  • Mr. Mass
  • Mr. Mass's Avatar
06 Dec 2025 08:07
Replied by Mr. Mass on topic qtdragon mod
qtdragon mod
Category: Qtvcp
Oh, that works great, thank you very much. I even made a small function that checks the active HAL pin against the widget every time the encoder signals, but your method is much more elegant.
New question: how to connect a button to a HAL pin? I want to add an MPG on/off button. I created a HAL pin in the handler file and created IndicatedPushButton. In the button properties, I added HAL.set_p(’mpg.mpg-enable’,’1’) to true_python_cmd_string. But I got an error:
  File "<string>", line 1
SyntaxError: invalid character '’' (U+2019)
06 Dec 2025 08:04
Looking for freelancer to finish retrofit of K2 router
Category: User Exchange
Can you find anyone near you that knows a bit about wiring?
That would be very helpful.
06 Dec 2025 07:59
Replied by tommylight on topic Remora sk1.4 with ethernet?
The same pins used on RPI are on the W5500, those are the SPI pins so the wiring is the same.
Just check the pin naming.
06 Dec 2025 07:57
Replied by tommylight on topic GCode Review
GCode Review
Category: CAD CAM
Download the official LinuxCNC ISO, write to USB, use that USB to boot the PC (any PC) and use it in LIVE mode to view and test gcode using any of the included SIM configs.
06 Dec 2025 07:54
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
Try adding this
linuxcnc.org/docs/2.9/html/man/man9/timedelay.9.html
to amp.fault input pin.
  • nikk
  • nikk
06 Dec 2025 07:15
7i92T + 5 Axis BOB, encoder pin mapping issue.
Category: PnCConf Wizard
Dear author , please share the result. Unfortunately, I have the same problem and cannot find a solution.
  • Fastfred
  • Fastfred
06 Dec 2025 03:23
Clearpath HLFB amp.joint.delay was created by Fastfred
Category: HAL
I really could use some help trying to figured out how to setup a delay for amp.joint when I enable the machine i get a instant error from joint.amp using clearpath SD HLFB  , from what ive read i need to add a delay for it.But the problem is ive tried but no luck please someone show me a confing to get me started.
File Name: custom_2025-12-05.hal
File Size:2 KB
File Name: CNC_2025-12-05.hal
File Size:13 KB
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar
06 Dec 2025 02:42
Replied by LearningLinuxCNC on topic Mesa Configuration Tool
Category: Configuration Tools
I did not get a working stepper configuration out of MesaCT with a 7i76eu. I have posted the output and my working config here forum.linuxcnc.org/configuration-tools/5...erated-configuration
The output was supposed to be on the 02 stepper but it was connected to the 00 stepper. The feedback loop was not closed and it was not set to be in velocity mode. Look at the two configurations.
  • electrosteam
  • electrosteam
06 Dec 2025 02:22
GCode Review was created by electrosteam
GCode Review
Category: CAD CAM
Raspberry Pi 4B running Gmoccapy 4.9.4 without any significant issues on a 3-axis turret mill.
CamBam used to produce 3D MOPs for cast iron model locomotive wheels.
Camotics and NCViewer used to simulate the GCode files produced.
But, as we all know, issues do arise that need review.
NCViewer displays the GCode file and a 3D representation of the paths.
It includes an option that shows each GCode data point in the 3D display as a GCode line is highlighted.
The reverse does not work, selecting a data point does not highlight the equivalent GCode line.
Looking for suggestions on how to identify a GCode line when a path/point is selected on a 3D path display.
  • PCW
  • PCW's Avatar
06 Dec 2025 01:07
Homing open loop steppers on encoder index pulse
Category: Basic Configuration
Here's at least a first attempt:
File Name: 5i25_7i76_...sdid.zip
File Size:111 KB
  • Punisher
  • Punisher
05 Dec 2025 23:57 - 05 Dec 2025 23:58
Replied by Punisher on topic Remora sk1.4 with ethernet?
I searched through the documentation before starting this thread. That only shows how to wire it to a raspberry pi.
As I said at the beginning I do not want to use a raspberry pi. I want to use a w5500 ethernet board. Then connect with a pc. Like shown in the demo video.
  • seuchato
  • seuchato
05 Dec 2025 23:09
Script for automated testing of computer latency.
Futterama
Thanks for your error reports and certainly for the corrections.
I >think< Tommylight usually amended the link in Post #1 to the latest version. Unfortunately I am still not afloat. There is a 95% finished update of the script with quite a few amendmends. Not good to go public yet. I do hope I could give this some time soon.
Meanwhile, please do as you please and keep posting your findings.
greez
chris
... and thanks for the flowers anyway :-)
  • COFHAL
  • COFHAL
05 Dec 2025 22:23
Replied by COFHAL on topic wiring MPGs to 7i96s
Category: Driver Boards
I have a similar setup on my lathe; I'll send it to you later.
  • Masiwood123
  • Masiwood123's Avatar
05 Dec 2025 22:13
Replied by Masiwood123 on topic Hybrid Manual/Stepper Control
forum.linuxcnc.org/27-driver-boards/4698...7i96s?start=0#252760
I made a lathe with manual control of two axes simulatively, although apart from the servo motor as the main spindle I didn't have another axis as in your Z that could do its thing while these two are moved manually as I understood. maybe something in this topic can help.
  • Masiwood123
05 Dec 2025 21:43
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
this won't work either in sim mode or in reality, I tried something via chatgpt but I know that it doesn't work, it can't create a routine. here is my configuration if anyone is free to look at where the error is and what needs to be added in Hal eventually. Tx m6 works but will not return the tool to its pocket when you give it another tool, it also reports in the bottom line that there is no tool even though in reality it took it. each pocket has its own active high sensor on inputs 16-21 and the spindle has a sensor for ``flush'' input 10 the tool is in the spindle, input 12 reports that there is no tool in the spindle. Thanks
File Name: betabeta.zip
File Size:22 KB
youtube.com/shorts/CXxlm92xtt8
Displaying 8401 - 8415 out of 14064 results.
Time to create page: 1.129 seconds
