  • darrylb123
  • darrylb123
14 Mar 2025 09:41
Replied by darrylb123 on topic SCATECH EV1616DN - Example config
Category: EtherCAT
stiickies?
I have a working config using 2 parallel ports. Can I start with that?
I am using closed loop steppers.
I undestand that I will have to add invert pins etc.
The reset pin has me confused. Is it to generate a particular pulse width?
  • rodw
  • rodw's Avatar
14 Mar 2025 08:55
Replied by rodw on topic QTPlasmaC post processor - SheetCam?
Category: Plasmac
I just watched your YouTube video on you high speed ohmic and it’s impressive.
I assume you mean this one
I had a job which I filled a 8' x 4' sheet with some flanges and small parts. I cut it in 3 sections on a 4' x 4' table and there were heaps of probing so over time I tweaked the probing routine heights etc. I was using my hypersensing which uses a THCAD for the ohmic sensing. it does not like Hypertherm machines on a water table but it would work for you by the look.
Part of the speed comes from the way it breaks contact on up travel because as soon as it senses a fall in voltage, probing finishes (before the contact is broken).
I've been sent a ohmic circuit from Proma Elextronika in Poland. Its a very nice piece of kit and have some very good reviews on it. This will by my water table solution.
  • HansU
  • HansU's Avatar
14 Mar 2025 08:47
HAL Oscilloscope application has no Chan Off button...
Category: LinuxCNC Documents
The documentation is outdated, try clicking on the colored channel buttons on the bottom of the screen to toggle channels on/off. Eg the red button with '1' on it.
Fixed in github.com/LinuxCNC/linuxcnc/commit/e412...449b7450922240e9b9c1
  • matasbuk
  • matasbuk
14 Mar 2025 08:42 - 14 Mar 2025 08:43
QTDragon_hd won't display a larger file.
Category: Qtvcp
    Hello, I have a machine with 32gb of RAM and an i5, QTdragon fails to visualize gcode files over 20-30mb. The RAM is not even loaded. What could be the problem and how to solve it? Instead of a program, a box within machine bounds is displayed.
  • Daan96
  • Daan96
14 Mar 2025 08:21
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
Sorry for the late message. Unfortunately I had to give the project less priority.
At the moment very busy with my full time work, my own company and graduating from my bachelor mechanical engineering next to a more than full-time job.
I am slowly designing further on the mechanical part during my breaks. The hardware will be a pc that runs on plasmac in combination with a mesa board and a thcad.
The drive will be a belt, I do not believe that this stretch is noticeable under the load of plasma cutting. Much cheaper and simpler in design than rack and pinion.
  • elovalvo
  • elovalvo
14 Mar 2025 07:18
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Dude please don't change the subject, it makes things hard. I check this thread regularly.
I think it is useful to change the title from
"Linuxcnc & the Rpasberry Pi"
to that
"Linuxcnc & the Raspberry Pi"
  • rodw
  • rodw's Avatar
14 Mar 2025 07:08
Replied by rodw on topic SCATECH EV1616DN - Example config
Category: EtherCAT
you need to write your hal by hand. check the stiickies and start with an example config.
  • unknown
  • unknown
14 Mar 2025 07:00
  • unknown
  • unknown
14 Mar 2025 06:55
Replied by unknown on topic Trouble getting a new configuration running.
can you share the AXYZ_connect.hal file?
The opening post has all the files as attachments, just download and save them.
  • unknown
  • unknown
14 Mar 2025 06:52
Replied by unknown on topic SCATECH EV1616DN - Example config
Category: EtherCAT
The hal_parport driver creates the pins & such and also talks directly to the parallel port hardware. I'm not sure if want you do is possible. I would imagine it would require a very special real time driver. I would also guess you wouldn't get any extra performance over using a parallel port as the step & direction timings would be created by the Linuxcnc software.
  • medicusdkfz
  • medicusdkfz's Avatar
14 Mar 2025 05:58 - 15 Mar 2025 10:49
Replied by medicusdkfz on topic scurve trajectory planner
A great thank you to the team and testers! This is gonna be a big milestone for LCNC…
Well, well done!
Pierre
  • darrylb123
  • darrylb123
14 Mar 2025 05:48
Category: EtherCAT
I just got a SCATECH EV1616DN module with the view of using it instead of parports. I have the hal operating the module.
I used github.com/pklopping/linuxcnc-ethercat-b...asic_digital_outputs for reference.
I'm lost as to how to integrate this back into a linuxcnc hal file generated by stepconf.
I assumed that I could simply change the parport references to lcec but, for example' there are no -reset pins etc.
Can you point me at an example of a compete configuration using ethercat?
  • unknown
  • unknown
14 Mar 2025 04:01
Replied by unknown on topic 7i95 randomly throws error with raspi b
Category: Driver Boards
I think PCW was referring to the power supply for the mesa card.
You may also be experiencing issues with the RPi4 ethernet powering down, this is a much talked about issue.
If you look at the RPi sticky under installing Linuxcnc the very last post discusses this issue with a link to some trouble shooting.
  • Nathan40
  • Nathan40
14 Mar 2025 03:06
Replied by Nathan40 on topic 7i95 randomly throws error with raspi b
It is a raspi 4 8 gb version. I tried with a changed power supply and after few hours it again reset. Upon pressing the reset button the axis showed no movement. However, after restarting linuxcnc it started working fine.
Displaying 17716 - 17730 out of 18506 results.
Time to create page: 0.821 seconds
