27 Jan 2026 22:01
Replied by tommylight on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
But will it make any sense at all to try to configure the setup as long as I get an “unsupported board”
You should ignore that, it is the older version of mesaflash, you do not need mesaflash at all unless you need to change the board firmware, ever.
As for "easy as...", it is same as everything in life, i can not use an iphone and will never ever learn as it is absolutely not intuitive, but i can operate medical equipment i have never seen before after about 15 seconds of looking at it.
Friendly advice, stop thinking about "mach vs LinuxCNC", they are not the same in any way, shape, or form, except both control machines, Mach is for small simple weekend use machines, LinuxCNC for everything from small engravers to huge industrial machines and fully automated production lines, hence it is simple only for simple machines, it can not be simple for a several ton industrial machine.
Get over it, move on, and start here first and foremost and do not skip anything:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
  • SrLange61
  • SrLange61's Avatar
27 Jan 2026 21:58 - 27 Jan 2026 22:13
Replied by SrLange61 on topic issues with isolcpus
All guides say that grub is updated from this file by " sudo update-grub".
What worked better for running my real machine is to use this script here:- forum.linuxcnc.org/38-general-linuxcnc-q...rq-affinity?start=60
srl
27 Jan 2026 21:51
Replied by tommylight on topic Custom PC build for my brothers company and more
Category: Show Your Stuff
New builds for a dentist, needed 3 of proper PC's for the new offices, but insisted on plain simple cases, will have to switch of the LED's before sending them as he might have a heart attack! :)
They do boot fast though, very fast:
Will do the boot test on Linux as it should be even faster...
27 Jan 2026 21:48
I will need an ice cold shower if they call and say they can not ship it due to ....reasons!!!
Had several cold showers back then as even their CEO called me to justify their f@kin mistake, aft6er about 20 phone calls i had enough. They did offer to send me the motherboard that the EAN number was listed instead, but i said no.
  • unknown
  • unknown
27 Jan 2026 21:23
  • unknown
  • unknown
27 Jan 2026 21:19
Replied by unknown on topic Linuxcnc 2.9.4 and Mesa 7i97T
You don't need "20 years of Linux behind you", get rid of that way of thinking. All you need to be able to do is follow instructions, minding syntax and not taking shortcuts, and be able to relay any error messages without leaving anything out. It is also to follow any links in replies, it saves those that reply having to repeat any info.
Oh and mesa wouldn't sell you a product that is deemed to work with Linuxcnc that doesn't .
Did you look at the download PCW attached, I think it was a simple config to get you going.
Upgrading mesaflash from the GitHub page may help with your issue .
  • DemonClaW
  • DemonClaW
27 Jan 2026 21:11
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
Hey Guys,
I was quite busy that week so i didnt get much work into it but here is what i got at this point.
On left down corner you can find a Vakuum button that allows you to switch Clamping variant between a vice or something like that and vacuum clamping. It opens the PopUp on the right side, there you find 4 displays for 4 vacuum plates, your able to switch them on or off depending on how large your workpiece is you can work with 1 or with all 4. The Main Slider down in the middle allows you to set the needed pressure. Every plade is moitored by a single Pressure sensor on a beckhoff EL3124. If the pressure gets lower then the main slider value the system goes immediately in E-Stop mode to provide serios accidents. The main slider may gets removed after i made some experience with the system.
  • edimas93
  • edimas93
27 Jan 2026 20:49
Spindle Step/Dir and as C axis one the same Servo
Category: Basic Configuration
Is there any hal to configure this 2-mode configuration!
  • OT-CNC
  • OT-CNC
27 Jan 2026 20:19
Replied by OT-CNC on topic How do I lubricate correctly?
Category: Milling Machines
Good info.
I used Nylon tubing in the past. I think. Whatever it was has been holding up well. I'll look into Kynar.
What are the compression fittings you are using on the trucks? That is usually the more difficult part to source due to the odd pitch of 0.75 on some LM blocks.
Push to connect fittings are fantastic except for some that grab the tubing without a proper release mechanism. Meaning the collar that gets pushed in doesn't slip over the teeth to release causing tubing to become shredded during removal. That can contaminate critical components. I wanted to mention that as I recently went through that with cheap fittings.
For a lathe I would need 10 remote ports if direct fed like on your setup. That might be okay.
Equal length tubing may be a solution to avoid metering units if running it off a manifold. Any experience with that?
  • mrmike
  • mrmike's Avatar
27 Jan 2026 19:57
issues with isolcpus was created by mrmike
I cannot get the isolcpus command line to take effect.  I have set the grub to the following:
savedefault
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
search --no-floppy --fs-uuid --set=root a08bfa77-56e1-4ee2-a80a-ccc22b8725cd
echo    'Loading Linux 6.3.0-rt11-linuxcnc ...'
linux    /boot/vmlinuz-6.3.0-rt11-linuxcnc root=UUID=a08bfa77-56e1-4ee2-a80a-ccc22b8725cd ro initrd=/install/gtk/initrd.gz
echo    'Loading initial ramdisk ...'
initrd    /boot/initrd.img-6.3.0-rt11-linuxcnc
GRUB_CMDLINE_LINUX_DEFAULT="isocpus=3"
And have changed the last line to 0,1,2 to 0, to 1, and to 2 with no effect.  The histograms show 4 cores no_isolcpus.
This is an intel i5-6500t.
Any ideas?
  • Nkbhvid
  • Nkbhvid
27 Jan 2026 19:51
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
A little about the background for the project.
I have over time -as a side business - made several retrofits of older (woodworking)cnc machines
Normally I change the driveline to new hybrid steppers controlled by a plc with a control sw developed by ourselves (or in a few projects Mach 3&4), but in this project I have a huge 7ton Homag with very powerful Rexroth motors and drives where i have modified the drives to analog control.
Therefore I went for a LinuxCNC and a mesa 7i97T.
I accept there is a learning curve but it has been far more complex than expected.
I’m surprised about how many YouTubes are found about “LinuxCNC as easy as Mach3” a statement I have hard to believe unless you have 20 years of Linux behind you
  • bobwolf
  • bobwolf
27 Jan 2026 19:42
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
I'm interested in trying this out. Where can I get the Arduino source code?
You can find everything here: Project Home & Documentation:  bobwolfrst.github.io/io_decoder-linuxCNC/demo_mode.en
Direct Download (.zip):
github.com/bobwolfrst/io_decoder-linuxCN..._decoder_eval-v1.zip
ciao
Roberto
  • ruediger123
  • ruediger123
27 Jan 2026 19:19
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
@grandixximo
Very good work!
I've started testing.
I've noticed that the track speed is very low with G2/G3, but significantly higher with G64 Pxx.
More tomorrow.
  • spumco
  • spumco
27 Jan 2026 19:18
Replied by spumco on topic How do I lubricate correctly?
Here's what I came up with for my Mill's Y-axis saddle.  Much simpler than running grease/oil lines to a central lubrication pump...make them just long enough for easy access.
  • Hose is Kynar (PVDF), I believe 4mm OD
    • any fluoro-polymer hose/tube should be fine (PTFE, ETFE, etc), stay away from anything else.
  • Fittings are just cheap air-hose push-to-connect (same as 3D printer filament tube size)
    • The cheap push-to-connect o-rings will likely fail after some years, but it'll be obvious when it happens and I have a dozen or so spare fittings
    • Drill out the PTC fitting to remove any unnecessary constrictions (it's surprising how small the ID is)
    • The fittings on the actual trucks are compression w/ferrules, so no o-rings to worry about
  • Manifold is a really kludged DIY thing - drilled/tapped for the fittings
    • it's not actually a manifold... each port is separate
  • I'm using NLGI #1, no moly.  Any thicker (or much longer hoses) and I'd run the risk of a hose popping out of a fitting.
Z-axis has a similar 'remote fill' system as the Y-axis.
Couple pumps 3-4 times a year (low use machine) and no issues since installed.
  • Jocman
  • Jocman
27 Jan 2026 18:32
MAC address not retrieved (after 2 years stop)
As I've 2 lan cards (the onboard and a second PCI board), I tried to launch
ip a
when connected to both, and this is what I get:
connected to Mesa (onboard card):
joccnc@JocCnc:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether e8:4e:06:84:dc:c9 brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/8 brd 10.255.255.255 scope global eth0
    inet6 fd59:b8bd:be6f:0:377f:d68c:ef9e:9227/64 scope global noprefixroute dynamic
       valid_lft 7154sec preferred_lft 3554sec
    inet6 fe80::8bdd:424d:f6d4:7ea2/64 scope link
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 70:85:c2:6a:f0:3d brd ff:ff:ff:ff:ff:ff
joccnc@JocCnc:~$
and pinging  my router:
joccnc@JocCnc:~$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
ping: sending packet: Network is unreachable
connected to WEB:
    inet 192.168.1.245/24 brd 192.168.1.255 scope global dynamic eth0
       valid_lft 863814sec preferred_lft 863814sec
    inet6 fd59:b8bd:be6f:0:6bdd:2ca7:6e73:aa7b/64 scope global noprefixroute dynamic
       valid_lft 7016sec preferred_lft 3416sec
    inet6 fe80::6ed6:c856:a0cb:2db8/64 scope link
joccnc@JocCnc:~$
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=0.651 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.488 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.479 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.522 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.479 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=0.461 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=0.479 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=0.478 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=0.483 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=0.486 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=0.398 ms
I've attached a screenshot of my desktop showing the lan connection window
Displaying 6301 - 6315 out of 14037 results.
Time to create page: 0.449 seconds
