23 Oct 2024 10:57
Replied by tommylight on topic How to put the 7i77 encoder in mode 1?
Category: HAL Examples
In the hal file, the loadrt line containing Mesa IP address, the number of encoders is set to 1, should be set to 8 i think, see your other topic already replied by PCW.
Then you would have to also change the encoder number, most probably from encoder.00 to encoder.06 for every entry of that encoder.
23 Oct 2024 10:48
Replied by tommylight on topic Double / twin scara robot
Scara is a certain type of robot arm, usually with 4 or 5 joints/axis, not a foam cutter.
Yes, it can do indepent axis foam cutter, i have made several of them, and it can have configurations for 2 axis with 4 joints or tandem and a configuration for independent 4 axis, even 5 is you want to add a rotary table.
Some examples
www.google.com/search?q=foam%20cutter%20...%20cutter%20linuxcnc
  • gitano
  • gitano
23 Oct 2024 10:47 - 23 Oct 2024 11:11
...just discovered this a few days ago and i am really impressed! Really nice work, also with the configuration wizard in the docker container!
Just stepped inside the LinuxCNC world with a rudimentary BOB setup, so maybe a bit early... but i am really considering having a look at this :)
Cheers!
-lgitano
  • Stanislavz
  • Stanislavz
23 Oct 2024 10:28
Double / twin scara robot was created by Stanislavz
Hello. Is it possible to configure linuxcnc for two scara x/y and u/z axis from same controller ? Ie - i would like to make a cnc foam cutter, and have independednt sides controlled from same controller for tapered cuts. .
  • phillc54
  • phillc54's Avatar
23 Oct 2024 10:16
Replied by phillc54 on topic Update failure
Update failure
Category: Plasmac
There should be three of encoder A, numbered 0, 1, and 2. Click the arrow next to the encoder you want for arc voltage.
If you are using an encoder for ohmic comp you need to do that manually after PnCconf has completed, the default ohmic sensing for QtPlasmaC is done using a solid state relay rather than a THCAD.
Warning: Spoiler!
  • freemoore
  • freemoore
23 Oct 2024 09:50
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
When would suit you?
  • zack
  • zack's Avatar
23 Oct 2024 09:38
Replied by zack on topic 10" 1024 x 600 display with touchscreen
Category: Basic Configuration
This version supports touch screens
  • daveyr
  • daveyr
23 Oct 2024 09:18
Replied by daveyr on topic Probe Basic Contour ShuttlExpress
Category: QtPyVCP
Not sure if it is to late but here is the Hal file that i used for my shuttle.
As a warning every now and then i would get a run away when using the outer jog wheel thing where it would just go all the way on the axis. As a result i mainly used the jog wheel in the middle and have now transitioned to a normal pendant using a 7i73 for stepping.
To make it work all you should have to do is include the HALFILE in your .ini
#Shuttle Pendant
HALFILE = shuttle.hal
  • Aciera
  • Aciera's Avatar
23 Oct 2024 09:08
Machine moves when you stop program in the middle
Looks fine
If is was something like on abort, shouldn't it do it all the time? I mean like for any program?
Well, yes but since this is an obscure problem it is not likely just related to your hal and ini files.
I think I need to try and revert back to before trying to install easy probe.
Indeed, the easiest would be if you had made a copy of your machine config folder before trying to do the install.
  • btvpimill
  • btvpimill
23 Oct 2024 08:53
I found it finally. I don't see anything in it but here it is. I hope you do. I think I need to try and revert back to before trying to install easy probe.
1- I was unsuccessful in the install (didn't try very hard)
2- not using it since I was unsuccessful
3- never experienced anything like this over the last 12 years or so since finding EMC
  • Guytou
  • Guytou
23 Oct 2024 08:43
Replied by Guytou on topic 10" 1024 x 600 display with touchscreen
Thanks for the tips.
Does Axis support touch screens ?
I was thinking using Gmocappy.
  • tray
  • tray
23 Oct 2024 08:17
Replied by tray on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
Yeah, sorry I'm at a loss also.
I was thinking of getting linux mint and installing Linuxcnc on that.
After all this is a fresh install I am attempting to install the mesact on.
  • zmrdko
  • zmrdko's Avatar
23 Oct 2024 08:13
Replied by zmrdko on topic Probe Basic Buttons Missing
Category: QtPyVCP
can you verify, if it shows the same in the sim config?
  • Popo
  • Popo
23 Oct 2024 07:38
Allen Bradley motors and drives was created by Popo
Looking for some advice on a build.  This is what I have.  Would this work?
2 - Allen Bradley N-3412-2 motors.
2 - Allen Bradley MPL-A310-MK22AA
3 - Allen Bradley Ultra 3000 drivers
I also have several Allen Bradley Logix 5561, logic 5550, and other hardware
Do I need Allen Bradley software to run the motors?
I have. A lot of experience with CNC routers and computers. I am a novice when it comes to programming but I am willing to learn.
I am looking to build a 4x4 CNC with a spindle.
  • zmrdko
  • zmrdko's Avatar
23 Oct 2024 07:26
Replied by zmrdko on topic Start / resume button challenges
Category: QtPyVCP
RE: custom_postgui.hal:67: Pin 'halui.program.is-idle' was already linked to signal 'prog-running'
try replacing:
net my-start-resume-button-in2 and2.pause-resume-0.in1 <= halui.program.is-idle
with:
net prog-running my-start-resume-button-in2 and2.pause-resume-0.in1
Displaying 22426 - 22440 out of 22607 results.
Time to create page: 0.437 seconds
