  • Aciera
  • Aciera's Avatar
29 Dec 2025 13:26 - 29 Dec 2025 15:59
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Good to hear that you are making progress.
[edit]
I would be interested to know how tool offsets are handled in the tool table for lathe tooling in the milling spindle on such a mill-turn machine. On a lathe the tool offset is different to a mill in the sense that the length of the tool is an X-offset as opposed to a Z-offset. That is why I have made two different TCP (mill / lathe) modes in this sample config. I wonder if that is actually necessary or if lathe tool offsets are handled just like milling tools.
  • jochen91
  • jochen91
29 Dec 2025 13:12
Hi Folks,
im still living. Wanna give you a status update:
  1. The spindle taper is fixed (Needed to be Laserwelded and reground)
  2. New spindle bearings
  3. I scraped the geometry of the Y axis. Which was a major step, and im not satisfied with the bearing points. (Geometry is excellent) When it gets warmer in Germany i want the moglice all the guide ways. Epoxy is already ordered.
  4. I reassembled the B axis. In january i hope to reassemble the spindle and mount it to the B axis. I need the spindle and B axis ready and mounted to the X axis slide to check and scrape (even for moglice scraping is needed) the geometry.
Kind regards and happy new year,
Jochen
  • matasbuk
  • matasbuk
29 Dec 2025 13:06
Replied by matasbuk on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
At this stage, I would bypass the contactors so the Indramat is on when the power is connected to the machine (maybe through estop chain) without LCNC and manually give an analog signal to the indromat using a 1.5V AA battery. If the Z axis moves, you can continue to troubleshoot the following error. If it does not, then the indramat is dead.
  • andrax
  • andrax's Avatar
29 Dec 2025 12:48 - 29 Dec 2025 12:49
Replied by andrax on topic Problem bei installation Ethercat
Category: Deutsch
Hallo zusammen,
melde mich wieder nach langer Zeit aus der Versenkung.
Ich habe neues zu berichten. Meine alte Konfiguration mit SEW-Servos und analoger Ansteuerung über die Mesa 7i97 lief mehr schlecht als recht.
Ich hab das alles rausgeworfen und den freiwerdenden Platz mit  A6 Servos (Ethercat) von Stepperonline gefüllt.
Mit Hilfe aus den Forum forum.linuxcnc.org/ethercat/54965-stepperonline-a6-servo hab ich alles erfolgreich zum laufen gebracht.
Meine Konfiguration:
Gantry: XYYZ (1800mm x 600mm x 300mm)
Servos: X A6 750W Ethercat STO, YYZ A6 400W Ethercat STO
Die Servos laufen über Netztwerkkarte 1 und die I/O über Netzwerkkarte2
Oberfläche: Gmoccapy
Homing über Homeschalter
Die Servos werden leider ohne I/O Kabel geliefert. Das wird benötigt, um die Homeschalter an die Servos anzuschließen.
Ich habe mir hier DB15 VGA Stecker bestellt und die Kabel selbst gebaut.
Die Achsen verfahren, Homing funktioniert, jetzt muss ich nur noch die Feineinstellungen erledigen.
Grüße
Andre
File Name: ethercat_2...2-29.xml
File Size:8 KB
File Name: Andres_Frs...2-29.hal
File Size:9 KB
File Name: Andres_Frs...2-29.ini
File Size:4 KB
  • RotarySMP
  • RotarySMP's Avatar
29 Dec 2025 12:27
I am now having trouble with the Maho 400E. The machine was working normally, had a normal shut down, and the next day started erring out.
It does not seem to be a LinuxCNC or Mesa  issue as it boots into LinuxCNC without error.
** Note - It is configured as a vertical mill, but Maho configured as a horizontal, so on the original schematics, Y and Z are switched.
** Note - The HAL and Ini are attached to the first posts in this thread.
Consistent symptoms.
- X axis jogs without error.
- Y axis will jog in either direction, as far as I like, but as soon as I release the jog button, it faults with a " Y axis following error"
- Z axis faults immediately as soon as jog button pushed to "Z axis following error".
These symptoms are consistent and repeatable.
In addition, inconsistent symptoms are
- When it first happened the "Control Voltage Fault" light was lit on the Indramat server amp. This has not lit again
- On start up,  sometimes it refuses to latch on, sometimes it drops the latch immediately with a " External estop set" messages:
Troubleshooting:
- The 3Ph power at the wall probed normal.
- The 3ph  power in the cabinet after the main switch probed fine
- The 2x90VAC and 2x 140VAC which input to the Indramat probe fine at the input to the 7K1 relay.
- The E-Stop chain has continuity.
- The Machine is ready chain through the motor overheat protection (8B2/9B2/10B2) is working.
- Interchanging the Heidenhain EXE's makes no difference to behaviour (withing the limitation that Y and Z EXE's have different resolutions, and therefore the PID tuning is off on the swap).
-manually jogging Y with a hex drive, the linear scale follows motion.
It would seem that the next troubleshooting step is to work out whether the Indramat is faulting and dropping the 7A1 contact.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
or whether the Indramat is simple reacting to either a fault in the enable circuit
...or it the issue is driven by the latching circuit
How would you recommend troubleshooting to isolate which is cause, and which is effect, with these actions which occur nearly similtaneously? With pins or signals should I put on the Halscope, and what am I looking for please?
The Indramat 3TRM2 manual is here:
www.ssdservice.pl/FTP-serwer/Aplikacje%2...T/3TRM2%20MANUAL.pdf
Cheers,
Mark
  • JT
  • JT's Avatar
29 Dec 2025 12:23 - 29 Dec 2025 12:56
Replied by JT on topic Safely Flash a Mesa Board
Category: Driver Boards
I just updated the 7i92t firmware to include all the latest firmware from Mesa. Select the 7i92t and then Downloads > Firmware to get the latest.
Edit: I also updated the 5i25t, 7i76eu, 7i95t, 7i96s and 7i97t firmware.
JT
  • Ozcnc
  • Ozcnc
29 Dec 2025 12:18
Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Hello,
I've spent a few days getting Linuxcnc 2.9.7 up and running with a Mesa 5i25 board, properly flashed and functioning.
My hardware setup consists of 2no X-axis gecko 203V drives, 1no Y - axis, 1no Z-axis, and 1no A-axis.
I have x,y,z home switches, e-stop, and Highspeed Spindle.
I have been trying to get the mesa card to work with a HKD 5 AXIS MACH3 BOB.
Currently i can get mesa to drive the gecko drives and motors if I connect directly (Testing Purposes Only).
I cannot get the HKD BOB to drive the gecko drives and motors.
Does anyone have suggestions?
Thanks,
Orrin
  • Aciera
  • Aciera's Avatar
29 Dec 2025 12:12 - 29 Dec 2025 12:20
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
I think current master would probably make the most sense as this is where it could actually be merged. 2.9 is for bug fixes only. (Currently recommended stable version is 2.9.7)
[edit]
If your modifications are limited to the trajectory planner you might also be able to create a custom planner that can be used as a drop in replacement for the one currently used:
github.com/LinuxCNC/linuxcnc/blob/master...mponents/tpcomp.comp
  • manny
  • manny
29 Dec 2025 11:32
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
Hello,
I am attaching my INI and HAL files.
I am not sure which pins of the P3 connector on the Mesa 7i43
should be used to connect a stepper motor driver so that it works correctly.
The person who originally configured the system for me
reconfigured axis A to use a stepper motor,
but unfortunately he is no longer with us
and there is no one who could advise me now.
I would be happy to offer compensation for the help.
Thank you.
File Name: frezka_TOS.ini
File Size:5 KB
File Name: frezka_TOS.hal
File Size:14 KB
  • cncfreak
  • cncfreak
29 Dec 2025 10:53 - 30 Dec 2025 13:55
Replied by cncfreak on topic asd-a2-e ... lcec driver?
Category: EtherCAT
Hi.
I set up my machine and everything worked for me, but there is a small problem: The direction of movement of the X-Axis is not up to standard.
Please tell me how to change the direction of movement of an axis on a machine? How to swap + and - places? The machine is assembled on an ASD-A2 EtherCat. System LinuxCNC 2.9.2.
I tried to configure the change using scale using the following code:net x-vel-cmd    =>  scale.3.in
setp scale.3.gain -1
net x-vel-cmd-DAC  scale.3.out  =>  lcec.0.X.srv-vel-cmdand changing the .iniENCODER_SCALE = -1but the machine goes crazy and does not work normally.
Its the servo parameter P1-01 = 0x010C or 0x000C
  • tar_san
  • tar_san
29 Dec 2025 10:35
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I found lot of messages
"Failed to get reference clock time: Input/output error"
in LinuxCNC Console
when I set "refClockSyncCycles="-1" to EtherCat Master configuration.
But if I set refClockSyncCycles="1", I could not see such messages.
I attached
refClockSyncCyclesMinus1.linuxcnc.txt (LinuxCNC Console Log)
refClockSyncCyclesMinus1.dmesg.txt (dmesg Log)
when I execute with  "refClockSyncCycles="-1"
And also, for reference, I attached
refClockSyncCycles1.linuxcnc.txt (LinuxCNC Console Log)
refClockSyncCycles1.dmesg.txt (dmesg Log)
when I execute with  "refClockSyncCycles="1"
  • grandixximo
  • grandixximo's Avatar
29 Dec 2025 09:26 - 29 Dec 2025 10:06
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I would like to share an S-Curve jerk control I have been working on, actually since I made the OP, I think the code is pretty battle tested, but I based it on an old version, and I would like to port the code to something that the community will be happy with, what should my base code be from which to introduce the jerk control? are you guys ok with master? or 2.9.4?
  • grandixximo
29 Dec 2025 05:23
lemontart - a call for help with s curve, ui's, and all the cool toys
I have a pretty decent S-curve I have been using for sometime, would you be interested in testing it?
  • Thllll
  • Thllll
29 Dec 2025 03:55
Replied by Thllll on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Attached ini and hal
Displaying 7636 - 7650 out of 14025 results.
Time to create page: 0.427 seconds
