  • PCW
  • PCW's Avatar
01 Jan 2025 22:17
Replied by PCW on topic 7i96s not recognized
Category: Basic Configuration
I'm not sure what you mean when you say (long) Ethernet device name?
enx0050b6c0edc3
  • slowpoke
  • slowpoke
01 Jan 2025 22:03 - 01 Jan 2025 22:17
Replied by slowpoke on topic 7i96s not recognized
You should not change the hosts file, but rather the etc/network/interfaces file
This is what's in mine:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
       auto eno1
       iface eno1 inet static
           address 10.10.10.100
           hardware-irq-coalesce-rx-usecs 0
You would need to change eno1 to your (long) Ethernet device name
Presently that file has:
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
In Network Connections I called the ETHERNET instance  "Wired connection 7i96s"
I'm not sure if that is what you are referring to?
  • Grotius
  • Grotius's Avatar
01 Jan 2025 22:00
Replied by Grotius on topic PathPilot V2 source code
Category: PathPilot
Test scurve on real machine.
Just playing around.
youtube.com/shorts/8r2IrYtdmNI
  • RNJFAB
  • RNJFAB
01 Jan 2025 21:41 - 01 Jan 2025 21:44
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
Nothing but errors for me.
been a long few days reading again.
Got Debian 12 Bookworm setup and running.
Loaded Linuxcnc 2.9.
Got Mesa card flashed.
Now cant get a working config.
About to try an reinstall everything as per RODW Debian 12 & Linuxcnc packadge.
  • kzali
  • kzali
01 Jan 2025 21:38 - 01 Jan 2025 21:41
"many thanks to 'Schoch' , for the quadencoder(z) fixes and the much better rps/rpm calculations.
and many thanks to all other people that helps here, in github and in the discord chat."
Is the discord chat related to RIO? and if so what is the link to the channel?
  • cmorley
  • cmorley
01 Jan 2025 21:24
Replied by cmorley on topic qtvismach, a axis toolpath
Category: Qtvcp
It's hard coded to the left.
in halHud/hud draw() function defines it.
I'll look into it when I can.
  • PCW
  • PCW's Avatar
01 Jan 2025 21:08
       auto eno1
  • cmorley
  • cmorley
01 Jan 2025 20:48
qtDragon LED Probe und Spindeldrehzahl anzeigen
Category: Deutsch
Aus dem Handbuch:
Die QtDragon-Spindelgeschwindigkeitsanzeige und die Spindelgeschwindigkeits-LED erfordern, dass „spindle.0.speed-in“ mit der Spindelgeschwindigkeitsrückmeldung verbunden ist.
Es kann eine Encoder- oder VFD-Rückmeldung verwendet werden, sofern die Rückmeldung in Umdrehungen pro Sekunde (RPS) erfolgt.
Wenn keine Rückmeldung verfügbar ist, können Sie die gewünschte Geschwindigkeit auf dem Display anzeigen lassen, indem Sie die Pins wie folgt verbinden:
Netto-Spindelgeschwindigkeits-Feedback Spindle.0.Speed-Out-rps => Spindle.0.Speed-In
  • slowpoke
  • slowpoke
01 Jan 2025 20:46
Yes, you are pinging yourself (I hear that may make you go blind)
I would set the host address to 10.10.10.100
I don't know how to set the host address to 10.10.10.100
I tried sudo nano /etc/hosts
and then changed 127.0.0.1 to 10.10.10.100  ans saved and rebooted for good measure, however after that and running ip a
I still see host as 127.0.0.1
So obviously that's not the correct way to change the host address. BTW I changed local host in /hosts back to the way I found it 127.0.0.1
So how does one go about changing the host address?
  • RV3Dtech
  • RV3Dtech
01 Jan 2025 20:07
Category: Deutsch
vielen Dank, für led-probe hat das geholfen.
Wie komme ich zu der Spindeldrehzahl?
  • gilesclement
  • gilesclement
01 Jan 2025 19:47
Replied by gilesclement on topic Trouble Shooting USB Jogging with an Xbox Controller
I have an XBOX controller working with my 3 axis cnc, have been using it for a year now. The only issue I have is that the Y axis is reversed. Pulling the left hand joystick back moves the table forward, which has cost me a few end mills.
I've tried using Jscal and Jstest-gtk to reverse the direction of that axis and it does show up as moving correctly in Jstest but still moves the same way in linuxCNC. Any ideas?
  • zelo
  • zelo
01 Jan 2025 18:33 - 01 Jan 2025 18:37
I looked again at my config and i see some unnecessary crap so ignore this message :)
  • PCW
  • PCW's Avatar
01 Jan 2025 18:29
Replied by PCW on topic Spindle speed and instatnly powered led
Category: Qtvcp
Depending on your breakout card, you may get better linearity by lowering the PWM frequency
  • ihavenofish
  • ihavenofish
01 Jan 2025 18:05 - 01 Jan 2025 18:05
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
There, moved to the front.
Tiny motor to spin the mag I guess. with some sensors. or encoder. the 7i96s has an open encoder input since the spindle doesn't have one. Hm. Gotta think about that. On an ethercat version if just use a 50w absolute servo I guess.
  • ErwinCNC
  • ErwinCNC
01 Jan 2025 18:00
Replied by ErwinCNC on topic Linux CNC startet nicht mehr
Category: Deutsch
Vielen Dank
Der Fehler lag tatsächlich in der Konfiguration des Netzwerks. Um den Ping zu reduzieren habe ich folgende Datei editiert und dabei wohl einen Fehler gemacht. Die eigentliche Netzwerkverbindung habe ich nicht bearbeitet weshalb ich nicht auf die Idee gekommen bin.
Läuft wieder
Danke
Add these lines to the file /etc/network/interfaces to configure eth1 with a static address:
auto eth1
iface eth1 inet static
address 192.168.1.1
Displaying 20926 - 20940 out of 21769 results.
Time to create page: 0.500 seconds
