  • DarkPhoinix
  • DarkPhoinix
04 May 2025 19:51
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
sorry i dont understand, maybe i missed some step,
here you say everything is ok.
what is not working? Have you tried on other axes?
yes the direction of rotation and all the axes respond, you have some axes that don't work at all! Mine work but not smoothly!
  • GuiHue
  • GuiHue's Avatar
04 May 2025 19:49
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
Hi, are the xml files from the aforementioned Sasha’s shop somewhere to be found? Would love to have a look.
  • Hakan
  • Hakan
04 May 2025 19:32
Lcnc & Ethercat data types, Ethercat automated hal pin setup.
Yes that 64-bit integer data-type is missing in hal, but I think I heard that might change for next release. Don't quote me on that though.
In the other hand, there is the flexibility to use all EtherCAT's data types (almost then) and convert data into hal data types to send and receive so in one way it is very flexible. Downside is it requires a bit of understanding from the user who may not be so interested in this, just want to use it kind of.
  • jjdege
  • jjdege's Avatar
04 May 2025 19:30
  • jjdege
  • jjdege's Avatar
04 May 2025 19:25 - 04 May 2025 19:27
  • Grad
  • Grad
04 May 2025 19:14
unable to get gpio to work on Raspberry Pi 5 using latest image
Well, that thread helped me before but i somehow did not notice the "Basic Mill Config Using hal_gpio" ...would have saved me a lot of time... anyways - works fine now - Thank you!
04 May 2025 18:24
Replied by tommylight on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Lots of other men contributed to its discovery and invention too.
If you mean the induction motor, no, no one even tried it before him. He knew his s#it, for sure.
Induction motor has no magnets, no rotor coils, no brushes, yet it works!
It has been the single most important discovery that pushed civilization and the industrial complex forward.
  • unknown
  • unknown
04 May 2025 18:21
forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#321296
WTF would you use AI ?????????
BTW Just about everything to do with the Rpi5\4 images is in the thread linked above, rather than waste time with AI read something, a lot of work has and is going into that thread.
  • jochen91
  • jochen91
04 May 2025 18:00 - 04 May 2025 18:10
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
The B Axis can be locked but also rotate freely for full simulatanious 5 axis milling.
The milling spindle in the B-axis can be locked in 12 positions for broaching and turning or rotate freely as a milling spindle.
I don't THINK that TCP needs to be applied for turning. To be honest im not particular sure. I know from a metal working perspective that an endmill can have z and x tool-offsets and turning tools can have x/y/and z. How and if that needs to be incorperated into the kinematic...?
Here is a link to see the machine in operation to get a better understanding what is possible:
Warning: Spoiler!
Machining starts at roughly 4:51
Its a rather simple part for a Millturn but it gives at least a rough understanding of the operation of such a machine.
Tomorrow i wil work more with Fusion and the Doosan millturn PP and see what else of proprietary G-code will be posted.
  • Grad
  • Grad
04 May 2025 17:37
Hi, i have a similar problem with my RPi5 and GPIO but I think I/(the AI that helped me) screwed up with the .hal-File. Do you (or anyone) mind to put your working .hal here so I can see how it is done?
  • hmnijp
  • hmnijp
04 May 2025 17:07 - 04 May 2025 17:10
All available hal components work with s/u32 pins
There is no point in having 16bit numbers from ethercat, because to connect to subsequent components they will have to be converted to 32bit anyway by loading additional components to convert 16->32.
The LCEC component does this automatically in the XML configuration.  pdoentry
In practice, there will probably never be any memory problems, as the number of pdos and sm is quite limited.
There have also been suggestions in the forum to make all HAL pins 64bit for standardisation, as encoders have a problem with overflowing 32bit numbers.
  • Hakan
  • Hakan
04 May 2025 16:05
Replied by Hakan on topic Using POSIX realtime
Category: EtherCAT
Search for the ec_generic.so files like  I did.
  • hans48
  • hans48
04 May 2025 15:51
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo nochmal
Fotos sind zu groß habe sie daher kleiner gemacht.
  • DarkPhoinix
  • DarkPhoinix
04 May 2025 15:39 - 04 May 2025 15:43
Warning: Spoiler!
Of course, I also put the photo of the parameters on mach3, but on mach3 I have another control board and it has 4 wires with ENABLE, I wrote it in the first post. Here Enable is disconnected but I also tried to connect it to +5V (+com)
  • hans48
  • hans48
04 May 2025 15:36
Category: Deutsch
Hallo
Nachtrag: Ein Foto wurde nich Übermittelt.
Gruß Hans und Danke
Displaying 16201 - 16215 out of 17066 results.
Time to create page: 0.732 seconds
