  • TripleM
  • TripleM
22 Oct 2025 12:50
Additional hardware-button for coolant
Category: Gmoccapy
Hello,
I would like to add a hardware button for cooling, for example.
Currently, my *.hal entry looks like this:
net coolant-flood     <=  iocontrol.0.coolant-flood => hm2_7i96s.0.7i84.0.0.output-11
This allows me to switch the coolant on and off via the GUI.
How can I add the hardware button (push button)?
I want to be able to continue switching it on and off in the GUI and see that the cooling is switched on.
  • Cooped-Up
  • Cooped-Up
22 Oct 2025 12:47
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
Well yesterday and this morning before work I was able to not only correct the wiring for the encoders which works now, but also figured out my issue with the 2x20 pin header wiring issue. I now realize a note I read on another document that the output is not alternating between the top and bottom row but is straight across the top then the bottom. Now that the wiring is squared away I just need to figure out the gearbox shifting logic to make the machine in theory functional. Well that and build the operating panel which the screen is on its way.
  • Unlogic
  • Unlogic
22 Oct 2025 12:43 - 22 Oct 2025 13:32
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
The mill has continued to work great but as I started to mill larger parts and use the full 50 cm z-height of the machine my existing chip cover proved to be inadequate with chips ending up all over my garage.
I had already increased the size of the polycarbonate chip guard once before because of this reason so this time I decided to do "the final chip guard". In all honesty a full enclosure would probably be the way to go but I don't have space for that which is why I'm sticking to chip guards that sit on the table instead.
To get started I ordered a large sheet of 4 mm polycarbonate.
I then started a very analog process of designing the actual size and shape using the cardboard box that the polycarbonate sheet was delivered in.
Once I hade the decided size and shape I purchased some aluminum extrusions which I cut slightly too long and then milled to size in order to get square corners.
While at it I decided to add some more polycarbonate on each side of the column to protect everything behind the machine from chips. They attach with magnets so that they can be removed just by pulling them off.
Here is how it looks all assembled.
The door took a bit of thought to figure out what would be the best solution so that it wouldn't be in the way for operations which don't require it to be in place.
In the end I decided to go with this design so that it's very easy to remove. When removed I just set it down on the floor in front of the machine leaning against the stand.
  • unknown
  • unknown
22 Oct 2025 12:39
  • andypugh
  • andypugh's Avatar
22 Oct 2025 12:36
Replied by andypugh on topic Automatic tool changer
What sort of tool changer do you want to build?
A rack toolchanger can work well with a gantry-style machine, but not so well on a knee mill, so the choice does depend to an extent on the base machine.
(and very much on if it's a mill or a lathe, you haven't said)
What spindle do you have? It's a lot easier to set up an ATC with a pneumatic drawbar, for example. (If it's any help I converted my threaded drawbar 1960s mill to a pneumatic pull-stud type drawbar, but was lucky that the mill had a fairly generous drawbar bore)
I have seen some fairly clever hacks to change tools on an ER-collet spindle, though, its not impossible.
hackaday.com/2016/06/20/hackaday-prize-e...omatic-tool-changer/
This one rather cleverly uses a circular move to apply more torque to the collet nut than the spindle can provide.
  • andypugh
  • andypugh's Avatar
22 Oct 2025 12:26
Replied by andypugh on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
Yeah I could but I'd like to have a Trixe & Bookworm base image to work off. I'll get that going tomorrow (doesn't take too long)
One advantage of the Pi is that you can switch OS as simply as swapping the SD card.
  • andypugh
  • andypugh's Avatar
22 Oct 2025 12:12
Replied by andypugh on topic 3D printed stuff, showcase it here
Category: Additive Manufacturing
Multi extruders are a real pain to setup and adjust, and this has to be done any time you change the nozzles.
The Prusa XL has load-cells in the extruders. You just take off the build-plate, put the calibration pin in the hole for that purpose and select "calibrate extruders" (or similar) and it taps each extruder in turn against the pin from 4 sides a few times (just like a probing macro with LinuxCNC).
Admittedly it's not the cheapest of printers, but I don't regret buying it.
  • andypugh
  • andypugh's Avatar
22 Oct 2025 12:06
Replied by andypugh on topic Axis configuration not fully working on 2.9.6
Category: AXIS
Andy, if this is tested as working, can you build an official 2.9.7 release and put it on our repo for bookworm and Trixie?
temp folder does not sound very permanent
I plan on doing so, but I will have to build all the variants by hand on a selection of VMs and RPis as Buildbot2 seems to be broken. It stalls at the end of the RIP builds: buildbot2.highlab.com/buildbot/#/grid
00-checkin has been running for 1 day and 15 hours at the moment, the previous two builds were killed by me from the IRC interface after similar times stalled.
  • Hakan
  • Hakan
22 Oct 2025 12:02 - 22 Oct 2025 12:16
Replied by Hakan on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
Led was easily solved with oneshot to qtplasmac.ohmic_led_in.
It works pretty well now. Time to wrap up this project.
The goal was ohmic sensing with the IPTM-60 (and IPTM-80) torch
without modification to the plasma cutter. I think it came out really nice.
A new box was made, needed to measure on what we call the ground lead.
The box tucked away
Schematics.
All schematics, code etc are available on github
github.com/MetalMusings/MyOwnEtherCATDevice
specifically the Kicad files for the THCLIP board are here
github.com/MetalMusings/MyOwnEtherCATDev...n/Cards/THCLIP/Kicad
  • andypugh
  • andypugh's Avatar
22 Oct 2025 12:00
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Category: Driver Boards
So does this mean that the BLDC module doesn't output commutation before/during the startup indexing procedure? If commutation outputs are suppressed before index pulse is found I may have a problem. I was thinking that it could output them, even if they were off by a little, and hopefully it wouldn't jostle the motor around too much.
I think you are suggesting that you could supply "fake" commutation signals from LinuxCNC to the drive, and that might be enough to persuade the drive to start working?
That might actually work.
If the motor has little enough load on it at startup to magnetically align so that the "fake" commutation becomes true, just long enough for the drive to see the encoder index, then start running off that, you might be able to get things working.
I suppose it's worth a try, it's an hour's work and 3 wires.
  • Gartenzwerg
  • Gartenzwerg
22 Oct 2025 09:29
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
So, Parallel Hat ist da, die Mesa Karte noch im Zulauf.
Komme gerade vom ersten Testlauf aus dem Keller - Grundsätzlich positiv, ein paar Dinge laufen aber noch nicht richtig:
- die X-Achse läuft immer nur in eine Richtung, egal welchen Pfeil ich auf der Tastatur drücke (Ich nehme an da passt der DIRX Pin nicht, der war am alten PC invertiert "setp parport.0.pin-03-out-invert 1")
- Alle 3 Achsen laufen zu schnell (gefühlt immer im Schnellgang den man sonst nur mit Shift+Pfeil aktiviert)
- Die Spindelsteuerung fehlt komplett in der Axis GUI
Ich nehme an da muss ich in den .hal und .ini Dateien nochmal nachbessern. Ich habe vieles von der alten Config übernommen, vermutlich gehört da noch was angepasst.
File Name: diadrive20...0-22.hal
File Size:9 KB
File Name: diadrive20...0-22.ini
File Size:3 KB
  • Unlogic
  • Unlogic
22 Oct 2025 09:24
Replied by Unlogic on topic Probe Basic backplot error when loading file
Category: QtPyVCP
I realized that I forgot to mention which version and branch I'm running.
LinuxCNC: 2.9.4
ProbeBasic: stable branch
  • DerKlotz
  • DerKlotz
22 Oct 2025 09:00
How and where activate X, Y and Z Home? Gladevcp buttons already done
Category: GladeVCP
Hello,
i already created 4 Gladevcp buttons. X, Y, Z and Home all.
Now i need to know what do to activate them. I guess i need to change may machine.ini or hal.
  • Unlogic
  • Unlogic
22 Oct 2025 07:17
Category: QtPyVCP
Noticed that the code tags in the editor completely mangled the stack traces, here they are in a more readable form.
Error 1:
[qtpyvcp.widgets.input_widgets.gcode_text_edit][INFO]  File encoding: ascii (gcode_text_edit.py:538)
[qtpyvcp.widgets.display_widgets.vtk_backplot.vtk_backplot][INFO]
Draw time 1.4562861919403076 seconds --- (vtk_backplot.py:762)
[qtpyvcp.app.launcher][CRITICAL]  Unhandled exception in vtk_backplot.py line 849 (launcher.py:37)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 849, in load_program
    point_01_pos = self.path_offset_start_point[prev_wcs_index]
KeyError: 1
Error 2:
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7081, resource id: 8480708, major code: 40 (TranslateCoords), minor code: 0
[qtpyvcp.app.launcher][CRITICAL]  Unhandled exception in vtk_backplot.py line 1174 (launcher.py:37)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 1174, in on_offset_table_changed
    self.rotate_and_translate()
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 1289, in rotate_and_translate
    self.offset_change_start_actor[wcs_index].SetUserTransform(actor_transform)
KeyError: 2
  • Unlogic
  • Unlogic
22 Oct 2025 07:14
Category: QtPyVCP
It's been a long time since I found any bugs in Probe Basic but this morning I came across a backplot error.
To trigger this bug I loaded the attached g-code file and probed 3 work offsets using the built in probing functionality (G54, G55, G56).
As soon as I probed the final offset G56 I got the first error below.
[qtpyvcp.widgets.input_widgets.gcode_text_edit][INFO] File encoding: ascii (gcode_text_edit.py:538) [qtpyvcp.widgets.display_widgets.vtk_backplot.vtk_backplot][INFO] -------Draw time 1.4562861919403076 seconds --- (vtk_backplot.py:762) [qtpyvcp.app.launcher][CRITICAL] Unhandled exception in vtk_backplot.py line 849 (launcher.py:37) Traceback (most recent call last): File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 849, in load_program point_01_pos = self.path_offset_start_point[prev_wcs_index] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^ KeyError: 1
I pressed the ignore button but after that the GUI became partially unresponsive and for example the jog buttons would not work.
Pressing the stop button on the machine gave me the following error.
[qtpyvcp.widgets.input_widgets.gcode_text_edit][INFO] File encoding: ascii (gcode_text_edit.py:538) qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7081, resource id: 8480708, major code: 40 (TranslateCoords), minor code: 0 [qtpyvcp.app.launcher][CRITICAL] Unhandled exception in vtk_backplot.py line 1174 (launcher.py:37) Traceback (most recent call last): File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 1174, in on_offset_table_changed self.rotate_and_translate() File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 1289, in rotate_and_translate self.offset_change_start_actor[wcs_index].SetUserTransform(actor_transform) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^ KeyError: 2
I did some further testing and discovered that if I do the probing first and then open the file I get the same error. However if I do the probing, close Probe Basic and then start it again and open the file I get no error but on the other hand this forces me to rehome the machine which is not optimal from an accuracy perspective.
Seems like the probing routine somehow causes the backplot to crash or leave a bade state somewhere. I tired poking around in the code myself but I'm too inexperienced to put my finger on the exact cause.
If you need any information don't hesitate to contact me here on the forums or via e-mail (This email address is being protected from spambots. You need JavaScript enabled to view it.).
Displaying 12376 - 12390 out of 12819 results.
Time to create page: 6.486 seconds
