  • markbaenen
  • markbaenen
09 Feb 2026 14:25
Replied by markbaenen on topic Configuration Problems 7i92 PnCConf
Category: PnCConf Wizard
So you are saying that if everything on the config page says "unused", it will still work?
09 Feb 2026 14:14
Servo Wiring and Tuning detailed How To example Mesa 7i77.
Remove the dots after the 0 for I and D.
From video, definitely something wrong, but no idea what, that is not normal oscillation as it is moving way to much back and forth.
Do some plots using halscope for command and f-error
  • my1987toyota
  • my1987toyota's Avatar
09 Feb 2026 14:14
09 Feb 2026 14:04
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Yeah i forgot to mention the size is 640X640X1600mm and print size is 460X460X1200mm, could have pushed the height to 1350mm but if i add a lid it would not leave space for the filament roll.
I will probably start another one, but this time more wide and less height...and a styro cutter...and an EDM...and the mill... As Pink Floyd once said: Time...
  • Nathan40
  • Nathan40
09 Feb 2026 13:43
Replied by Nathan40 on topic Using 7c81 with 5v encoder on bob3 config
Category: Driver Boards
As suggested ,have linked pin to my 7c81 input. Its a single phase encoder. I have set the counter mode to 1. But the values are coming between 1.8v and 5v on my meter. The rawcounts are changing to 1 and then 0. Please help as the encoder is not reading any counts and not changing at all.
  • my1987toyota
09 Feb 2026 12:34
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
that is definitely a sizable machine. Nice
  • ihavenofish
  • ihavenofish
09 Feb 2026 11:50
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
thanks
  • royka
  • royka
09 Feb 2026 10:17
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Sorry for the late reply, that image should also work for de OPI5 plus if you only edit in "armbianEnv.txt" the line:
fdtfile=rockchip/rk3588s-orangepi-5.dtb
to:
fdtfile=rockchip/rk3588-orangepi-5-plus.dtb
  • Dudelbert
  • Dudelbert
09 Feb 2026 09:10
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
At no time did it hit -20°C here, at -10°C it was plenty cold enough for me. It has gotten warmer the last days. The next update on the machine will be very soon (at least I hope).
  • depronman
  • depronman
09 Feb 2026 08:47
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
Tommy / Rod
Also worth remembering that I downloaded the previous latest version 2.9.7 which is also on Debian 13, burned the iso to a pen drive (all be it a different pen drive) using the same version of Rufus with all the same settings and that installed GRUB perfectly
  • depronman
  • depronman
09 Feb 2026 08:41 - 09 Feb 2026 19:58
Thanks Rod
See my reply above to Tommy
Secure boot was already turned off
Machine for context is a Dell small form factor vintage 2014
Intel dual core 8gb ram
Selected as it gives really low max jitter numbers
Cheers. Paul
  • depronman
  • depronman
09 Feb 2026 08:37
Secure boot is already turned off
I’ll take a look for CSM (assumed to be ‘compatibility support module’)
I didn’t spot it in the bios but equally wasn’t looking for it. Is it normally in the same area of the bios screen that legacy mode and secure boot reside ?
Thanks for the help so far
Cheers. Paul
  • raggielyle1@gmail.com
09 Feb 2026 08:33
Replied by raggielyle1@gmail.com on topic New Laser Build - raster engraving
Category: Plasma & Laser
Try this code
#!/bin/bash
# Laser Engraving Converter - Final Vertical Fix
echo "========================================"
echo " LASER ENGRAVING CONVERTER "
echo ""
# Get filename
read -p "Enter image name (without .png): " base_name
# Find the file
if [ -f "${base_name}.png" ]; then
png_file="${base_name}.png"
elif [ -f "${base_name}.PNG" ]; then
png_file="${base_name}.PNG"
elif [ -f "$base_name" ]; then
png_file="$base_name"
else
echo "ERROR: File '${base_name}' not found!"
read -p "Press Enter to exit..."
exit 1
fi
echo "Found: $png_file"
gcode_file="${base_name}laser.ngc"
echo "Output: $gcode_file"
echo ""
# Get settings
read -p "Enter target width in mm: " target_width_mm
read -p "Enter DPI [75]: " dpi_input
dpi=${dpi_input:-75}
read -p "Enter feed rate [500]: " feed_rate_input
feed_rate=${feed_rate_input:-500}
read -p "Enter safe Z height [10]: " safe_z_input
safe_z=${safe_z_input:-10}
read -p "Enter engrave Z height [0]: " engrave_z_input
engrave_z=${engrave_z_input:-0}
read -p "Enter minimum power [1]: " min_power_input
min_power=${min_power_input:-1}
read -p "Enter maximum power [500]: " max_power_input
max_power=${max_power_input:-500}
read -p "Cross-hatching? (y/n) [n]: " cross_hatch_input
cross_hatch=${cross_hatch_input:-n}
echo ""
echo "=== SETTINGS ==="
echo "Image: $png_file"
echo "Width: ${target_width_mm}mm"
echo "DPI: $dpi"
echo "Feed: ${feed_rate} mm/min"
echo "Safe Z: ${safe_z}mm"
echo "Engrave Z: ${engrave_z}mm"
echo "Power: ${min_power}-${max_power}"
echo "Cross-hatch: $cross_hatch"
echo ""
read -p "Continue? (y/n): " confirm
if ! "$confirm" =~ ^[Yy]$; then
echo "Cancelled."
exit 0
fi
echo "Converting..."
echo ""
cat > /tmp/laser_final_fix.py << 'PYTHON_EOF'
import sys
import os
from PIL import Image
def main():
if len(sys.argv) != 11:
print("ERROR: Wrong number of arguments")
return 1
# Parse arguments
input_file = sys.argv[1]
target_width_mm = float(sys.argv[2])
dpi = int(sys.argv[3])
feed_rate = int(sys.argv[4])
safe_z = float(sys.argv[5])
engrave_z = float(sys.argv[6])
min_power = int(sys.argv[7])
max_power = int(sys.argv[8])
cross_hatch = sys.argv[9]
output_file = sys.argv[10]
print(f"Converting: {os.path.basename(input_file)}")
print(f"Power range: {min_power}-{max_power}")
try:
# Load image
img = Image.open(input_file)
if img.mode != 'L':
img = img.convert('L')
orig_w, orig_h = img.size
# Calculate new size
pixels_per_mm = dpi / 25.4
target_px_w = int(target_width_mm * pixels_per_mm)
aspect_ratio = orig_h / orig_w
target_px_h = int(target_px_w * aspect_ratio)
actual_mm_w = target_px_w / pixels_per_mm
actual_mm_h = target_px_h / pixels_per_mm
mm_per_pixel = 25.4 / dpi
print(f"Image size: {target_px_w}x{target_px_h} pixels")
print(f"Physical size: {actual_mm_w:.1f}x{actual_mm_h:.1f} mm")
print(f"mm per pixel: {mm_per_pixel:.3f}")
# Resize
img = img.resize((target_px_w, target_px_h))
pixels = list(img.getdata())
# Generate G-code
with open(output_file, 'w') as f:
# Header
f.write('; Laser engraving - FINAL FIX\n')
f.write(f'; Image: {os.path.basename(input_file)}\n')
f.write(f'; Size: {actual_mm_w:.1f}x{actual_mm_h:.1f} mm\n')
f.write(f'; DPI: {dpi}\n')
f.write(f'; Feed: {feed_rate}\n')
f.write(f'; Power: {min_power}-{max_power}\n\n')
# Setup
f.write('G21\nG90\nG64\nG17\nG54\n\n')
# Initialize
f.write(f'F{feed_rate}\n')
f.write(f'G0 Z{safe_z:.1f}\n')
f.write('G0 X0 Y0\n')
f.write(f'G0 Z{engrave_z:.1f}\n')
f.write('M3\n\n')
# HORIZONTAL PASSES
f.write('; --- HORIZONTAL PASSES ---\n')
print("\nGenerating horizontal passes...")
for y in range(target_px_h):
# Flip Y: image row y (0=top) -> machine Y (target_px_h-1-y)*mm_per_pixel
y_pos = (target_px_h - 1 - y) * mm_per_pixel
if y % 2 == 0:
# Left to right
f.write(f'G0 X0 Y{y_pos:.3f}\n')
for x in range(target_px_w):
pixel = pixels[y * target_px_w + x]
power = min_power + int((max_power - min_power) * (255 - pixel) / 255)
f.write(f'G1 X{x*mm_per_pixel:.3f} S{power}\n')
else:
# Right to left
f.write(f'G0 X{actual_mm_w:.3f} Y{y_pos:.3f}\n')
for x in range(target_px_w-1, -1, -1):
if y % 50 == 0:
print(f" Row {y+1}/{target_px_h}")
# VERTICAL PASSES
if cross_hatch.lower() == 'y':
f.write('\n; --- VERTICAL PASSES (CROSS-HATCH) ---\n')
print("\nGenerating vertical passes...")
print("DEBUG: This should engrave on the way UP, not on the way DOWN!")
x_pos = x * mm_per_pixel
if x % 2 == 0:
# Even columns: bottom to top (engrave on the way UP)
f.write(f'G0 X{x_pos:.3f} Y0\n')
# We want to go from Y=0 to Y=max
# Read pixels from BOTTOM (image row target_px_h-1) to TOP (image row 0)
for step in range(target_px_h):
# step: 0 to target_px_h-1 (bottom to top in machine coords)
# image_y: target_px_h-1 to 0 (bottom to top in image)
image_y = target_px_h - 1 - step
pixel = pixels[image_y * target_px_w + x]
current_y = step * mm_per_pixel # 0 to max
f.write(f'G1 Y{current_y:.3f} S{power}\n')
else:
# Odd columns: top to bottom (engrave on the way DOWN)
f.write(f'G0 X{x_pos:.3f} Y{actual_mm_h:.3f}\n')
# We want to go from Y=max to Y=0
# Read pixels from TOP (image row 0) to BOTTOM (image row target_px_h-1)
# step: 0 to target_px_h-1 (represents position from top)
image_y = step # 0 to target_px_h-1 (top to bottom in image)
current_y = actual_mm_h - (step * mm_per_pixel) # max to 0
if x % 50 == 0:
print(f" Column {x+1}/{target_px_w}")
# End program
f.write('\n; --- END ---\n')
f.write('M5\n')
f.write('M2\n')
print(f"\n✅ G-code written to: {output_file}")
# Show sample of vertical section
if cross_hatch.lower() == 'y' and os.path.exists(output_file):
with open(output_file, 'r') as f:
lines = f.readlines()
# Find vertical section
for i, line in enumerate(lines):
if 'VERTICAL PASSES' in line:
print("\n=== SAMPLE OF VERTICAL SECTION ===")
# Show first 20 lines of vertical section
for j in range(i, min(i+20, len(lines))):
print(f" {lines[j].rstrip()}")
print("...")
break
return 0
except Exception as e:
print(f"\n❌ ERROR: {e}")
import traceback
traceback.print_exc()
return 1
if __name__ == "__main__":
sys.exit(main())
PYTHON_EOF
# Run the Python script
python3 /tmp/laser_final_fix.py \
"$png_file" \
"$target_width_mm" \
"$dpi" \
"$feed_rate" \
"$safe_z" \
"$engrave_z" \
"$min_power" \
"$max_power" \
"$cross_hatch" \
"$gcode_file"
result=$?
echo ""
if [ $result -eq 0 ]; then
echo "CONVERSION COMPLETE!"
echo "File: $gcode_file"
echo ""
else
echo "CONVERSION FAILED!"
fi
echo ""
  • Hakan
  • Hakan
09 Feb 2026 07:44
Replied by Hakan on topic XHC WHB04B development?
Is it realistic to write a new firmware for the dongle? Is it to improve on the reset?
Sounds like you identified blocking wait states as at least one big part of the problem.
Realistic to rewrite those sections in the component?
fyi, I have the radio version, works well for me needs.
  • David-Diy
  • David-Diy's Avatar
09 Feb 2026 06:24
Replied by David-Diy on topic Hydraulic press brake control
I just arrived but I just fixed a new Chinese 12 feet CNC press brake, and I have to say the control box HMI and the motor pump is very clean installation. The one that I fixed was 120T. I recommend you to build your own from a 5-10HP motor low speed, buy the oil pump, just the cylinder block. and connect 1/2" hoses to your reservoir. The already made will not have what it takes to be sufficiently powerful to be happy with repeatability.
Displaying 5641 - 5655 out of 14029 results.
Time to create page: 1.191 seconds
