  • Aciera
  • Aciera's Avatar
20 Dec 2024 12:19 - 20 Dec 2024 12:21
  • RNJFAB
  • RNJFAB
20 Dec 2024 10:13
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
So, after the success of my first plasma CNC, I thought it time to move her on to a new home, and build a new one. Bigger, faster, more powah!!!
Im starting with a MESA 7i96 with 2x THCAD10 for volts and ohmic sensing. Closed loop stepper motors will be Nema 34 running 60v. Reduction gearboxes onto helical gears. The z axis will bolt the hypertherm xp45 machine torch and an air scribe. I’ll use an air actuator to drive the scribe to the required height. Everything is running on aluminium extrusion and linear rails. I have prefer up a water bed that is 1500x3000. Giving me adequate space to load up a full sheet.
I’ll get some pics and links to the parts used as I go along.
lots of new things for me to learn with this build so no doubt I’ll be calling on the brains trust for guidance again and to help me when I get myself stuck.
cheers
  • RNJFAB
  • RNJFAB
20 Dec 2024 10:05
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Well, after 6 years, it’s time to say good bye to this baby. It’s about to leave and move to its new home.
Stay tuned to see my new build that I started last night.
Much the same, just a bit bigger, and faster, and more powerful.
Thanks for all the help and support. I’m probably going to need it for the next one as well.
Cheers
  • abdulasis12
  • abdulasis12
20 Dec 2024 10:03
Skew correction/perpendicularity correction (millkins or millkins_xyz)
Category: Basic Configuration
You would need to add the 'skew-y' pin and the corrective terms to the forward and inverse kinematic models of the xyzac-trt kins.
This I understand.
This is hard for me , not understand.
Now I open .hal of xyzbc and i add
loadrt skewkins
before line
loadrt xyzbc-trt-kins sparm=identityfirst
try to run linuxcnc and error  :
<commandline>:0: Pin 'motion.switchkins-type' does not exist
INI file HAL command net :kinstype-select <= motion.analog-out-03 => motion.switchkins-type failed.
Could you please guide me? I am ready to learn it
Thank you,
Asis
  • Cong
  • Cong
20 Dec 2024 09:03
How to build linuxcnc on buildroot?
I need to build linuxcnc in buildroot, is there any reference document?
  • Aciera
  • Aciera's Avatar
20 Dec 2024 08:53
Replied by Aciera on topic Fast Hole EDM from Hacked Parts
1. This makes no sense in your custom mcode as the file needs to be executable in the first place
chmod +x M101
2. comment out those 3 lines in your hal file, start your config and use the 'show halconfiguration' tool to check for the correct pin descriptor.
  • CaspianCmonster
  • CaspianCmonster
20 Dec 2024 08:30
Replied by CaspianCmonster on topic Should I update
Should I update
Good to hear, now I can focus on using the machine rather than figuring out a configuration I setup five or six years ago :)
  • Aciera
  • Aciera's Avatar
20 Dec 2024 08:30
  • Hakan
  • Hakan
20 Dec 2024 08:25
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I wonder what Grotius did that can have such implications. After all it wasn't long ago we used to download and compile the ethercat master ourselves when we needed it.
Anyways, I have installed ethercat from repositories a few times the last few months and always ran into this with the signing and expired key. And the last time on 2.9.3 iso the ecat.sh didn't solve it. Can we have a pointer in the first sticky to the third sticky? I had a hard time finding the ecat.sh script to start with.
The ecat.sh script, admittedly I may have screwed some things up, did add a duplicate entry in /etc/apt/sources.d. The original was call ScienceLab-something. I removed that one. Then there was the question of where the new downloaded key went. Kind if forgotten the details but there became duplicate keys and one had to be removed.
In the end I wonder if it isn't easier to just remove the signed-by entry in the sources file. So now I only have this in the igvh.sources file
Types: deb
Suites: ./
URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/
  • Mr. Mass
  • Mr. Mass's Avatar
20 Dec 2024 07:05
Replied by Mr. Mass on topic CNC machine B64-S-ATC
Category: CNC Machines
Moving forward a bit, this time the Z-axis.
The profile turned out to be bent, I had to level the plane for the rails.
When machining, some of the clearances were very tight.
But it went well, plus another part ready to go.
  • timo
  • timo
20 Dec 2024 06:08
Some new Linux CNC board by Bigtreetech looks cool still trying to get more info
I could not locate the video, you are refering to.
"Trying to get more info" and ending up having to create it, I personally would shy away from.
  • Tchefter
  • Tchefter's Avatar
20 Dec 2024 05:04
Replied by Tchefter on topic Linux CNC auf Virtualbox Simulation
Category: Deutsch
axis_mm.ini sagt mir nichts.
Seine Maschine muss dann wohl "axis_mm" heißen, da i.d.R. die "ini" nach dem Namen der Maschinen benannt wird, wie auch die "hal" usw.
20 Dec 2024 04:54
Actually I doubtful of the Linuxcnc compatibility, and unless they come up with a driver..
Also I don't see any Linuxcnc compatible interfaces, personally I wouldn't trust wifi for running a cnc machine based on the Linuxcnc model. Maybe CAN or SPI but that would limit the choices of the computer platform.
  • abdulasis12
  • abdulasis12
20 Dec 2024 04:51
Hi
I have question.I would like to know if I can use skewkins together with xyzac-trt-kins. If it is possible to use them together, what steps do I need to take? Please provide me with some guidance.
Thank you,
Asis
  • IronManDylan
  • IronManDylan
20 Dec 2024 04:28
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
So I spent the rest of the day trying to figure out how to get a gcode command to turn a relay on and off using the output pin from the mesa 7i96s.  The relay controls the pumps and it needs to be turned on before I start EDMing.  I think getting a simple relay to work before trying to mess with a PID loop is best. I am not sure if it is relevant but the pin is TB3 pin 14 based on the mesa 7i96s manual.
I believe what I need to do is have a user defined mcode (this allows me to easily turn the pumps on and off and I can also modify my gcode post processor to turn this off and on after I output any drilling operations).  The name of the file is M101. I will also write a M102 to turn the pumps off once I get this first one working. And btw this is just placed in the main folder that is this machine.  Here is what is in the M101 file:
#!/bin/bash
halcmd setp motion.digital-out-00 true
chmod +x M101
exit 0
I am also trying to modify the .hal file to actually call up the mcode command. Here is what I have in the .hal file:
setp hm2_7i96.0.output.00 true
net edm-pump-output <= motion.digital-out-00
net edm-pump-output => hm2_7i96.0.output.00 true
Something is not right though because I am getting the debug error "paramater or pin 'hm2_7i96.0.output.00' not found" and the machine won't boot up (I did get it to boot up after flashing though).
I am going to look at this with fresh eyes in the morning.  But this is not an area I am proficient in and I am not finding a webpage that clearly lays out the syntax.  I get that the pin needs to be set, and then connected.  But I really do not know how to do that.  So if someone would be willing to point out what I have wrong I would really really appreciate it.
Thank you.
Best,
-Dylan
Displaying 21511 - 21525 out of 21851 results.
Time to create page: 0.458 seconds
