03 May 2026 05:03
ATC lathe - Clasic Ladder, Stream Deck, Remap M6 My setup
Djakuju bardzo.
Should be "thank you very much" in Polish language, is that correct?
03 May 2026 05:01
Replied by tommylight on topic Gibbscam Post Processor
Did you check if it has a post fro EMC2 as that was the old name for LinuxCNC?
Post processors should be fairly easy to edit/modify, so you can give that a try.
03 May 2026 04:56
Replied by tommylight on topic spinbox problem
spinbox problem
Category: pyVCP
Google translation:
I just upgraded my mortiser from Linux 2.5.4 to 2.9.5, but the problem is that Spinbox signals are no longer working. I read that there was a change in Python, I tried several Python scripts and changed Post-GUI Halfile, but nothing changed. Can you help me?
What is the exact error you get?
  • andrax
  • andrax's Avatar
03 May 2026 04:51
Sanitycheck my plan: ethercat + stepperonline A6
Category: EtherCAT
How did you manage to connect to the drives?I’ve installed the software, but I can’t get a connection
  • PCW
  • PCW's Avatar
03 May 2026 04:46
Firmware request: 7i95T with 4 PWM generators on P1
Category: Driver Boards
7I95T firmware with 6 PWMs on P1
(If you need just 4, use num_pwmgens=4 in the driver command line)
File Name: 7i95t_p1_6pwmd.zip
File Size:295 KB
  • Accipiter
  • Accipiter
02 May 2026 23:58
Replied by Accipiter on topic MESA card (LAN) failing to connect.
Thank you. Will try to pursue your suggestions tomorrow.
  • ffffrf
  • ffffrf
02 May 2026 23:51
How complex would this DIY Swiss style lathe conversion be to set up hal/ini?
I definitely hear you on the stock waste and that may be a good reason to increase my guide bushing axis to be 18 inches, however, I have a method where the actual full headstock length will not be all waste, based on how my stock will insert into the drive servo, I will get about 40% of the tag 5c headstock as usable stock, so knocking it out from 5 inches to around 3 inches.
So you are saying that with a traveling steady rest and gang tooling, I should be able to have every lathe side cutting tools (ignoring drills and boring bars for now) be able to cut right at the entrance of the bushing? I am trying to imagine this. If it is possible, in that case, during a tool change, I just need the guide bushing axis to retract the stock all the way back, and only then cause the cross slide to move to the new tool location, then the stock pops back out of the bushing and cutting proceeds? I need each lathe tool to have its cutting edge right at guide bushing entrance.
My issue is with each tool holder, your actual cutting edges will not all line up, for example, I dont want my 55 degree side cutter to be cutting right at the bushing, but my parting tool has to cut 5mm beyond the bushing just based on where the cutting edges line up in my taig tool holders.
Also, if I add a Y axis and live tooling, in that case would you recommend the W axis?
  • TheTinkeringMechanic1
02 May 2026 22:33 - 02 May 2026 22:54
Replied by TheTinkeringMechanic1 on topic Can't read gcode text in dark mode when editing.
Category: Gmoccapy
How do I tell what one it is?
  • rodw
  • rodw's Avatar
02 May 2026 22:00
Replied by rodw on topic HAL component for tangential knife
Category: HAL
Finally, I have sent a PR to Linuxcnc on Github for this
github.com/LinuxCNC/linuxcnc/pull/3995
It was a lot harder than I thought. Many thanks to grandixximo for his help ensuring all the runtime tests passed.
  • zbeeru
  • zbeeru
02 May 2026 21:43
Yes, I need DIR signals. I don' have a preference for pinout.
  • HansU
  • HansU's Avatar
02 May 2026 21:41
Category: Gmoccapy
We can only help you if you tell us which GUI do you use.
  • fer662
  • fer662
02 May 2026 21:17 - 02 May 2026 21:18
Category: EtherCAT
Update:
I've got a draft electronics panel with all the ethercat stuff working with linuxCNC, including the servos which i'm able to jog around, which is a great start! it'll be a while until they are mounted physically on the machine, but i want to get started better understanding the process of tuning them, specially since i'm basically blocked from continuing with the physical part of the build until a few more things arrive.
I was able to get the stepperonline software running on a windows 10 vm within qemu and perform the inertia autotune part( which i'll obviously have to do again when they are really mounted ). I understand after that comes a manual part in which you tune the gain along with other stuff, basically testing movements and see what minimizes the error, but i've no idea about how this is done concretely, like what steps in which pieces of software, and specially how it is done for the 2 motors that share an axis.
  • PCW
  • PCW's Avatar
02 May 2026 20:05
Replied by PCW on topic MESA card (LAN) failing to connect.
local host should always be 127.0.0.1/8
Don't change that.
You either need to figure out the issue with the  setting up a static IP address
with the network manager or edit the interfaces file as described in the
hm2_eth manual page.
googling debian setup static ip address
will give some more options.
  • Accipiter
  • Accipiter
02 May 2026 19:54
I then went to /etc/hosts and changed the local host to 10.10.10.100/24 which it accepted, then went to ping 10.10.10.10 and got the so far standard response 5 packets transmitted, 0 received
Displaying 2446 - 2460 out of 13999 results.
Time to create page: 0.253 seconds
