08 Dec 2024 18:46
Replied by tommylight on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
Yeah, i wasted 20 minutes last night looking for it, but all i could find was some very short videos of it, so either my serach-foo is failing me or google has gone completely off the rails. I am rooting for the latter:)
08 Dec 2024 18:42
Replied by tommylight on topic Kuka robot project - hardware choice
Category: Driver Boards
In Europe you can get toroidal transformes for any secondary voltage, that is the easy part, the 5.4A rating is most probably the long term current the motor can withstand, peak current will be much higher so the drives are usually 20A or 30A rated, hence the power supply must be rated accordingly, in your case at a guess at least 60A transformer and rectifier. Or have 2 of the big motors on one power supply and 4 smaller on another power supply, at 30A to 40A each are easier to manage and find and might even be cheaper. You might easily make do with much less as it is a small weight, and use moderate accelerations.
Does the control box have power info on it? Should be in KW,
  • Aciera
  • Aciera's Avatar
08 Dec 2024 18:41
Replied by Aciera on topic Video Editors
Video Editors
spam removed
  • Aciera
  • Aciera's Avatar
08 Dec 2024 18:39
Replied by Aciera on topic User Signatur
User Signatur
Category: Forum Questions
Spam removed
  • slowpoke
  • slowpoke
08 Dec 2024 18:27
Replied by slowpoke on topic Lathe Macros
Lathe Macros
I had the link for that one. Perhaps I wandered off this thread when I found it. It was a compilation of I think all of the macros showing the actual operation on a lathe much like the video you referenced, just for all the different operations quite a good video, no idea where I found it and can't seem to find it.
  • gardenweazel
  • gardenweazel's Avatar
08 Dec 2024 18:06
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
I am certainly willing to test it.
I would suggest that we either fix VersaProbe or remove it completely from the project as it's really annoying to not have this working
as expected.
I can also move over to Basic Probe but I'd need some of the documents cleaned up as to what is to actually happen for each
button/control. Some controls are documented but, other controls as well as their functionality are not.
I'd be more than happy to work with you and even document the process for the project(Linuxcnc).
Send me some ideas and I can act on them.
  • RotarySMP
  • RotarySMP's Avatar
08 Dec 2024 17:41
Replied by RotarySMP on topic Retrofitting a 1986 Maho 400E
Category: Milling Machines
Thanks for that David, I have been pretty busy this week.
  • greg23_78
  • greg23_78
08 Dec 2024 17:39
Replied by greg23_78 on topic Kuka robot project - hardware choice
ok, so the 160 V on your website corresponds to a peak voltage?
For the input voltage, for reasons of economy, a DC power supply to manage the 6 motors is likely to be expensive.
What's more, being in Europe, I have to manage with 240/400 volts. It's easier to find an auto-transformer to output 110V and add a 3-phase bridge rectifier with capacitor.
is it possible to supply your amps with RMS voltage?
for resolvers, is there a way to manage robot position data with batteries (like kuka) without continuously powering the computer with linuxcnc open? because manually homing robot axes could take a long time ...
  • abdulasis12
  • abdulasis12
08 Dec 2024 17:34
Feedback control XY not full speed run G1 when curve or Arc
Hi, MR.ACIERA  MR. TOMMY
Thank you for reply and sorry in weekend slow reply.
This below post file gcode problem.
example about in gcode file at N15 to N3900
**Also, what acceleration is set in the ini file?**
Tomorow at workshop I will check and told again.
Thank you
Asis,
File Name: 1001.ngc
File Size:648 KB
  • JackRay
  • JackRay
08 Dec 2024 17:19
Retrofit of 2 Messer Cortina DS Plasma cutting machines
Category: Show Your Stuff
Hello everyone,
first of all I don't know if I'm in the right place in the frum, but if I need to move my message please let me know.
Like you, I am in the process of retrofitting my 5-axis CNC type XYZBC.
In fact, having important torque reducers on the B&C axes I want to add encoders directly on these two axes. For this, I have started to buy a 7i96s where only one encoder is available but a daughter board can be added like a 7I85.
I've started to connect the system under linuxcnc 2.9.3, and I can't synchronize the scale between the Axis display and the actual position of my encoder.
my encoder is 1000 pulses/hole in quadrature, which gives 4000 pulses per revolution. With variables SCALE_ENCODEUR = 11.11 I manage to synchronize the display & the actual position of my axis; unfortunately my “joint” doesn't follow; I need at least a value of 3000 pulses/hole to no longer have this “joint tracking error”. And even with this value, the motor remains very reactive to the slightest movement of my encoder. Of course, the display no longer corresponds (since there's only the value of 11.11 to synchronize the display and the position of my axis).
I've been struggling for two months just to get this setting right.
Does anyone have an idea for my problem?
Thanks in advance for your help
  • hans48
  • hans48
08 Dec 2024 15:56
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo liebe Linux cnc Gemeinde
Ich habe es doch nicht aufgegeben und weitergemacht. Alle Achsen Bewegen sich, aber das hat Zeit gebraucht. Jetzt muss ich noch den Not-Aus machen, da habe ich ja schon Informationen. Das mit den Endschalter hat sich auch erledigt. Ich wußte nicht das man den Weg vorgeben kann somit Stopt die Achse ja nach erreichten Weg. Vorige Woche habe ich den Bildschirm montiert eine Schnurlose Tatatur und Maus Installiert damit nicht soviel Kabel sind.
Ich möchte die Grafig ändernund zwar die Jog - Tasten X - Achse ist Horizetal angeordnet un Y - Achse Vertikal die möchte ich tauschen wenn das nicht all zu schwierig ist. So das war es wieder mal.
Gruß Hans
08 Dec 2024 15:55
Replied by tommylight on topic Accuracy
Accuracy
Category: Configuration Tools
Most probably missing G64 P0.1 or whatever the tolerance should be, notice the white line still visible in the preview.
G64 Pnn should be in the gcode file.
  • PCW
  • PCW's Avatar
08 Dec 2024 15:43
Replied by PCW on topic Accuracy
Accuracy
What type of motion hardware do you have?
  • meister
  • meister
08 Dec 2024 15:03
if you using the makefile, all should work with the gowin enviroment (WLED/1.8V).
pin 10 in one of the LED's on the Tangnano9k and the blink plugin is only to show that the gateware is flashed and running
Displaying 22021 - 22035 out of 22095 results.
Time to create page: 0.416 seconds
