  • emresensoy
  • emresensoy
03 Dec 2025 18:08
Replied by emresensoy on topic Beckhoff EL2522 lcec xml file
Category: EtherCAT
Hakan, thank you very much for your answer. I'm curious about something else. For example, there's a built-in driver for the EL3062. Where is this file or driver stored on the hard drive? How can I view its contents?
  • Hakan
  • Hakan
03 Dec 2025 17:51
Replied by Hakan on topic Beckhoff EL2522 lcec xml file
Category: EtherCAT
See if the output of "lcec_configgen" will work.
  • emresensoy
  • emresensoy
03 Dec 2025 17:44
Beckhoff EL2522 lcec xml file was created by emresensoy
Category: EtherCAT
There is no builtin driver for EL2522,
I need help to convert ethercat xml output to lcec xml
Thanks,
<EtherCATInfo>
    <!-- Slave 6 -->
    <Vendor>
      <Id>2</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
          <Type ProductCode="#x09da3052" RevisionNo="#x00160000">EL2522</Type>
          <Name><![CDATA[EL2522 2K. Pulse Train Ausgang]]></Name>
          <Sm Enable="1" StartAddress="#x1000" ControlByte="#x26" DefaultSize="128" />
          <Sm Enable="1" StartAddress="#x1080" ControlByte="#x22" DefaultSize="128" />
          <Sm Enable="1" StartAddress="#x1100" ControlByte="#x24" DefaultSize="28" />
          <Sm Enable="1" StartAddress="#x1280" ControlByte="#x20" DefaultSize="16" />
          <RxPdo Sm="2" Fixed="1" Mandatory="1">
            <Index>#x1600</Index>
            <Name>PTO RxPDO-Map Control Ch.1</Name>
            <Entry>
              <Index>#x7000</Index>
              <SubIndex>1</SubIndex>
              <BitLen>1</BitLen>
              <Name>Frequency select</Name>
              <DataType>BOOL</DataType>
            </Entry>
            <Entry>
              <SubIndex>2</SubIndex>
              <BitLen>1</BitLen>
              <Name>Disable ramp</Name>
            </Entry>
            <Entry>
              <SubIndex>3</SubIndex>
              <BitLen>1</BitLen>
              <Name>Go counter</Name>
            </Entry>
            <Entry>
              <Index>#x0000</Index>
              <BitLen>13</BitLen>
            </Entry>
            <Entry>
              <SubIndex>17</SubIndex>
              <BitLen>16</BitLen>
              <Name>Frequency value</Name>
              <DataType>UINT16</DataType>
            </Entry>
          </RxPdo>
            <Index>#x1603</Index>
            <Name>PTO RxPDO-Map Target Ch.1</Name>
            <Entry>
              <SubIndex>18</SubIndex>
              <BitLen>32</BitLen>
              <Name>Target counter value</Name>
              <DataType>UINT32</DataType>
            </Entry>
          </RxPdo>
            <Index>#x1605</Index>
            <Name>PTO RxPDO-Map Control Ch.2</Name>
            <Entry>
              <Index>#x7010</Index>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>13</BitLen>
            </Entry>
            <Entry>
              <BitLen>16</BitLen>
            </Entry>
          </RxPdo>
            <Index>#x1608</Index>
            <Name>PTO RxPDO-Map Target Ch.2</Name>
            <Entry>
              <BitLen>32</BitLen>
            </Entry>
          </RxPdo>
            <Index>#x160b</Index>
            <Name>ENC RxPDO-Map Control Ch.1</Name>
            <Entry>
              <BitLen>2</BitLen>
            </Entry>
            <Entry>
              <Index>#x7020</Index>
              <BitLen>1</BitLen>
              <Name>Set counter</Name>
            </Entry>
            <Entry>
              <BitLen>12</BitLen>
            </Entry>
            <Entry>
              <SubIndex>16</SubIndex>
              <BitLen>1</BitLen>
              <Name>Reserved</Name>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
              <Name>Set counter value</Name>
            </Entry>
          </RxPdo>
            <Index>#x160d</Index>
            <Name>ENC RxPDO-Map Control Ch.2</Name>
            <Entry>
              <BitLen>2</BitLen>
            </Entry>
            <Entry>
              <Index>#x7030</Index>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>12</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
            </Entry>
          </RxPdo>
          <TxPdo Sm="3" Fixed="1" Mandatory="1">
            <Index>#x1a00</Index>
            <Name>PTO TxPDO-Map Status Ch.1</Name>
            <Entry>
              <Index>#x6000</Index>
              <BitLen>1</BitLen>
              <Name>Sel. Ack/End counter</Name>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
              <Name>Ramp active</Name>
            </Entry>
            <Entry>
              <BitLen>4</BitLen>
            </Entry>
            <Entry>
              <SubIndex>7</SubIndex>
              <BitLen>1</BitLen>
              <Name>Error</Name>
            </Entry>
            <Entry>
              <BitLen>6</BitLen>
            </Entry>
            <Entry>
              <SubIndex>14</SubIndex>
              <BitLen>1</BitLen>
              <Name>Sync error</Name>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
              <Name>TxPDO Toggle</Name>
            </Entry>
          </TxPdo>
            <Index>#x1a01</Index>
            <Name>PTO TxPDO-Map Status Ch.2</Name>
            <Entry>
              <Index>#x6010</Index>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>4</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
              <Name>Error</Name>
            </Entry>
            <Entry>
              <BitLen>6</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
          </TxPdo>
            <Index>#x1a03</Index>
            <Name>ENC TxPDO-Map Status Ch.1</Name>
            <Entry>
              <BitLen>2</BitLen>
            </Entry>
            <Entry>
              <Index>#x6020</Index>
              <BitLen>1</BitLen>
              <Name>Set counter done</Name>
            </Entry>
            <Entry>
              <SubIndex>4</SubIndex>
              <BitLen>1</BitLen>
              <Name>Counter underflow</Name>
            </Entry>
            <Entry>
              <SubIndex>5</SubIndex>
              <BitLen>1</BitLen>
              <Name>Counter overflow</Name>
            </Entry>
            <Entry>
              <BitLen>8</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <SubIndex>15</SubIndex>
              <BitLen>1</BitLen>
              <Name>TxPDO State</Name>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
              <Name>Counter value</Name>
            </Entry>
          </TxPdo>
            <Index>#x1a05</Index>
            <Name>ENC TxPDO-Map Status Ch.2</Name>
            <Entry>
              <BitLen>2</BitLen>
            </Entry>
            <Entry>
              <Index>#x6030</Index>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>8</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>1</BitLen>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
            </Entry>
          </TxPdo>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  • PCW
  • PCW's Avatar
03 Dec 2025 17:19
Replied by PCW on topic MesaCT 2.1.8: Scale vs Encoder Scale
Category: Configuration Tools
The encoder scale with a 4mm pitch screw and 10000 counts per turn would be
2500 (counts per mm)
Not sure on MesaCT what the other scale refers to but possibly analog output scaling
LinuxCNCs maximum velocity should typically be about 80% of the drives maximum velocity
to allow control headroom. So with a 3000 RPM maximum drive speed, 160 mm/sec would
be a good maximum velocity (3000 RPM=50 RPS so 200 mm/s woudl be the velocity at 3000 RPM).
A good guess at maximum acceleration is 5X the maximum velocity
so 800 mm/s^2 (this means an axis will get to full speed in 1/5 of a second)
There are a number of tuning tutorials on the forum, assuming the drives are setup for velocity mode,
the most critical tuning parameter is FF1. If you set the analog scale to 200 (because at 10V the linear velocity
would be 200 mm/s) , FF1 will be 1.00
  • CaliusOptimus
  • CaliusOptimus
03 Dec 2025 16:59 - 03 Dec 2025 17:00
Replied by CaliusOptimus on topic Lathe project needs a turret
Category: Turning
The turret is up and running!
Not too bad getting it set up. The turret control board from tormach has NPN outputs and the mesa 7i77 needs PNP so I had to add some pullup resistors. One of the relays on the turret board also bit the dust right away (maybe my fault but not sure)... which led to a lot of confusion while programming the hal. I rigged it to use a couple of ice cube relays instead of the tiny, soldered in, DIP relays. Good to go.
Here's a vid of the first part I made with the turret. Just a little delrin spacer:
  • Hakan
  • Hakan
03 Dec 2025 14:57
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Install IgH Ethercat master from gitlab.com/etherlab.org/ethercat (standard site)
Follow installation procedure and when you do the "./configure " command,
make sure to use "./configure <other options>  --disable-eoe"
  • ArthurG
  • ArthurG
03 Dec 2025 13:59
Looking for freelancer to finish retrofit of K2 router
Category: User Exchange
Thank you for the quick reply.
We think the motors are DAE HWA D860-30B7 TC-9, but the manufacturer, K2, went out of business right after we bought the router, back in 2014, and we never received any documentation for it.
Other components:
Control: MESA 7i95T
Servo Amplifiers: Pico Systems PWM Servo Amplifiers
Encoders: Same Sky AMT113S-V
VFD: Delta VFD037C23A
Spindle: HSD Model ES 915A 2P H1
I've tried read and understand your guide many times before (as our previous consultant sent me it when he gave up on the tuning) but it's clearly meant for someone with deeper familiarity with the terminology than I have.
For example, when you say "Make sure you have 5V logic power, Vin and Vfield, or at least Vin with the jumper set for Vfield. Anything from 8 to 28V can be used." I have no idea how I'm supposed to do that.
Or shortly after that: "Try to get the scaling right for the encoders if you have info on the /encoder counts/lead screw pitch/reduction ratio/belt pulley teeth etc. Any change of the scale on a tuned axis will mess up the tuning, depending on how much it changed." How do I "get the scaling right", what am I checking or changing to make sure the scaling is right?
These are only two examples - your guide is clearly a wonderful aid for people with a deeper understanding of these systems and processes than I have, but it is well beyond my ability to utilize it without first spending many many hours of technical learning to get to the level where I can understand and follow the guide. This is why I would much rather hire an expert - someone who can either utilize your guide, or knows their way around these systems well enough to finish the retrofit without any guides.
  • HaroldHarvey
  • HaroldHarvey
03 Dec 2025 11:00 - 20 Dec 2025 08:30
Replied by HaroldHarvey on topic SmartSerial on cheap ESP32-8ch-Relais Card
Category: Driver Boards
Essas placas ESP32 baratas funcionam, mas exigem mais testes do que soluções industriais. A fase experimental faz lembrar os primeiros passos dos casinos em portugal no ambiente digital. Testar, errar e ajustar faz parte do processo.
  • hdhedhu
  • hdhedhu
03 Dec 2025 10:42
Category: EtherCAT
Hey It seems that I also have encountered this problem... Can you please tell what exactly needs to change sii eeprom file or the compilation of ethercat master with eoe disable option. If possible direct me to the suitable solution.
  • Masiwood123
  • Masiwood123's Avatar
03 Dec 2025 09:53
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
Can someone help me create ``rack_change.ngc`` based on my configuration and pocket coordinates, I tried without python because I don't know where to put path and toplevel because those files don't exist in my configuration, just simple ngc, the example from github doesn't work. The last one I sent only works on the m6 command from mdi so it starts lowering z, it doesn't wait to check if the tool is in the pocket because for each tool I have an inductive sensor that is active high, when there is no tool it becomes active low...rack is very simple, only the y coordinates in the game are from g53 and the change should happen at z-170mm, the M6 ​​t1 command for example just plays play without any movement, and m6 goes to the first pocket because I defined the y offset y-80 in the tooltable.Thanks
File Name: beta1.hal
File Size:11 KB
File Name: beta1.ini
File Size:4 KB
File Name: tool.ngc
File Size:3 KB
File Name: rack_change.ngc
File Size:2 KB
  • rodw
  • rodw's Avatar
03 Dec 2025 09:27
Replied by rodw on topic Reduce read-all timing 7i76e + 7i77
I don't think you can improve much on this without building the kernel from source and changing some of the config parameters. (which is not hard)
here are a couple of links I had saved
ubuntu.com/blog/real-time-kernel-tuning
eci.intel.com/docs/3.3/development/perfo...e/rt_scheduling.html
I did try installing the Intel tools but they did not like Trixie.
the only other idea I explored was to use time sensitive networking (TSN) protocols en.wikipedia.org/wiki/Time-Sensitive_Networking
But I think this would require writing a new hm2-eth driver (hm2-tsn?) and changes to the mesa hardware to support it.
This should solve the issue where networking does not currently support real time (networks are inherently store and forward so never designed for RT comms) but its not a trivial project. This would require TSN capable network cards but these are available at reasonable cost but the common entry level i225/i226 cards do not support TSN. ref: www.intel.com/content/www/us/en/support/...rs-up-to-2-5gbe.html I did find some for USD $70 to $150
  • Aciera
  • Aciera's Avatar
03 Dec 2025 08:30
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Have a look at the 'extra joints' feature. You might have to configure at least one regular joint/axis for motmod to be happy but that still leaves 15 to be used as 'extra joints'. Homing extra joints is handled just like regular joints but are controlled through hal pins after homing. For more info see links in this post:
forum.linuxcnc.org/24-hal-components/577...h-push-button#338305
  • unknown
  • unknown
03 Dec 2025 08:17
Replied by unknown on topic Linuxcnc Image for Raspberry Pi 3
this link has only pi 4 images, not any oi 3. what need doing can use pi 3 and linuxcnc, what is patch and how need doing, or what need doing, not understand , ready to install pi 3 image only need how need patch or what this mean and how change kernel if need no understand anything linux and code, secret engineer language all.
This is getting silly, 3 times you post, I did try to help you with your first post. You didn't say you were using RPi3B to begin with. I did politely ask what your native language was, so we could find someone to help you, as it quite clear English is not your first language.
First of all I think you need to find some Linux info in your own language, this forum is not here how to teach people how to use Linux takes way too much time. Anything Linuxcnc we can help.
  • masawee
  • masawee
03 Dec 2025 07:54
Installing LinuxCNC 2.8.4 on Raspbian 10 (Buster) tested on Raspberry Pi 3B+, Pi
Category: Installing LinuxCNC
what this all code have ??? not understand anything. have linuxcnc image what can add to SD card and run rpi3 ready to use, i not understand this all secret code anything, what need doing or how doing and were doing.
need only image who working and can run rpi 3 board and connect stepper drivers DM556 to rpi and run nema 23 motors. whit linuxcnc.
Displaying 10051 - 10065 out of 12699 results.
Time to create page: 0.478 seconds
