  • djdock99
  • djdock99
31 Dec 2024 21:58
Replied by djdock99 on topic Maho mh800w retrofit
Category: Milling Machines
Hi PCW
Thanks for such a speedy reply
(manual extract HARDWARE CONFIGURATION IP ADDRESS SELECTION The 7I97T has four options for selecting its IP address. These options are selected by Jumpers W11 and W12.
W11 W12 IP ADDRESS
DOWN DOWN FIXED 192.168.1.121(DEFAULT)
DOWN UP FIXED FROM EEPROM
Note: The as shipped default EEPROM IP address is 10.10.10.10. This can be changed via the mesaflash utility)
I have tried multiply attempts using the following jumper pin locations
Down UP =  Computer ip 10.10.10.1 -7i97t unchanged at 10.10.10.10
Down UP =  Computer ip 10.10.10.11 -7i97t unchanged at 10.10.10.10
Down UP =  Computer ip 10.10.10.10 -7i97t unchanged at 10.10.10.10
also tried
down down= computer at 192.168.1.1  & 7i97t at 192.168.1.121
down down= computer at 192.168.1.0  & 7i97t at 192.168.1.121
down down= computer at 192.168.1.121  & 7i97t at 192.168.1.121
same results
Ive spent the last 2 days at this and im lost.
I cannot get mesaflash to find the board name or anything.
I cannot get mesaflash to update either. my installed version is something like 3.4.8 or something like that and ive read i need 3.5.something for 7i97t. Im at home now. cant remember exactly. anyway ran all the bash command listed on github for mesaflash update and it says im uptodate with 3.4.8 which i dont think is correct.
Is there a way to verify correct connection between the computer and the mesa board without using Mesaflash or ping as the bash command?ping has returned ''working fine'' on many of the attempts above but still unable to launch this basic config without errors? what leds should be lit with a correct connection.
What ip address should be in the Hal file? the boards or the computers?
Thanks Paul.
  • TomAlborough
  • TomAlborough's Avatar
31 Dec 2024 21:57
Replied by TomAlborough on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Hello,
I have run into a need for LinuxCNC. I'm wondering if some kernel / device driver work is needed for supporting LinuxCNC on Pi 5. I would look for a user to be able to download, install and use the software without high-level technical support.
Please let me know your thoughts.
Thanks,
Tom Alborough
Some of my related work:
"Thomas Alborough Unix" - (Use citations that contain "Unix" and "Alborough")
"Thomas Alborough Guide to Writing a Unix Device Driver" - (Search for "Alborough")
LinkedIn... Search for "Thomas Alborough"
  • PCW
  • PCW's Avatar
31 Dec 2024 21:37
Replied by PCW on topic Wiring Pendant to MESA 7C80
If Input common 0 (TB1 pin 1) is connected to +5V
You cannot use any signal other than 5V on inputs 0..11
 (so if you have +36 V signals, the common must be GND)
31 Dec 2024 21:36
Replied by tommylight on topic 7i96s not recognized
Category: Basic Configuration
- choose "manual" on the "method" drop down menu
Apparently you missed a step, you still have it set to automatic.
  • PCW
  • PCW's Avatar
31 Dec 2024 21:28
Replied by PCW on topic 7i96s not recognized
Set the IP address in the hal file to 10.10.10.10
(and make sure the 7I96S is set for 10.10.10.10)
  • PCW
  • PCW's Avatar
31 Dec 2024 21:26
Replied by PCW on topic Threading Index Varies With Speed
So I  wonder why it is working now?
  • ccatlett1984
  • ccatlett1984
31 Dec 2024 21:20 - 01 Jan 2025 01:08
Wiring Pendant to MESA 7C80 was created by ccatlett1984
Have this Pendant:
www.amazon.com/dp/B01E6VTZHC
Wiring as below (see attached image).
I have inputs 0-15 available on the 7c80 (have TB02.0 connected to GND)
Looks like Black, Black/white, Black/Orange can all be tied together and connected to GND
Black/Green and Red tied together and connected to 5v+ (power and LED+)
Yellow to an input pin (X)
Yellow/Black to an input pin (Y)
Brown to an input pin (Z)
Black/Brown to an input pin (4th)
Grey to an input pin (spd X1)
Black/Grey to an input pin (spd X10)
Orange to an input pin (spd X100)
I'm not sure on how to wire the A+,B+ and A-,B- for the dial
Looking at this post, would it make sense to use the Encoder (TB4) header for A/B?
forum.linuxcnc.org/27-driver-boards/53986-7i96-mpg-encoder-a-b
Not sure on how i should wire the E-Stop, should E-Stop be controlling a relay for the psu/vfd input power (220v in this case)?
  • slowpoke
  • slowpoke
31 Dec 2024 20:37 - 31 Dec 2024 21:30
7i96s not recognized was created by slowpoke
New installation of Linux2.9.3 on a Lenovo Yoga
I followed the tommylight Ethernet setup for 7i9x and can't seem to get Linux to recognize the 7i96s
Power LED and the green user LED's change status, I'm getting a swirly network icon up in the top right that I assume is indicating it's trying to connect.
Settings and error are as shown in attached.
I also tried moving the jumpers from the default 192.168.1.121 to EEPROM and same result except can't connect to 10.10.10.11
Suggestions?
  • 10K
  • 10K's Avatar
31 Dec 2024 20:35
  • PCW
  • PCW's Avatar
31 Dec 2024 20:05
Replied by PCW on topic Maho mh800w retrofit
You have set the host PC's IP address to the Mesa cards address.
This will not work, all IP addresses on a network must be different.
I would suggest setting the host IP address to 10.10.10.100
(and the 7I97 to 10.10.10.10)
  • PCW
  • PCW's Avatar
31 Dec 2024 18:46
Well, naturally, that looks normal  (no exponential/varying thread pitch)
Was that at 200 RPM?
  • djdock99
  • djdock99
31 Dec 2024 18:45
Maho mh800w retrofit was created by djdock99
Hi
Im new to linux cnc and linux in general. coding and programming is not my strengths so im looking for some help with my retrofit.
I have a maho mh800w which has a philips 523 controller. This has died multiple times and i have been lucky enough to repair it until now as the cpu board or graphics board has gone.
Time for a retrofit as im sick of drip feeding programs.
RotarySMP has been kind enough to forward on all his information which has been great to cross reference philips 432/532 wiring diagrams.
Hardware so far
hp elitedesk 800 g2
Elo touch screen
Heidenhain te425b panel
3 heidenhain 602d's
Mesa 7i97t, 7i84, 7i73, ordered 7i74+7i73
Warning i will probably be asking simple questions but i dont know what i dont know.
1st problem
I cant get a basic configuration to open. this is a basic config that tommy light shared in some thread.
Ive tried 10.10.10.10 and 192.168.1.121 with 7i97t and im lost.
ive done the mesa ethernet card manual as ive an intel Ethernet chip.
 This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).#
#source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eno1
iface eno1 inet static
address 192.168.1.121
netmask 255.255.255.0
hardware-irq-coalesce-rx-usecs 0
Ive done
maho@maho:~$ linuxcnc
LINUXCNC - 2.9.3
Machine configuration directory is '/home/maho/linuxcnc/configs/my_LinuxCNC_machine/backups/basic7i97_2024-06-10'
Machine configuration file is 'basic7i97.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
emc/iotask/ioControl.cc 786: can't load tool table.
Note: Using POSIX realtime
Found file(REL): ./basic7i97.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121  encoders=6 num_pwmgens=6 num_stepgens=0 sserial_port_0=00xxxxxx: Connection refused
hm2_eth: rtapi_app_main: Connection refused (-111)
./basic7i97.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./basic7i97.hal:9: /usr/bin/rtapi_app exited without becoming ready
./basic7i97.hal:9: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
Could not open command file 'shutdown.hal'
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/maho/linuxcnc_debug.txt
and
    /home/maho/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Please help. Paul
31 Dec 2024 18:22
Replied by tommylight on topic Linux CNC startet nicht mehr
Category: Deutsch
Die PC address ist beim 192.168.1.121 eingeshtelt, das muss etwas anderes sein, wie 192.168.1.100 oder 192.168.1.111
  • spicer
  • spicer's Avatar
31 Dec 2024 18:08
Replied by spicer on topic Linux CNC startet nicht mehr
Category: Deutsch
Könnte das das Problem sein?
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121: Connection refused
Wenn hm2_eth die Mesa Karte ist...
  • slowpoke
  • slowpoke
31 Dec 2024 17:54
Mesa 7i96s: differential DRO inputs? & are ENC A and ENC B reqd for threading?
The spindle needs A and Index or A/B and index.
Note that the MPG encoder inputs on TB3 are fairly
slow so may not be suitable for axis scales.
Hmmm....
Lot's of questions and limited knowledge on my side.
Do you know if the isolated encoder inputs are fairly slow because of the opto's or is it the sample speed of those inputs by the FPGA?
If I instead use the inputs available on the expansion connector:
a) Are they fast enough to keep up with the scale data?
b) How would I configure those inputs as quadrature inputs so I can route the results to the DRO display in Linux? Can I do this in HAL?
c) If there is not a way to configure those pairs of inputs as quadrature inputs?
I suppose I could decode the quadrature signals by using a flip-flop in HAL to give direction and then just count pulses for the count, not sure if HAL is fast enough to not miss the counts especially when I do a change of direction? I have a vague image in my mind of a HAL based up-down counter with the flip-flop driving the direction and say the A signal driving the counter clock, hopefully such a counter exists?
Not sure if there is any protection on the expansion pins (I'm guessing direct to FPGA), so either I make a fast isolator board (assuming the inputs are actually scanned quickly) or I take ESD precautions when connecting and just risk it. The DRO pickups will be powered via the 5V on the 7i96s so they will not be powered when the 7i96s is not so will not be driving the unprotected pins when the Mesa board is not energized. Comments/Suggestions welcome.
Displaying 20971 - 20985 out of 21762 results.
Time to create page: 0.703 seconds
