  • Thllll
  • Thllll
03 Jan 2026 14:36
Replied by Thllll on topic Auto Tool Probe - not callable
Category: Qtvcp
I corrected the program prefix, to be one and have the "~" at the start. Ran again I am getting the following from the terminal. The path is valid as well. The following is from the terminal
home/cnc/linuxcnc/configs/New_TAIG_dragon/New_TAIG_dragon.ini:92: executing 'import sys
sys.path.append("/home/cnc/linuxcnc/nc_files/examples/remap_lib/python-stdglue/python")'
PythonPlugin: Python  '3.13.5 (main, Jun 25 2025, 18:55:22) [GCC 14.2.0]'
is_callable(__init__) = FALSE
[QTvcp.QTVCP.QT_ISTAT][WARNING]  Path not valid in INI File [DISPLAY] PROGRAM_PREFIX section (qt_istat.py:96)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_LINEAR_VELOCITY Entry in DISPLAY, Using: 5 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_POWER Entry in DISPLAY, Using: 1500 (qt_istat.py:532)
is_callable(oword.on_abort) = FALSE
task: main loop took 0.119162 seconds
is_callable(oword.qt_auto_probe_tool) = FALSE
I compared to the sim .ini file and found that the "~" was not part of the program_prefix. Running it again without the "~", cleared the error
Still does not work but this was noticable
Running the sim actually in debug shows the same thing..
/home/cnc/linuxcnc/configs/sim.qtdragon.qtdragon_tool_probe/qtdragon_auto_tool_probe.ini:120: executing 'import sys
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
tool_result(id=2, xoffset=0.0, yoffset=0.0, zoffset=0.1, aoffset=0.0, boffset=0.0, coffset=0.0, uoffset=0.0, voffset=0.0, woffset=0.0, diameter=0.0625, frontangle=0.0, backangle=0.0, orientation=0)
  • freylax
  • freylax
03 Jan 2026 14:31 - 03 Jan 2026 16:34
Hi Oliver, thank you! I post the configuration (json.txt), linuxcnc_print.txt output and a copy of the terminal output linux_cnc_out.txt
I generall I know that I have to do some HAL configuration to (software) wire the machine together. What for the beginning is not so easy to know is what exactly has to be done. I see what your rio-setup does, and there is also the possibility to make linuxcnc HAL net connections in the setup, but what is necessary to start with..
I'm looking forward to hear from you,
regards, Robert
PS: do you run robot os on RPI5 Debian Trixie?
  • Surmetall
  • Surmetall's Avatar
03 Jan 2026 14:14 - 03 Jan 2026 14:15
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
thanks a lot for the update. I’m always happy to see new progress in this thread! :)
Also thanks for the screenshots, everything is looking very promising.I noticed that you’re writing the manual in German as well, so I assume you’re German too.
If you’re interested in chatting "in real time" in German with like-minded people, there’s a German-speaking Discord from Peter aka Talla83. You’ll find many LinuxCNC users there, including quite a few lathe users. If you’re ever looking for feedback or beta testers, that could be a good place to connect.
Of course, this is only meant as an addition, please definitely keep posting updates here as well. If you are interested, here is a Discord server invite link: discord.gg/dPBgNR3t
Best regards
Tom
  • Fastfred
  • Fastfred
03 Jan 2026 14:05
Replied by Fastfred on topic Manual tool change + tool lengh touch off
Hopefully not a silly question if i got this tool change config to work could I use it with easyprobe with min effort? (Axis Gui) easy probe not yet installed but like the GUI AXIS/Easy probe very basic.
  • JT
  • JT's Avatar
03 Jan 2026 13:59
Replied by JT on topic Mesa Configuration Tool
Category: Configuration Tools
It should be in Debian 13 what repositories do you have configured for debian?
Synaptic Package Manager > Settings > Repositories
Note: I don't have Debian 13 installed anywhere to test.
JT
  • aDm1N
  • aDm1N's Avatar
03 Jan 2026 13:46
Category: Qtvcp
Hi everyone,
I’d like to give a short status update on LatheEasyStep, mainly to clarify what has changed recently and what my current focus is.
 What has changed
1. Interactive legend in the preview
The preview now includes an interactive legend.
The title “Legend” is always visible and acts as a permanent click area.
Clicking on it toggles the legend collapsed / expanded.
When collapsed, only the header remains visible so the legend can always be reopened.
The legend affects visualization only, not geometry calculation or toolpath logic.
2. Improved preview with safety areas
The preview now clearly distinguishes different geometry and safety elements:
Green (solid): contour / target geometry
Yellow (solid): active machining path
Grey (dashed): stock outline
Cyan (dashed): retract planes (XRA/XRI/ZRA/ZRI)
Red (dashed): machining / safety limit (e.g. ZB)
Safety limit violations are highlighted visually.
Stock and retract planes are drawn based on the actual configured parameters, not approximations.
3. Facing – chamfer or radius at the end
In the Facing tab it is now possible to define an optional chamfer or radius at the outer end of the facing operation.
Supported options:
None
Chamfer
Radius
This affects both the preview geometry and the generated toolpath.
All of these changes are documented in the README, in both German and English.
 Current focus: the preview
Right now, my main focus is the preview system.
The goal is to make sure that:
geometry is displayed correctly,
safety and retract areas are clearly understandable,
and the preview can be trusted as a visual plausibility and collision-check aid.
Once the preview side is solid and stable, I’ll move on to the fine-tuning of the actual machining / stock removal functions and further logic improvements.
 Next steps
Further testing and stabilization of the preview
Real-world test cases with complete programs
UI adjustments if needed
After that: refinement and extension of machining features
  • 5_Zylinder
  • 5_Zylinder
03 Jan 2026 13:33
Replied by 5_Zylinder on topic Mesa Configuration Tool
Hello,
I installed Debian 13 (Trixie) and the latest Linux CNC 2.9.8 today. Unfortunately, the Mesa Configuration tool won't install.
I get the message: mesact: Depends: phyton3-distro but it is not installable. Perhaps someone could give me an additional tip.
  • meister
  • meister
03 Jan 2026 12:11
Hi Robert,
can you please post your json config and maybe the complete error output ?!?
  • cmorley
  • cmorley
03 Jan 2026 10:50
Replied by cmorley on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
OK
In your configuration folder (or the sim folder if you want to test there) there will be a set of folders qtvcp/screens/qrdragon/
in that last folder add the file i have provided. name it qtdragon_handler.py
When you run the config, there should be an entry in the status page about a customization.
The button should be clickable after that.
I would suggest you try the sim first.
  • PCW
  • PCW's Avatar
03 Jan 2026 10:48
Ich brauche Hilfe bei meiner Konfiguration
Can you post your hal and ini files?
The sserial_port0=something stanza in the driver command line
in the hal or ini file will determine which sserisl channels are enabled.
Does the 7I74 have 5V power?
  • andrax
  • andrax's Avatar
03 Jan 2026 10:04
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Eureka!
I think I've found the cause.
While I was testing various settings in the ini file, the errors occurred sometimes on one axis and sometimes on another.  Even with unchanged settings, the error was sometimes there and then gone again. Until I turned off my handwheel (WHB04B).
With the handwheel turned off, there are no problems with referencing.
For some reason, the handwheel seems to interfere with the reference run.
  • PCW
  • PCW's Avatar
03 Jan 2026 10:02
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Category: Driver Boards
The 7I84 should connect to 7I85 TB2 pins 10..16
There are also some difference in the VHDL source and mesaflash pin list
1. You have 2 null modules descriptors before the PKTUARTS. I don't think this will
work as the module scan normally ends at the first null
2. The source you posted has  sserial channels starting at channel 1 rather than 0
(so sserial_port_0=2xxxx" would disable the first channel (1) on the 7I85)
  • andypugh
  • andypugh's Avatar
03 Jan 2026 09:48
LinuxCNC 2.9.8 Release was created by andypugh
Category: LinuxCNC Announcements
LinuxCNC 2.9.8 has been released.This is a minor update release, mainly of interest to those using the hal_gpio HAL driver (mainly Pi users)Changelog:
  • backport #3516 to fix #3679
  • Only initialize python if not yet initialized.
  • hal_gpio: Adapt to use libgpiod3 or libgpiod2 according to what is installed
  • Merge pull request #3671 from smoe/docs_image_handling
  • core-components.adoc remove duplicate descriptions
  • Merge pull request #3642 from LinuxCNC/2.9_#2460
  • Update LinuxCNC RTAI Install instructions
  • Merge pull request #3555 from smoe/lintian_warnings
  • Merge pull request #3588 from f355/2.9
  • [ci] publish releases with artifacts
  • debian: Addressed lintian warnings
  • axis.py: restore mdi queuing provision #2460
The main driver for the release was the change in API for the gpiod driver. This resulted in the hal_gpio driver not being built under Trixie.As of this release the default Debian version for the ISO for both PC and Pi has been updated to Trixie. The LinuxCNC repositories have been updated for Buster, Bullseye, Bookworm, Trixie and Sid.Note that released debs are also now available on the LinuxCNC GitHub under “Releases”: www.github.com/https://github.com/LinuxCNC/linuxcncAs always, thanks to all the developers who make this possible, and for this release especially:Bertho Stultiens
Dewey Garrett
Konstantin Tcepliaev
Robert Schöftner
Steffen Möller
  • workshop54
  • workshop54
03 Jan 2026 09:14
Escalation of a Maho MH400E Retrofit (LinuxCNC + EtherCAT)
Category: Milling Machines
I finally put together a short YouTube video to introduce the project
(even though I’ve already been working on it for about a year ).
I’ll add more videos in the near future.
  • TripleM
  • TripleM
03 Jan 2026 09:10
I have checked the power and the cable, that look fine. (FieldA (24V) or FieldB (5V) power on 7I84)
This is the load line in the hal file:
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=6 num_pwmgens=1 num_stepgens=5 sserial_port_0=2xxxx"
Do I have to add anything if the 7i84 is connected via a daughter card?
Displaying 9196 - 9210 out of 11475 results.
Time to create page: 1.056 seconds
