  • BIBIGUL
  • BIBIGUL
08 Feb 2026 19:19 - 08 Feb 2026 19:32
Replied by BIBIGUL on topic 403 Forbidden
403 Forbidden
Category: Forum Questions
Phone - 401 Unauthorized
08 Feb 2026 19:07
Replied by tommylight on topic 403 Forbidden
403 Forbidden
Try from a phone or tablet, or another PC.
  • bobwolf
  • bobwolf
08 Feb 2026 18:56
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
Hi everyone,
I’ve just released version 1.1.0 of the io_decoder driver. This update focuses on architectural stability and addressing initial feedback from the community.
What's new in v1.1.0:
Asynchronous Threading: I have moved the keyboard emulation logic (uinput) out of the Real-Time HAL thread and into a dedicated user-space thread. This ensures that any system-level delay in processing keystrokes will never interfere with the real-time performance of the CNC HAL components.
Config File Optimization (Credits to COFHAL): Following COFHAL's feedback regarding parsing errors with comments and blank lines, I have refined the io_decoder-keymap.cfg structure. I've implemented a stricter formatting requirement to keep the driver lightweight and added clear instructions within the config file to prevent GUI warnings.
Full English Translation: The source code and all comments have been fully translated to English for better accessibility.
Clean Exit: Improved the cleanup routine to ensure proper thread termination and resource release upon hal_exit.
You can find the updated source code, documentation, and the new pre-packaged ZIP on GitHub and the project landing page:
GitHub Repository: github.com/bobwolfrst/io_decoder-linuxCNC Project Page & Downloads: bobwolfrst.github.io/io_decoder-linuxCNC/
A big thanks to COFHAL for the valuable feedback. I’m looking forward to hearing from more testers about how the new threading model performs on different hardware setups!
Happy milling!
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:46
Replied by andypugh on topic Cannot JOG Plus/Minus move in TeleOp mode
Category: Basic Configuration
Which GUI are you using? I seem to recall that Axis needs to be on the manual tab for jogging to work.
Can you share your HAL file?
  • NT4Boy
  • NT4Boy
08 Feb 2026 18:42
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Crumbs I was sure that the angle used in M19, was the angle after an index pulse, but can see now its after the enable edge. Guess I cannot get the index to trigger the enable. Pulling oneself up by the bootlaces I expect.
I've been wondering whey I never really followed the logic behind how those on the forum have got tool changing to work.
So what is orient intended to do as I cannot picture what it can do if not related to a fixed point on the spindle.
A index relatable orient sounds like what I'd like, but not really got a clue how to start looking at that. Perhaps a bolt on python bit, a language I'm completely unfamiliar with. I'll do some research.
Thanks Andy.
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:32
Need to install newest Linux Debian Bookworm with the newest Linuxcnc preempt-rt
Category: Installing LinuxCNC
1) Why Bookworm and not Trixie?
2) Why not just install from the ISO image?
It looks like the automatic updater has not updated the manual page to reflect anything since 2.9.4.
You can see what the page is meant to currently say here:
github.com/LinuxCNC/linuxcnc/blob/master...etting-linuxcnc.adoc
  • amanker
  • amanker
08 Feb 2026 18:28
Thanks a lot.
I am attaching my ldscript which I made based on existing ldscripts included in repository. And attaching my platformio.ini.
File Name: STM32F446X...L.ld.txt
File Size:5 KB
File Name: platformio.ini
File Size:3 KB
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:23
Replied by andypugh on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
It sounds like the servo amps are being enabled without the PIDs being enabled.
Start LinuxCNC from the command-line and make sure that there are no error messages in there.
  • andypugh
  • andypugh's Avatar
08 Feb 2026 18:16 - 08 Feb 2026 18:18
Replied by andypugh on topic HURCO KMB-1 Control Update
I don't think that Orient uses index.
(It probably should, and adding spindles to the homing sequence is something that I meant to do and seem to have forgotten).
If you were to set the spindle-index-enable in the HAL file then the encoder would be aligned to index as soon as it does a revolution in spindle mode.
The "orient" component exists specifically to account for the many thousands of accumulated turns accumulated in the spindle encoder counter.
If you wanted to re-index on every orient then one way would be to create a modified version of "orient" that outputs an index-enable and that also commands an initial position command morfe than one turn from the starting postition until the index reset is detected.
  • DerKlotz
  • DerKlotz
08 Feb 2026 17:00
Hello,
I've been trying unsuccessfully all weekend to get the latest Debian Bookworm with the latest Linuxcnc preempt-rt up and running. Since I have little experience with Linux, I'm reaching my limits.
I downloaded and installed Debian Bookworm 12.13. Now I wanted to follow these instructions linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel , point 7 (with preempt-RT kernel). Would that be correct so far?
At point 3, Open Applications Menu > System > Synaptic Package Manager, search for linux-image, right-click on the original non-rt, and select Mark for Complete Removal, I don't know which original non-rt I have to select. I have attached a screenshot.
Otherwise, please attach Linux terminal commands so I can quickly achieve my goal.
Greetings from Germany and many thanks.
Translated with DeepL.com (free version)
  • BIBIGUL
  • BIBIGUL
08 Feb 2026 16:35
403 Forbidden was created by BIBIGUL
403 Forbidden
I created a topic, went into it and - 403 Forbidden. What is it? How to fix?
  • 5_Zylinder
  • 5_Zylinder
08 Feb 2026 16:12
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Hello everyone, we've now integrated several pushbuttons and switches. The signals are being received and are functioning correctly. However, a new problem has arisen: as soon as I switch on the machine, the X and Y axes start moving immediately, and Linux CNC goes into error mode. I don't recall ever having this problem before. Nothing has been changed in the wiring. Perhaps someone has a crucial suggestion.
  • PCW
  • PCW's Avatar
08 Feb 2026 15:37
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
You might try increasing the interval (it's in microseconds so 1000 is just one ms)
And that may be too fast for the Omron
I will look into getting a MX2 to try to have some way of duplicating the issue.
The GS10 setup was straightforword
  • Fl4tty
  • Fl4tty
08 Feb 2026 14:57
Replied by Fl4tty on topic StepperOnline A6 Servo
Category: EtherCAT
I guess you summarize all your servo drives, so 4x400W would roughly be a FN 2090-16-06?
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 13:55
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
OK
I have given up on making it work after messing up several versions of my hals and inis
Instead i now want to make new ones by using mesaCT like i did from the beginning (the way that so far let me get the most successfull result)
I get an "OK" when trying to test the configuration
But when building the configuration i get this message from meseCT:
File "../../usr/lib/python3/dist-packages/libmesact/buildconfig.py", line 61, in build
    parent.updateini.update(parent, iniFile)
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 135, in update
    self.update_key(item[0], item[1], item[2])
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 765, in update_key
    start = self.sections[f'[{section}]'][0]
KeyError
'[MESA]'
First download the deb and reinstall
to be sure you have the latest build date
Then please file an issue at
github.com/jethornton/mesact/issues
Displaying 5686 - 5700 out of 14029 results.
Time to create page: 0.895 seconds
