  • mBender
  • mBender
09 Sep 2025 02:44
I need some help here again. I am having a weird issue with my machine. I first thought it has nothing to do with Riocore, but now I am not so sure anymore.
Posted here: forum.linuxcnc.org/12-milling/57122-mach...-programm-repeatable
Oliver or someone with experience, could you explain a bit more what the settings in the Stepper dialog under Step mean?
The Step signal for my machine is inverted. I tried to remove the inversion from the step signal, but than the Stepper don´t move at all. Does that make sense??
  • jschulze
  • jschulze
09 Sep 2025 02:17
Kinematic model for a 5axis mill with universal (nutating) head
Category: Show Your Stuff
Can you post your modified kinemaitics file and your ini file?
Here's all my files.  I've included .ini, .hal, and kinematics comp file.
  • scotth
  • scotth
09 Sep 2025 01:22
Replied by scotth on topic Axis_Comp having no effect[SOLVED]
I did most of my work on big iron. Watching what happens with an AC vent hitting the top of a machine with a laser will drive you crazy.
Good luck!
  • CNC4Life
  • CNC4Life
09 Sep 2025 00:45
Replied by CNC4Life on topic Axis_Comp having no effect[SOLVED]
Yes, it’s a rolled screw it has error from the manufacturing process. Thomson claims +\- 0.004 per ft / 300mm.
Though it could be mathed out in the SPU if I was using UCCNC or MASSO.
  • xunil
  • xunil
09 Sep 2025 00:19
Replied by xunil on topic halui.mdi-command-NN pins not showing up
Category: HAL
I'm happy to report that building the 2.9 branch (incorporating the merged PR mentioned above) from the LinuxCNC github solved the problem - the mdi-command-NN pins show up and function as expected.  Thanks for the fix!
-Rob
  • unknown
  • unknown
08 Sep 2025 23:13
Replied by unknown on topic Trixie libgpiod
Trixie libgpiod
Category: Installing LinuxCNC
Nevermind, I forgot how to correctly read and comprehend English.
  • PCW
  • PCW's Avatar
08 Sep 2025 22:52
Replied by PCW on topic Proximity sensor hardware debounce?
Category: Basic Configuration
I would use an RC filter if in a high noise environment
Also not sure from your description,  whats 24V and whats 5V
no 24V signal should be anywhere near 7I92T I/O pins
  • PCW
  • PCW's Avatar
08 Sep 2025 22:46
Replied by PCW on topic Homing is not working
Category: HAL
Can you do a:
halcmd show all | grep home > beforehome.txt
With LinuxCNC launched and enabled but before being homed
and
halcmd show all | grep home > afterhome.txt
With LinuxCNC launched and enabled after being homed (well at least home button pressed)
and post both berforehome.txt and afterhome.txt here?
  • PCW
  • PCW's Avatar
08 Sep 2025 22:38
Troubles to get started with SD240 Retrofit
Category: Turning
Ahh, looks like the index is single ended, maybe that's the issue.
Unfortunately the 7I33, each encoder input is all differential or all single ended
So one thing to try would be to select single ended instead of differential
encoder mode one the 7I33. This is not ideal as it less resistant to noise
but may be OK.
If setting the 7I33 to single ended encode mode works, there is also
the possibility of using custom firmware that puts all the index inputs
on one 7I33 encoder connector  so you could have differential for A,B
but TTL mode for the Index signals.
Another possibility is to add a TTL to differential converter for the index signals
Mesa has such a thing, but its really just 1 chip on a board
(26ls31 or one of the many equivalents)
  • ziggi
  • ziggi's Avatar
08 Sep 2025 21:07 - 08 Sep 2025 21:18
Category: Turning
No, I also watched the Z- Index and spindle index (not as brief as X) but watched the pins in HAL-Show and they do not change either.
Thats why I thought I made a mistake in the HAL.
The 7i33: otherwise the motors rum smooth as the spindle does and are perfectly controllable (motor and spindle)
The encoder cable- most likely- I will check this asap.
Interesting is that the encoders have Ua1 and Ua2 both also inverted, but the Index Ua0 not (also spindle encoder)
  • PCW
  • PCW's Avatar
08 Sep 2025 20:41
Category: Turning
OK So it looks like the FPGA card is OK.
This leaves the 7I33 and the cable
Do the other index inputs work?
  • Robert312
  • Robert312
08 Sep 2025 20:16
Homing is not working was created by Robert312
Category: HAL
HAl and ini files attached.  We are retrofitting linux cnc to work with a Bostomatic 3 axis milling machine using a mesaboard.  We have accomplished a lot however we cannot seem to figure out why our machine does not follow the homing procedure.  Jogging works, we have remapped M6 successfully... we even made a bust using the machine.  However when the home all button is pressed (using AXIS as gui), the only movement that occurs is the home offset or home (parameter) however many units they are set. We used halshow to reveal the signals as a way to hopefully diagnose the problem, but we have found is that some signals are not present and they should be.  For example the pins with the verb homing do not get signalled, but those that end in homed are set after the home-all button is pressed.
I have read the Homing Configuration in the docs many times through and we have essentially exhausted every combination of home_search_velocity, home_latch_velocity...etc.  The configuration we want to use is one where latch_velocity has an opposite sign than home_search does and we are using the index, and our soft limits are being shared as the home switch. (home_ignore_limits = YES) .  I've been thinking the only solution is to write a custom homing module using homecomp  or an existing one perhaps cia-402.   A response either suggesting other fixes or how to use homecomp would be extremely helpful.  Thank you
  • PCW
  • PCW's Avatar
08 Sep 2025 20:01
need help! mesa 7i95 connection problem
Category: Driver Boards
Sounds like you have a 5V power issue
Either to low a power rating or too long or too thin
5V power wires.
The blinking LEDs indicate that the 7I95T is resetting
This indicates marginal 5V power. Note that the 7I95T draws
significantly more power than a 7I96S.
  • Nicotron
  • Nicotron
08 Sep 2025 19:54
Replied by Nicotron on topic need help! mesa 7i95 connection problem
I have the same problem with Raspberry 5 and 7i95T everything works fine when i use 7i96S but when I connect the 7i95T no light in ETH connector the CR15 and CR16 flash. When I turn 5V up to 5.3V then the 7i95T work
Displaying 13171 - 13185 out of 13748 results.
Time to create page: 1.255 seconds
