  • R0ttencandy
  • R0ttencandy
15 Jan 2025 17:22 - 15 Jan 2025 18:00
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
Hello everyone, I'm very new to everything Linux related but frustrations with my current machinery has led me down a rabbit hole. Here we are.
I saw people asking for feedback on running the 2.9.2 package on a raspberry pi. I have a Raspberry Pi 4B 8G model that I have attempted to boot the 2.9.2 image to with very little success. I used the XZ file on the downloads page and put it into the Raspberry Pi imager, the board was booted with a small touchscreen plugged into it's display port via ribbon cable. ACT/power lights appeared promising until I got a peculiar message showing up on screen with some skulls. I have attached it here.
After the skull message, power light turns off and the ACT light switches to a faint, consistent flicker while the display continues rotating through solid colors.
It's entirely possible that since this is the second time ever using one of these that I have royally screwed up somewhere. I have also read some negative reviews as far as the compatibility of the 8G model goes so it could have something to do with that. Any and all info you guys could provide would be greatly appreciated. Thank you!
[Edit], the XZ file taken off the homepage for version 2.9.2 failed to flash using BalenaEtcher
  • Artur_1617
  • Artur_1617's Avatar
15 Jan 2025 16:33 - 15 Jan 2025 16:37
Replied by Artur_1617 on topic linuxcnc 2.9.2/2.9.3 toolchanger problem
The solution was so easy...
In toolchange.ngc file I copied that lines
M68 E0 Q#<selected_pocket> ;set the carousel to move to the right pocket
M64 P0 ; start carousel
;G4 P2
M66 P0 L3 Q60 ; wait for carousel finished
O210 if [#5399 LT 0]
(abort, failed to align carousel)
O210 endif
M65 P0 ; stop carousel
And inserted them to after that line
O100 IF [#<tool_in_spindle> GT 0]
Now I can turn carousel to any position for changing tools. And after that making M6T. carousel back to pocket from before loaded the tool and unload them in right pocket..
But still after change the tool popup screen to confirm like in manual change...
Any help with popup screen??
File Name: toolchange...1-15.ngc
File Size:5 KB
  • Martin.L
  • Martin.L
15 Jan 2025 16:27 - 15 Jan 2025 16:36
MS300 with CMM-EC02 to retrofit an existing electrospindle spindle
Category: EtherCAT
Hello guys,
I'm looking for an advice to buy the right VFD for the spindle with the following specs :
P = 2 KW
L = 4.5 A
2 poles
380 three phase
Hz 267 @ 16000 rpm
HZ 667 @ 40000 rpm
here are the specs of the ms300 VFD11AMS21AFSAA i'm thinking to buy :
2.2 KW
Input 220 single phase (so I don't require 380 three phases at all)
600 hz
Output current 11A
Built in EMC filter
Here are the CMM-EC02 ethercat expansion board features
► Supports EthernetCAT protocol
► Supports standard CiA402 speed mode
► Supports SDO (Service Data Objects) function: Drive status reading and parameters editing
► Auto shutdown function for interruptions during data transmission
► Supports remote I/O function
I'm not experienced to choose a right one without asking, this model should fits? It caps at 599hs so I should reach appox 36000 rpm? (old one seems 480hz).
Here is the delta ms300 catalog  filecenter.deltaww.com/Products/download...00_C_EN_20210714.pdf
www.farnell.com/datasheets/3171459.pdf
  • KrisR
  • KrisR
15 Jan 2025 16:24
Kappa goniostat was created by KrisR
Kappa goniostat
I have an old kappa-goniostat (crystallography) that should be disposed and it's breaking my heart. It has 3 rotational axis for the sample in middle of the goniometer and an additional rotation+translation axis where originally detector was mounted.
I had this crazy idea that one could use it to work on spheric shapes in the wood (think about Escher's "Angels and Devils").
Two main problems:
1) I'm newbie to linuxCNC
2) goniometer has a strange geometry. I've attached image how it works.
The object rotates in center of system with three axis omega, kappa and phi. The kappa-angle is 50° to base (or 130°).
I tried to read examples about 5-axis geometry but all of them describe systems with orthogonal axis.
Any suggestions on how I should start this project? I have no idea how to tackle kinematics.
And before I spend hours reverse engineering encoders on DC motors, I need to know whether it is actually possible with LinuxCNC.
all best, Kris
  • Plasmanfm
  • Plasmanfm
15 Jan 2025 16:22 - 15 Jan 2025 16:28
Replied by Plasmanfm on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
was ist das für ein Schaltungs Müll !!!
Mal den N und mal den L zu schalten ist absoluter Müll man schaltet nur den den L !
What kind of circuit garbage is this !!!
To switch the N and sometimes the L,
Juegen
  • PCW
  • PCW's Avatar
15 Jan 2025 16:02 - 16 Jan 2025 00:22
How do I configure the connection of two mesa 7i92 via ethernet?
That's odd, I have run up to 4 hm2 cards from one switch
I will try and duplicate this.
I cannot duplicate this error, here's a screenshot of LinuxCNC running with two 7I92T's,
one at 10.10.10.10 and the other at 10.10.10.11, both running from a single Ethernet
port going to a switch:
and here are the hal and ini files for the test setup:
File Name: 7i92x2.zip
File Size:4 KB
  • Aciera
  • Aciera's Avatar
15 Jan 2025 15:18 - 15 Jan 2025 15:22
Replied by Aciera on topic Using G64 with M66 for smooth robot control
The problem is that M66 is a 'queuebuster' command that halts the interpreter until gcode execution has caught up which makes it impossible to blend moves before it with moves that come after.
The only other possibility to influence axis position during gcode execution is external offsets:
linuxcnc.org/docs/html/motion/external-offsets.html
  • PCW
  • PCW's Avatar
15 Jan 2025 15:13 - 15 Jan 2025 15:46
How do I control the speed and acceleration of the analog output of the 7i77 ?
One thing I see is that the Z encoder scale is off by orders of magnitude.
If you are using the ~100 to 900 KHz range of the THCAD2, I would expect
and encoder scale to be roughly 800,000 / Z_motion_range.
What is the Z motion range for 0 to 10V out from your sensor?
It addition the scale may need to be negative. This is the first thing to get setup correctly
Also as I mentioned, you may need to feed the encoder velocity signal through LinuxCNCs
offset component to remove the offset at 0V
  • Aciera
  • Aciera's Avatar
15 Jan 2025 15:07
Replied by Aciera on topic LinuxCNC with OKUMA OSP MX-55VA
Category: Basic Configuration
Another thread not a post.
  • PCW
  • PCW's Avatar
15 Jan 2025 15:02
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
Category: Driver Boards
Yes, you first write firmware to the FPGA RAM which gives you Ethernet access to the card.
Then you write the user and fallback firmware to the user and fallback areas of the EEPROM
with mesaflash.
(Your example shows the same file written to both, this will not work, you must write a fallback
file to the fallback area and a user file to the user area)
The init95t script in the .tgz file does all this but you can remove all the MAC/Netmask/IP address
writing stuff as these have already been done and are not affected by what you write to the flash memory.
  • programador
  • programador's Avatar
15 Jan 2025 14:32
How to use the velocity encoder signal as position feedback for the 7i77 board?
Category: HAL
Good morning
Thank you for your attention, but unfortunately I was not successful, even trying several attempts to find scale values, I posted in a new topic if you can help me, I appreciate it
forum.linuxcnc.org/10-advanced-configura...g-output-of-the-7i77
  • programador
15 Jan 2025 14:22
  • programador
15 Jan 2025 14:19 - 15 Jan 2025 14:22
This reading is being shown on the display after the following modification
#net z-pos-fb <= hm2_7i96s.0.encoder.00.position # Disabled Line
net z-pos-fb <= hm2_7i96s.0.encoder.00.velocity #New Line
net z-pos-fb => joint.1.motor-pos-fb
#net z-vel-fb <= hm2_7i96s.0.encoder.00.velocity # Disabled Line
net z-index-enable joint.1.index-enable <=> hm2_7i96s.0.encoder.00.index-enable
net z-pos-rawcounts <= hm2_7i96s.0.encoder.00.rawcounts
  • programador
15 Jan 2025 14:17
I can't find a suitable configuration so that the analog output can control the correct movement of the punching machine's piston. How do I solve this?Summary of what I'm trying to control:The piston that hits the punches is hydraulic, but it has an actuator that controls its descent and ascent by applying analog voltage of -10 volts and +10 volts, where +10 volts goes up and -10 volts goes down. However, unlike a motor, when there is no voltage at all, the piston descends gradually. To keep it high, a voltage above 2 volts positive will always be necessary.Hardware information: the sensor that detects the movement of the piston hitting the punches is magnetic and provides an analog output voltage, being 0 volts when it descends completely and 8 volts when it rises completely. This position voltage is connected to the THCAD2 electronic board that converts it into frequency. This frequency is used in channel 0 of the 7i77 electronic board's encoder, which is configured as
setp hm2_7i96s.0.encoder.00.counter-mode 1
#net z-pos-fb <= hm2_7i96s.0.encoder.00.position # Disabled Linenet z-pos-fb <= hm2_7i96s.0.encoder.00.velocity #New Linenet z-pos-fb => joint.1.motor-pos-fb#net z-vel-fb <= hm2_7i96s.0.encoder.00.velocity # Disabled Linenet z-pos-fb => joint.1.motor-pos-fbnet z-index-enable joint.1.index-enable <=> hm2_7i96s.0.encoder.00.index-enablenet z-pos-rawcounts <= hm2_7i96s.0.encoder.00.rawcounts
I'm worried that the problem is because
net z-vel-fb
was disconnected since it is being used to report the position, will the 7i77 electronic board work without net z-vel-fb?
Below is information that may helpWhen I manually jog the Z axis to 1mm or 5mm, it makes no difference in the actual movement of the piston, it always moves the same and the Z axis calculation error appearsWhen I manually jog the Z axis to 1mm
  When I manually jog the Z axis to 5mm  Piston hitting the punches in the zero position
  Piston hitting the punches in the position after a 1mm jog
 Piston hitting the punches in the position after a 5mm jog  I have been working on this machine retrofit for over 2 years, unfortunately here in Brazil I have not found qualified labor to perform this service. If I cannot resolve this step I will have to give up on LinuxCNC. I am willing to pay if someone resolves this situation. Even so, I thank all the contributions from the Forum and Mr. Peter.
  • hellvetica
  • hellvetica
15 Jan 2025 14:09
Replied by hellvetica on topic Using G64 with M66 for smooth robot control
Yes i played with the python MDI interface but it seemed to me like I couldn't get precise timings for my moves.
We're trying to pick up moving objects from a conveyor belt and MDI seems to have a delay.
Also, we want our robot to be VERY fast and we're going to be pushing it to its limits. MDI doesn't seem to fit into that.
Displaying 19801 - 19815 out of 21715 results.
Time to create page: 0.612 seconds
