  • Jaragua
  • Jaragua
15 Mar 2026 23:50
Também estou com o mesmo problema.aparentemente precisa editar o arquivo .hal no LinuxCNC. Conseguiu resolver?
  • PCW
  • PCW's Avatar
15 Mar 2026 23:43
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
This section of the hal file is broken in at least 3 ways:
#loadrt [KINS]KINEMATICS
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_stepgens=4 sserial_port_0=2"
#loadrt hostmot2
1. loadrt [KINS]KINEMATICS is commented out
2. loadrt hostmot2 is commented out
3. loadrt hostmot2 is in the wrong order (it must be loaded before hm2_eth)
It should look like what pncconf creates:
loadrt hostmot2
  • rock861261
  • rock861261
15 Mar 2026 23:04
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
is it possible to set it up as a output to a 5v input? I can trigger it that way?
  • grandixximo
  • grandixximo's Avatar
15 Mar 2026 22:07 - 15 Mar 2026 22:10
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
@andrax
Sittner's repository does  not support
syncToRefClock
If you want to test Sascha Ittner's code with pll
Set
refClockSyncCycles="-1"
My code is a different repo
github.com/grandixximo/linuxcnc-ethercat
Sasha's code is missing some drivers, he has done a huge rework, he also removed the grind, but used another method, I am still undecided on how to merge his code properly.
  • georgio
  • georgio
15 Mar 2026 21:37
Hello all,
I am a newbie and I might have posted this question on the wrong thread before so I apologize for my lack of knowledge and experience. I have got my board and pc communicatiing and I think I have fixed most of the error but until i get this one fixed I won't know. I have an error which seems to be misidentifiying my z axis. I have a xyyx router setup hopefully to get y  squaring. The error I am getting says an undefined kinematicsSwitch and it leaves my setup with undefined limit on z. All help will be greatly appreciated. I will post my ini and hal files for you to look at.
Thanks again,
George
  • georgio
  • georgio
15 Mar 2026 21:12
Replied by georgio on topic MESA 7i76eu Firmware
Category: Driver Boards
File Name: georges_router.hal
File Size:18 KB
File Size:18 KB
File Name: georges_router.ini
File Size:5 KB
File Size:5 KB
Thank you for for your assistance, i VERY MUCH appreciate it.I am having problems with my hal files and my ini files no matter what i do i keep getting the same error message kinematisSwitch not defined. If I could get you look at my ini and hal files I would be eternally gratful. I have got past the communication errors and my pc is able to communicate with the 7i76eu I think I have most errors fixed now but unitl I get this current error out of the way I don't know if ther are anymore. I am not sure if this is the right place to ask, so please excuse my inexperience. Thannks again
George
  • Atsu
  • Atsu
15 Mar 2026 17:11
Replied by Atsu on topic Ethercat random jitter fix
Category: EtherCAT
@TAKUYA
@Atsu
please check the value of the parameters lcec.0.pll-step
You can do so with this command
halcmd show param lcec.0.pll-step
This parameter will be set at 1000 automatically if you have RTAPI_TASK_PLL_SUPPORT
also I have updated again the repo
if you could be so kind as to download, build and test again, thank you
Thank you! I pulled the latest changes and can confirm that it is now working. The dc-phased pin turns true, and I can see the pll- pins getting values other than zero. I did couple restarts and so far there is no grinding noise. I will continue testing to see if its gone for good.
  • fery15sty
  • fery15sty
15 Mar 2026 16:59
buildbot.linuxcnc.org is not active, how install linuxcnc 2.10 in debian buster
I've checked the site buildbot.linuxcnc.org/ again. It's back up and running. A while ago, the site was showing an error and couldn't be opened. The inactivity is probably temporary.
Thank you all for your responses.
  • TAKUYA
  • TAKUYA
15 Mar 2026 16:22
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
you are missing the go package.
"sudo apt-get install golang"
then "make" and "sudo make install"
  • Marcos DC
  • Marcos DC's Avatar
15 Mar 2026 15:47
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
Small progress update: the stub has basically turned into a virtual drive backend for validation.
I’m already exercising a fair amount of the core CiA402 runtime behavior in AXIS SIM with it.
Still a lot left to test before going back to real EtherCAT hardware, but the direction looks good.
  • dbtayl
  • dbtayl
15 Mar 2026 15:12
Replied by dbtayl on topic Inaccurate milling - what could it be?
Category: Basic Configuration
You might also want to mention what tools/holders, speeds, and feeds you're using, as well as how far off the dimensions are.
That said, my first reaction to the above is deflection- the gouge looks like where the tool ended the cut, possibly dwelled there a bit before/during retract, giving it more time to cut. If it is deflection, there's a good chance you'll feel ridges if you run a fingernail along the floor of the machined surface perpendicular to the direction of cut.
Adding a finishing cut might be all you need- I generally leave 0.1~0.2mm of stock during roughing operations for the finishing cut(s).
Generally increasing rigidity should help as well (shorter tools/toolholders/stickout, bigger tools, better worktholding, working closer to the table), but I've always thought the columns on benchtop mills look too small, so you may be limited in options if that's the root cause. The good news is that so long as it cuts OK, taking a light finish cut should still get you on dimension.
15 Mar 2026 14:58
@RodW,
Is the "user exchange" section just for that kind of stuff?
You could have mentioned here you have a paid solution and posted a link to "user exchange" section, as i do not think that is just for parts nor am i aware it excludes services, but i am not sure.
@Others,
Would that be OK?
  • andrax
  • andrax's Avatar
15 Mar 2026 14:55 - 15 Mar 2026 15:19
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
I just updated LinuxCNC via the package manager.
When I set `syncToRefClock=“true”`, I still get the error `lcec_conf: ERROR: Invalid master attribute syncToRefClock`.
I've now downloaded the EtherCAT master from GitHub.
When I run `make`, I get the following errors:
devices/lcec_ep9214.c: In function ‘lcec_ep9214_write’:
devices/lcec_ep9214.c:206:23: warning: unused variable ‘hal_data’ [-Wunused-variable]
  206 |   lcec_ep9214_data_t *hal_data = (lcec_ep9214_data_t *)slave->hal_data;
devices/lcec_ep9214.c:205:12: warning: unused variable ‘pd’ [-Wunused-variable]
  205 |   uint8_t *pd = slave->master->process_data;
[code]Linking lcec.so
ld -d -r -o lcec.so.tmp lcec_main.o lcec_devicelist.o lcec_ethercat.o lcec_pins.o lcec_lookup.o lcec_modparam.o lcec_malloc.o
objcopy -j .rtapi_export -O binary lcec.so.tmp lcec.so.sym
(echo '{ global : '; tr -s '\0' < lcec.so.sym | xargs -r0 printf '%s;\n' | grep .; echo 'local : * ; };') > lcec.so.ver
gcc -shared -Bsymbolic -Wl,-rpath,/lib -Wl,--version-script,lcec.so.ver -o lcec.so lcec_main.o lcec_devicelist.o lcec_ethercat.o lcec_pins.o lcec_lookup.o lcec_modparam.o lcec_malloc.o -lm -Wl,--whole-archive liblcecdevices.a -Wl,--no-whole-archive -L/lib -llinuxcnchal -lethercat -lrt
chmod -x lcec.so
Compiling realtime lcec_conf.c
Compiling realtime lcec_conf_icmds.c
Compiling realtime lcec_conf_util.c
gcc -o lcec_conf lcec_conf.o lcec_conf_icmds.o lcec_conf_util.o lcec_devicelist.o lcec_ethercat.o lcec_pins.o lcec_lookup.o lcec_modparam.o lcec_malloc.o -Wl,-rpath,/lib -L/lib -llinuxcnchal -lexpat -Wl,--whole-archive liblcecdevices.a -Wl,--no-whole-archive -lethercat -lm
Compiling realtime lcec_devices.c
gcc -o lcec_devices lcec_devices.o lcec_devicelist.o lcec_ethercat.o lcec_pins.o lcec_lookup.o lcec_modparam.o lcec_malloc.o -Wl,-rpath,/lib -L/lib -llinuxcnchal -lexpat -Wl,--whole-archive liblcecdevices.a -Wl,--no-whole-archive -lethercat -lm
(cd configgen ; go build devicelist.go)
/bin/sh: 1: go: not found
make[1]: *** [Makefile:118: configgen/devicelist] Fehler 127
make[1]: Verzeichnis „/home/ich/Downloads/linuxcnc-ethercat-master/src“ wird verlassen
make: *** [Makefile:4: build] Fehler 2
[/code]
Edit:
I've used Git now.
git clone github.com/sittner/linuxcnc-ethercat.git
There were no errors this time,
but the syncToRefClock=“true” still doesn't work.
  • Aciera
  • Aciera's Avatar
15 Mar 2026 14:38
@rodw
Not sure what to think of this. I don't have a problem with you providing paid support for linuxcnc but please do not (ab)use your posts on this forum for blatant advertisement.
Thank you.
  • hmnijp
  • hmnijp
15 Mar 2026 14:24
Replied by hmnijp on topic Again about HOME_INDEX in step/dir mode
Category: StepConf Wizard
 Does it mean that in the firmware the encoder index is untied from the counter?
I will try to implement this using the GPT chat
A quick note to make it easier to find:
Instead of
“hm2_board.0.encoder.1.index-enable”
Use
“hm2_board.0.stepgen.1.index-enable”
Displaying 4141 - 4155 out of 14025 results.
Time to create page: 0.296 seconds
