  • unknown
  • unknown
05 Feb 2025 01:02
Installing NoMachine Remote Desktop - Package installer issues
Using the command line is like...........
Correct punctuation (including Commas) is very important ...
Punctuation! is the difference between …
Helping your Uncle, Jack, off a horse.
and
Helping your uncle jack off a horse.
  • unknown
  • unknown
05 Feb 2025 00:57
Replied by unknown on topic Newbe trying to run 7i92TM
Category: PnCConf Wizard
What do you mean exactly by "when connected to internet" ?
What is your network setup, IP addresses ?
Do you have 2 ethernet cards or wireless & ethernet ?
Have you tried 10.10.10.xx network for the Mesa card ?
  • unknown
  • unknown
05 Feb 2025 00:53
Replied by unknown on topic Verifying LinuxCNC ISO download.
Category: Installing LinuxCNC
Just give it a go,
I get
ef0d0cc7142444d8793233e516105f0c9f3dee667cfede1539e2190b39a29060
and all seems fine.
  • Chich2
  • Chich2
05 Feb 2025 00:41
Replied by Chich2 on topic Mesa Suppliers
Mesa Suppliers
Category: Driver Boards
Thanks for a smooth transaction Brad.
To anyone interested, I still have 3 available.
Chich.
  • Lcvette
  • Lcvette's Avatar
05 Feb 2025 00:38
Replied by Lcvette on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
I think he was referring to the integration in probe basic
  • automata
  • automata
05 Feb 2025 00:25
Replied by automata on topic scurve trajectory planner
Hi Grotius,
I sent you an email last month about the servo and stepper drives. Hope you have received it.
I am also seeing the same acceleration peaks in the joint command acceleration.
Inhave a suggestion: clothoid length can be calculated easily by knowing the start and end curvature radius and the clothoid parameter A.
www.geogebra.org/m/pPu6Kb3z#:~:text=Clot...20A2%20is%20constant.
math.stackexchange.com/questions/3287710...-of-clothoid-segment
Maybe clothoida are the way to go for 3 axis geometries. Beyond that I am having a hard time imagining what a clothoid would look like in higher dimensions.
-automata
  • babinda01
  • babinda01
05 Feb 2025 00:18
Hi Olli
Thank you very much for your efforts, I will download the latest dev of riocore tonight and will let you know how it goes.
Andrew
  • martyop
  • martyop
05 Feb 2025 00:00
Replied by martyop on topic Verifying LinuxCNC ISO download.
The cheksum I get with sha256sum linuxcnc_2.9.4-amd64.hybrid.iso is:
ef0d0cc7142444d8793233e516105f0c9f3dee667cfede1539e2190b39a29060  linuxcnc_2.9.4-amd64.hybrid.iso
Which does not match the checksum listed on the getting linuxcnc page which is given as:
sha256sum: 08b3f59233e47c91cf1c9a85c41df48542c97b134efefa7446d3060c9a3e644b
arm64 (Pi)
I have done several dowloads and thus far none of the checksums have matched.
zsync is listed as an alternative on the getting linuxcnc page.  It does  not find a control file that it wants on the server and it will not download linuxcnc_2.9.4-amd64.hybrid.iso.
I share your frustration.
  • Tobi_tree
  • Tobi_tree's Avatar
04 Feb 2025 23:59
Newbe trying to run 7i92TM was created by Tobi_tree
Hi there my Name is Tobi and I need help,
I am trying to run my Stepcraft D420 with a 7i92TM on Debian Bookworm ( SMP PREEMPT_RT Debian 6.1.124-1) .
I got so far that i can connect to my MESA 7i92TM with
--addr 192.168.1.121 --device=ETHER --readhmid
and get this output:
Configuration Name: HOSTMOT2
  BoardName : MESA7I92
  FPGA Size: 20 KGates
  FPGA Pins: 256
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 180.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 2 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: StepGen
  There are 10 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: PWM
  There are 2 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 180.000 MHz
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       None
14                      1   IOPort       PWM              0        PWM             (Out)
 2                      2   IOPort       StepGen          0        Step/Table1     (Out)
15                      3   IOPort       None
 3                      4   IOPort       StepGen          0        Dir/Table2      (Out)
16                      5   IOPort       StepGen          4        Step/Table1     (Out)
 4                      6   IOPort       StepGen          1        Step/Table1     (Out)
17                      7   IOPort       None
 5                      8   IOPort       StepGen          1        Dir/Table2      (Out)
 6                      9   IOPort       StepGen          2        Step/Table1     (Out)
 7                     10   IOPort       StepGen          2        Dir/Table2      (Out)
 8                     11   IOPort       StepGen          3        Step/Table1     (Out)
 9                     12   IOPort       StepGen          3        Dir/Table2      (Out)
10                     13   IOPort       QCount           0        Quad-A          (In)
11                     14   IOPort       QCount           0        Quad-B          (In)
12                     15   IOPort       QCount           0        Quad-IDX        (In)
13                     16   IOPort       None
IO Connections for P1
 1                     17   IOPort       None
14                     18   IOPort       PWM              1        PWM             (Out)
 2                     19   IOPort       StepGen          5        Step/Table1     (Out)
15                     20   IOPort       None
 3                     21   IOPort       StepGen          5        Dir/Table2      (Out)
16                     22   IOPort       StepGen          9        Step/Table1     (Out)
 4                     23   IOPort       StepGen          6        Step/Table1     (Out)
17                     24   IOPort       None
 5                     25   IOPort       StepGen          6        Dir/Table2      (Out)
 6                     26   IOPort       StepGen          7        Step/Table1     (Out)
 7                     27   IOPort       StepGen          7        Dir/Table2      (Out)
 8                     28   IOPort       StepGen          8        Step/Table1     (Out)
 9                     29   IOPort       StepGen          8        Dir/Table2      (Out)
10                     30   IOPort       QCount           1        Quad-A          (In)
11                     31   IOPort       QCount           1        Quad-B          (In)
12                     32   IOPort       QCount           1        Quad-IDX        (In)
13                     33   IOPort       None
But when I am coneckted to the Internet i cant Ping the Mesa Card or connect via mesaflash
Also "mesaflash --device 7i92 --addr 192.168.1.121 --readhmid
results in this output: No 7I92 board found
When i try to run LinuxCNC
i get this Error output:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/tobias/linuxcnc/configs/TEST_MESA7i92'
Machine configuration file is 'TEST_MESA7i92.ini'
INIFILE=/home/tobias/linuxcnc/configs/TEST_MESA7i92/TEST_MESA7i92.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./TEST_MESA7i92.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_pci: rtapi_app_main: No such device (-19)
./TEST_MESA7i92.hal:9: waitpid failed /usr/bin/rtapi_app hm2_pci
./TEST_MESA7i92.hal:9: /usr/bin/rtapi_app exited without becoming ready
./TEST_MESA7i92.hal:9: insmod for hm2_pci failed, returned -1
24393
Stopping realtime threads
Unloading hal components
Can somebody help me please?
Thank you in advance for taking your time with this.
  • royka
  • royka
04 Feb 2025 23:35
Linuxcnc Debian bookworm update from 2.9 to 2.10
@Mr. Mass Perhaps still some files were left after removing it? Try to search for it after removing LinuxCNC with apt with: sudo find / -name linuxcnc
04 Feb 2025 22:30
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
It's not the board, it's Klipper.
Any board will work for 3D printing and any old PC, not just RPI (i was p.o. at those influencers that always started with "you need a RPI..." ), i have an Acer tablet attached to one of the Vorons that was never shut down, for over 2 years, that poor Voron is always ready to start printing, even from the phone, even if i am in say Australia (got invited there recently for when it gets hot over there :) ), and no i do not use remote desktops and teamviewer n'stuff, i use telegram, so no open ports and perfectly safe.
It would be blasphemy, but that would require FPGA to run klipper firmware in worst case, or add pressure advance and input shaping to LinuxCNC, or at least a way to set some values and be done with it.
Meaning, use a klipper board to test and get those values for advance and shaping, then plug those in LinuxCNC and live happily ever after.
  • spumco
  • spumco
04 Feb 2025 22:19
Replied by spumco on topic Brilliant Bambu Lab
Brilliant Bambu Lab
The BTT Panda isn't going to work with Bambus if they have the new firmware - unless they're put in Developer mode.
The Panda uses the same external-device communication scheme as X1Plus 'firmware' - i.e. it's a front end, not actual firmware.
"Note that the Panda Touch warranty does not cover lost functionality due to a Bambu Lab firmware update being performed."
04 Feb 2025 22:15
Replied by tommylight on topic CNC Plasma cutters, DIY, building info and guide
Category: Plasma & Laser
Stahlwerk, Stamos, even my Kzubr is still working just fine, although mine has been siting idle for nearly 2 months, the rest are in use daily.
Stahlwerk has it's own website, and stuff there is cheaper that on Amazon
Vertical machine torch is from 40-50 usually
www.stahlwerk-schweissgeraete.de/zubehoe...r-p-80-cnc-edelstahl
70A with pilot arc is 450 but currently not available
www.stahlwerk-schweissgeraete.de/plasmas...-cut70-pilotzuendung
Here is the full list of plasma, mind the pilot arc and notice those with pilot arc have another red connector on the lower front.
www.stahlwerk-schweissgeraete.de/Plasmaschneider-CUT
04 Feb 2025 22:06
Replied by tommylight on topic The dumification of humanity through internet
Nah, i did my thing, no one started screaming at me, got more replies from Ausies than Americans despite aiming for Americans (i was convinced the silicium thing is just another "labeling everything wrong" American doing, obviously it was not), and all in all, a very civilized conversation.
Now moving on to "tabless" Elon-Tesla wrongly labeled batteries...
Should i start a new topic for that? :)
Or should i pick on Intel and AMD and Nvidia as it is still a hot topic?
Or Facebook/meta, twitter/x, adobe.....
ah the choices ... :)
Displaying 19456 - 19470 out of 19548 results.
Time to create page: 0.794 seconds
