  • romanetz
  • romanetz
14 Oct 2026 04:17
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Category: Driver Boards
Update: PREOP reached, full SII EEPROM interface workingQuick update on the Colorlight 5A-75E EtherCAT slave.Since my last post, quite a bit has moved:What works now:
  • SII EEPROM emulation fully implemented and verified with IgH master
  • ethercat slaves -v
    reads identity correctly:
    • Vendor Id:
      0xDEADBABE
      , Product code:
      0x00C0FFEE
    • All SII categories parsed: STRINGS, GENERAL, FMMU, SYNCM
  • AL state machine:
    INIT → PREOP
  • IgH configures SM0/SM1 and accepts the slave in PREOP
Current limitation:
CoE mailbox is not implemented on the FPGA side yet, so IgH fails on
CoE SDO upload (
0x1C12
PDO assign) and never reaches SAFEOP/OP.Next steps:
  • Remove CoE declaration from ESI to bypass mailbox requirement for
    Phase 1 (bring-up with LinuxCNC and quadrature encoders)
  • Then decide: implement mailbox via VexRiscv + SOES (Phase 2), or
    keep CoE-free with PDO mapping from ESI
Repository:
github.com/romanetz/liteethercat Architecture and roadmap:
docs/architecture.md
in the repo.The project continues the same modular LiteX approach. Once the slave
is in OP and HAL pins react to encoder movement, I'll post a video.
  • Shu
  • Shu's Avatar
14 Oct 2026 03:14
Replied by Shu on topic A6 1000w troubles.
A6 1000w troubles.
Category: EtherCAT
your machine enable signal is probably not passed to the drive? is the drive in op mode at all? check with 'ethercat slaves' in a terminal. and post your full config with ini, hal, and ethercat xml
  • Shu
  • Shu's Avatar
14 Oct 2026 03:09
Replied by Shu on topic Hermle auswahl Mesa Karten
Category: Deutsch
moin gerald,
für mehr infos solltest du die genauen kompletten bezeichnungen von den servo drives erwähnen. und mach dir doch mal eine tabelle mit allen benötigten inputs/outputs, dann weisst du auch was du an mesa hardware brauchst, also wie viele pins und was für welche. wenn du die genaue bezeichnung von den servo drives hast, kann jemand auch mehr zur anbindung sagen.
ich wette schonmal einen kasten koffeinhaltiges kaltgetränk, dass du die servos drives nicht über ethernet anbinden kannst :-D die haben vielleicht ein paar rj45 ports für einen bus wie modbus, ethercat etc. aber kein ethernet.
  • anfänger
  • anfänger's Avatar
14 Oct 2026 02:10 - 14 Oct 2026 16:27
Replied by anfänger on topic calling all probe basic lathe users!
Category: QtPyVCP
sounds great. If not open source is it still free? Or at least pretty affordable once its finished.
the next two evenings I wanted to work in the lathe UI anyway to clean up my bash codes zu python the rest ist done. I could implement it and test it on the weekend. I have some lathe work coming which would be perfect to test.
  • Hermle_Gerald
  • Hermle_Gerald
14 Oct 2026 01:55
Replied by Hermle_Gerald on topic Hermle auswahl Mesa Karten
Category: Deutsch
Ich hätte auch die Möglichkeit die Servos Drives über Ethernet anzuschließen.
  • Shu
  • Shu's Avatar
14 Oct 2026 01:55
Category: Deutsch
für die GMS brauchst du dann wahrscheinlich ein Heidenhain EXE TTL Konverter.
Die JASD AC Servos haben step/dir input, ja. Vielleicht übersehe ich was, aber eine 7i77 hätte einen Encodereingang pro Achse, damit sparst du dir die 7i85, wenn du die Servos eh mit step/dir anbinden möchtest, und die Encodereingänge von der 7i77 sind dann für die GMS.
  • Hermle_Gerald
  • Hermle_Gerald
14 Oct 2026 01:27
Category: Deutsch
Danke für die Antwort.
Die Frässpindel ist ein 3kw 400V Motor diesen möchte ich mit einem Fu ansteuern. Verbindung Fu - Mesa 24V Rechts/Links und 0-10V.
Was den Anschluss vom Servo-drives betrifft. Habe ich momentan noch keine Ahnung. Es sind Jasd Ac Servo mit 230V. Am Cn 1 Port sind gefühlt 50 Pins.
In der Beschreibung von der Mesa 7i76Eu steht. Man kann bis zu 5 Achsen Step/Dir-Schrittmotor- oder Servoantrieben anschliesen.
Die Heidenhain Messtäbe sind LS 803 die allerdings kein TTL Signal ausgeben. Ich dacht ich habe mal wo gelesen das mit der 7i85 das funktionieren sollte?
  • Lcvette
  • Lcvette's Avatar
13 Oct 2026 15:40
Replied by Lcvette on topic calling all probe basic lathe users!
Category: QtPyVCP
the new lathe conversational is incredible it is nothing like either in the stock ui's completely stand alone with built in safety checks tool fitment, built in threads and thread classes, motion simulation with stock, parameter operation builder.. its like full cam pretty much. it is an add on not open source.
  • anfänger
  • anfänger's Avatar
13 Oct 2026 15:28
Category: QtPyVCP
Yes I will give it a try on the Weekend., but let ne finish my changes first. I might have found a way to use the jog increments from the gui for my encoders.
Are the new ones more Like the Mill Version and create gcode? I think this was the goal all along when I started my First attempts to integrate the existing lathe macros.
  • 5_Zylinder
  • 5_Zylinder
13 Oct 2026 15:09
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
Hi everyone,
after a lot of back-and-forth—and some inexperience on my part—I’ve finally got the tool changer up and running. Many thanks for your help. Now just a few optimizations remain, but the bulk of the work is done. Next up are the 4th axis, the central lubrication system, and the spindle oil cooler.
youtube.com/shorts/3rU7JE1qDNo
  • Lcvette
  • Lcvette's Avatar
13 Oct 2026 12:32
Category: QtPyVCP
anfanger, would you like to beta test the new conversational? it is far superior to the existing macros based version, very powerful, pretty much can run the lathe with no cam software .. let me know!
  • jazzkramer
  • jazzkramer
13 Oct 2026 11:20
Replied by jazzkramer on topic Is this a bug?
Is this a bug?
Category: Plasmac
Thanks FabLabRacing,
I upgraded to last version (reinstalled all from new downloaded iso) and, after copying the old config directory, it's now working without that :)
Thanks, have a nice day,
Alberto.
  • Japoo_Ness
  • Japoo_Ness
13 Oct 2026 09:26
Retrofitting a 3-axis VMC with DC servos - guidance needed
I found it. I used the 7i97T_7i74d2.bin and this one doesn't have PWM in version 1, they are in 0. If I understand correctly, I can use 7i97T_7i74d.bin since they are functionally equal, and plus, this one does have PWM version 1
  • PCW
  • PCW's Avatar
13 Oct 2026 09:22
Replied by PCW on topic stepper motor does not move
Those errors are due to host network latency issues and this must be solved before proceeding.
You do not need to change any firmware unless you need to support an added parallel
daughtercard or add a feature like Modbus support or step/dir homing to index.
To get a rough idea where you are network latency wise, run this command:
sudo chrt 99 ping -i .001 -q -c 60000 [card_ip_address]
Where [card_ip_address] is either 192.168.1.121 or 10.10.10.10 depending on 7I95T jumpering.
The command will run for 1 minute and then print timing statistics,   please post the result here.
Also, what is the host hardware?
Displaying 421 - 435 out of 11392 results.
Time to create page: 0.153 seconds
