loadusr linuxcncrsh -n --name localhost, -p , --port 5007 I added the line in bold at the end of my hal file, and there didn't appear any error when I ran the CNC manually the Axis Gui. Everything works. But when i tried to run in this command "telnet localhost 5007", through the Terminal i got this error:Trying ::1...
Connection failed: Conexión rehusada
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]' I am using parallel port 0x378 What is missing or is wrong?Thanks a lot.
Displaying 19021 - 19035 out of 19543 results.
Time to create page: 0.569 seconds
