  • GDTH
  • GDTH's Avatar
27 Aug 2025 07:33 - 16 Sep 2025 17:18
Solved: Help with Busellato JET 2 spindle retrofit – VFD overload
Category: Driver Boards
Hi all,I’m in the process of retrofitting a Busellato JET 2 CNC machine. The machine has one main spindle, a side spindle, and drills, but I only need to control the main spindle.The spindle is still running on the original VFD, which has not been altered or replaced.Originally, the VFD was controlled via serial communication, but since I’m using a Mesa 7i77 card, I converted it to 0–10 V analog control (the serial setup seemed unnecessarily complex and hard to understand).Here’s what I’ve tried so far:
  • Using the original VFD (unchanged).
    • Converted VFD control from serial → 0–10 V (Mesa 7i77).
      • Adjusted VFD parameters to allow external analog speed control.
        • Able to start the spindle successfully.
          • Spindle ramps up but only reaches ~50 Hz.
            • After about 10 seconds at 50 Hz, the VFD trips into overload.
              My observations:
              • It sounds like the spindle wants to accelerate further but is somehow being held back.
                • I’ve spent several hours tweaking and checking parameters, but I can’t figure out where it’s going wrong.
                  Any tips, suggestions, or guidance on how to properly configure the VFD (or what to check mechanically/electrically) would be hugely appreciated.Thanks in advance!
                  Omron F7 guide
                  Omron F7 full manual
  • Hakan
  • Hakan
27 Aug 2025 04:33
Carousel component + ethercat absolute servo as ATC motor setup
No idea how the carousel works, but maybe you can try the Profile Position mode (PP) instead of CSP.
  • Hakan
  • Hakan
27 Aug 2025 04:24
What do i need exactly for ethercat ? Recommended hardware??
Category: EtherCAT
Maybe start with a fresh install of the latest debian "trixie". Linuxcnc is available as an apt package directly, just sudo apt install linuxcnc-uspace and so on forum.linuxcnc.org/9-installing-linuxcnc...ade-install-to-2-9-4
Ethercat needs to be installed after that, follow the guides here first forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories and then forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Ethercat server consists of two kernel modules, run in kernel space that linuxcnc communicates with.
Linuxcnc uses traditional HAL files for configuration. Translation between HAL pins and EtherCAT PDOs is provided by the linuxcnc lcec module which requires a configuration file "ethercat-config.xml". Often a source of questions, the easiest way to generate a good starting point is the Linux command "lcec_configgen". Reference for linuxcnc-ethercat (lcec) can be found github.com/linuxcnc-ethercat/linuxcnc-ethercat but it seems not many people read it.
Your servo drives seems to use the common cia402 drive profile. A must read is the example config found at github.com/dbraun1981/hal-cia402.
There is no easy (well...) way to configure an Ethercat machine. Typically you start with a sample configuration from the LinuxCNC simulator or generate a configuration using either stepconf or pncconf and then replace the motion and IO pins with the Ethercat motion and IO pins from ethercat-conf.xml.
Regarding the encoder resolution, there is a scaling number one need to provide, counts/mm or counts/inch, check the cia402 example hal file. After that, the cia402 module reports position directly in mm or inch in the pos-fb pin.
  • scotth
  • scotth
27 Aug 2025 03:48 - 27 Aug 2025 03:49
AXYZ Retrofit - VFD / AC Inverter electrical
Category: CNC Machines
The manual covers dynamic braking on page 88. You might need to contact Woods for resistor wiring info.
Here is the link.
     s3.amazonaws.com/Icarus/DOCUMENTS/TBWoods_Manuals_1214.pdf
file too large to attach.
  • Lcvette
  • Lcvette's Avatar
27 Aug 2025 03:12
Replied by Lcvette on topic Probe Basic Screen missing axes
Category: QtPyVCP
Docs have the required settings and files that are needed, read through the notes section and make sure you have the folders required in your config folder and the correct in settings.
  • Lcvette
  • Lcvette's Avatar
27 Aug 2025 03:05 - 27 Aug 2025 03:10
Probe Basic tool touch off gives "Probe tripped during non-probe move"
Category: QtPyVCP
Try removing slow probe by setting to zero and set fast probe to around 8ipm. You're likely going to slow causing the trigger to bounce physically rather than make a clean break. The work fine as written and are used by thousands of users so I would find the right balance of speed and accuracy.
  • lj
  • lj
27 Aug 2025 02:27
ESP32 HAL2UDP setup for linux CNC noob.
I think I found the problem. I am using a straight through instead of the cross over Ethernet cable I should be using
thanks for the help
  • Gusgus
  • Gusgus
  • ErrickW
  • ErrickW
26 Aug 2025 23:18
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
Tom, for some reason I never received your last post on 8/11/25. Contact me at 'linux at its-been-a-long dot com" I can help you with most any manual you need.
  • Gusgus
  • Gusgus
26 Aug 2025 23:17
File Name: remora-xyz.ini
File Size:3 KB
File Name: remora-xyz1.hal
File Size:2 KB
File Size:3 KB
True, let me post the files.
  • h_munktell
  • h_munktell
26 Aug 2025 21:13
Replied by h_munktell on topic Basic probe fails on latch return
Category: Qtvcp
This might be related
github.com/LinuxCNC/linuxcnc/issues/3486
I have something with spindle-at-speed in HAL, have not looked into it as I just see this now, and need to sleep.... If possible....
  • h_munktell
  • h_munktell
26 Aug 2025 20:46
Category: Qtvcp
Can now confirm that versaprobe has the same issue for me.
  • scotta
  • scotta's Avatar
26 Aug 2025 20:39
Hi, it may be helpful to share your config.txt, hal and ini files so that we may see your setup.
The following error is generated internally, not by the driver not being enabled. Hence maybe a config issue.
  • Cysign
  • Cysign
26 Aug 2025 20:09 - 26 Aug 2025 22:03
Replied by Cysign on topic Interfaces & linear scale for LinuxCNC
I have the magnetic linear encoders (MSR5000) in front of me. Next to the magnetic (10mm width) tape is a steel tape (10mm width), so which standard aluminium profile would you suggest for mounting it?
  • hitchhiker
  • hitchhiker
26 Aug 2025 19:28
Replied by hitchhiker on topic Homing with 2 inputs/sensors?
Category: HAL
works now perfect
Displaying 13606 - 13620 out of 13829 results.
Time to create page: 0.671 seconds
