  • NWE
  • NWE's Avatar
24 Aug 2026 07:06
Replied by NWE on topic For a full-fledged Press Brake GUI
Category: Other User Interfaces
I guess I happened to jump to  this thread. Check it out.
  • meister
  • meister
24 Aug 2026 04:47
  • jschulze
  • jschulze
24 Aug 2026 03:41
Replied by jschulze on topic For a full-fledged Press Brake GUI
Just wondering if you've been making any progress on the pressbrake gui?  I just got the press I'm working on moving today and I was going to start working on an interface, but I thought I'd check in on this first before I start from scratch.
  • galmiklos
  • galmiklos
24 Aug 2026 02:43 - 24 Aug 2026 02:58
linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed
Running linuxcnc 2.9.10 with linuxcncrsh loaded. When a client connects and executes a get spindle or get spindle_override command, linuxcncrsh crashes with segmentation fault.
This is the line in custom.hal.
[code]loadusr linuxcncrsh --port 5007 --connectpw EMC --enablepw EMCT00
linuxcncrsh started like this
[code]gal@linuxcnc-vm:~/linuxcnc/configs/sim.qtdragon_hd.qtdragon_hd_xyz$ linuxcncrsh -p 5007 -w EMC -e EMCT00 -- -ini /home/gal/linuxcnc/configs/sim.qtdragon_hd.qtdragon_hd_xyz/qtdragon_hd_xyz.ini
Connected to telnet
Segmentation fault
These are the commands on the client side.
[code]gal@roki:~$ telnet 192.168.3.125 5007
Trying 192.168.3.125...
Connected to 192.168.3.125.
Escape character is '^]'.
hello EMC telnet 1.0
HELLO ACK EMCNETSVR 1.1
get spindle
get spindle
Connection closed by foreign host.
 [/code][/code][/code]
  • spumco
  • spumco
23 Aug 2026 22:48
Probe Basic - user tabs/buttons/etc not appearing
Category: QtPyVCP
Got things working, badly.
Turns out the sub-folders have to be named the same as the .ui files.
And the user_atc_buttons MUST remain 'template_user_atc_buttons' as that seems to be hard-coded somewhere - maybe in probe_basic.py
Next problems:
  • Sidebar tab is appearing in the main window
  • Neither user tabs (main or sidebar) are labeled
  • kzali
  • kzali
23 Aug 2026 21:55
Hi Tim if you can post the Gerbers or Kicad that would be useful since Riocore is a open source project.
Cheers
Kam
The software/Gateware is open source; as for the hardware, it’s up to each individual. It can certainly be closed source and used commercially.
Ofcourse I already have the TangoBOB.  My post was only to see if Tim's board was not a comercial product.  It is wess designed your dedication is commendable.
Thanks K Zali
  • kzali
  • kzali
23 Aug 2026 21:51
Thanks Tim
I already have a Tangobob. I just comented on this forum for others. Your board is very well designed.
warm regards
Kzali
  • murdemon
  • murdemon
23 Aug 2026 21:50
Replied by murdemon on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
I am compiling kernel with RT patch and hostmot2 bitstream for board. Install linuxCNC in headless config, all main modules works, except smartserial, now working on it. LinuxCNC 2.9 , hostmot2 FPGA from Zboard .. If interesting can share Vivado 2025.2 project and SD card image.
  • MikkelRS
  • MikkelRS's Avatar
23 Aug 2026 20:40 - 23 Aug 2026 20:40
AXIS hangs on long part- controls rendered inoperable while CNC still moving
Category: AXIS
On my VMC that I retrofit, Im running lcnc 2.8.0 (did so a few years back), using AXIS... ive had an intermittent problem of axis completely freezing while the machine continues to operate, but not able to use any keyboard input and having to estop and kill axis via taskmanager to restart the machine.
I would consider this hugely dangerous... anyone else have an issue like this?
Its been especially long programs where the toolpath display has had to remove previous run path highlights as it goes that have caused this issue.
Lcnc 2.8.0, mesa 7i76e, dell touchscreen, i5 something or other with 8gb ram. edit: running on linux mint 19.1
Stable for short parts very well, but running long programs has now got me a little scared.
Is this one of those times where an upgrade is warranted?
  • meister
  • meister
23 Aug 2026 17:50
Cheers
Kam
  • Aciera
  • Aciera's Avatar
23 Aug 2026 16:52 - 23 Aug 2026 16:54
Help needed for conversion of old ( and loved ) Mach3 MPG
Category: Basic Configuration
you are right, but i see almost any buttons of my keyboard,
Sounds like you are not acually grabbing the right device.
What GUI are you using? Gmoccapy offers the option to disable keyboard shortcuts.
  • spumco
  • spumco
23 Aug 2026 16:36
Replied by spumco on topic Threading Index Varies With Speed
Thank you so much for looking in to this.
I'll test in the next few days on my machine and report back.  You want results here or on GH?
  • spumco
  • spumco
23 Aug 2026 16:34
Category: QtPyVCP
(LCNC 2.9.8, new APT develop installation of Probe Basic)
Trying to get all the user buttons, ATC buttons, user tabs, etc to show up and I'm struggling.  PB starts up ok.
Edited INI file:
ATC_TAB_DISPLAY                 = 1
USER_BUTTONS_PATH               = /home/mill/linuxcnc/configs/MILL_ETH_1.3/probe_basic/user_buttons/
USER_TABS_PATH                  = /home/mill/linuxcnc/configs/MILL_ETH_1.3/probe_basic/user_tabs/
USER_ATC_BUTTONS_PATH           = /home/mill/linuxcnc/configs/MILL_ETH_1.3/probe_basic/user_atc_buttons/
USER_DROS_PATH                  = /home/mill/linuxcnc/configs/MILL_ETH_1.3/probe_basic/user_dro_display/
DRO_DISPLAY                     = xyza
KEYBOARD_JOG                    = false
Copied all the template folders to my config folder.
Edited the copied template UI files slightly so I could see if 'my' versions were loading, but left them named 'template_user_nnn..."
Started PB and no user main/sidebar tabs were present.  User button area was empty/blank, as was the ATC user button area.
Is there something else I have to edit?  Any of the .py files need paths or file renaming?
  • ckaza13
  • ckaza13
23 Aug 2026 15:23
TANDEM Y AXIS CLOSED LOOP STEPPER MOTOR OSCILLATION WHEN IDLE
Hello all,
threre is a stepper motor ticking issue going in my cnc mill that has been bothering me for a while now. I have devoted a fair amount of effort trying to "trial and error" my way out of it by playing around with tuning parameters but i cant reach a satisfactory solution, so hopefully someone here can provide some much needed assistance or reference to a similar case if the topic has already been covered before.
CONTROL SETUP DESCRIPTION
In my setup i use a rpi4b as the linuxcnc host along with an EC300 bob in which i have flashed the 3.1.3 version of the remora firmware for the RT1052 processor. Rpi and EC300 exchange packets over ethernet. 4 integrated closed loop stepper motors are driven by the the EC300 board using the corresponding STEP/DIR pins. Feedback from the motor's encoder does not reach linuxcnc so it essentially acts an an open loop system.
INITIAL ISSUE DESCRIPTION
In the capture5.txt i have recorded the following signals of J1 (one of the two joints driving the Y axis, the other is J3) in the servo_thread period while the joint reached the idle state after executing a jog command in my initial attempts to get my machine going.
1st column       : j1pos-cmd
2nd column      : j1pos-fb
3rd column       : j1freq-cmd
at the time of the recording J1 was configured this way (scale and the rest of the dynamic parameters remained the same to my current configuration) :
  • remora.joint.1.pgain = 5
  • remora.joint.1.ff1gain = 1
  • remora.joint.1.deadband = 0.02
having all of the above parameters configured in the .hal file, the joint could not reach a steady state even though a single step equals to 0.0016 mm as you can see in the screenshot which is way below the deadband specified. The pos_cmd was constant but apparently a freq_cmd was calculated and sent to the EC300 that lead to the oscillation (how is that possible that the deadband gets defeated??).
CURRENT STATUS
In the attached .ini, .hal , remora-config-file.txt you can see how my machine is currently configured. Apparently by not specifying a p_gain and ff1_gain they both default to 1 according to the remora-eth-3.0.c  and with a deadband of 0.005 the Y axis is able to reach a steady state. The reason i am not satisfied is because the motion isn't smooth when approaching the final position, instead the motors "click" in place after a few steps and the axis makes a squeeking noise. When i try to modify the gain parameters to smooth the axis i roll back to the initial issue of not being able to reach a steady state.
Probably i did a poor job explaining the chronicle of my situation but hopefully i ll be able to further clarify in follow up questions.
Thank you
  • Holzwurm56
  • Holzwurm56
23 Aug 2026 14:57
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo,
ich arbeite an meiner "Simulationsdrehbank" immer etwas weiter. Ich habe jetzt noch einen Spindelencoder eingebaut. An der 7I96
habe ich folgende Anschlüsse: +5V, Gnd, EncA+, EncA-, EncB+, EncB-, Index+ und Index-. Mein Encoder hat nur +5V, Gnd, KanalA,
KanalB. Kann ich den trotzdem benutzen? Kann ich den so anschließen:
+5V         >     +5V
Gnd         >     Gnd
EncA+     >      KanalA
EncB+     >      KanalB       ?
MfG
Hans
Displaying 1351 - 1365 out of 12530 results.
Time to create page: 0.368 seconds
