  • Aciera
  • Aciera's Avatar
16 Oct 2024 18:57 - 16 Oct 2024 18:59
Replied by Aciera on topic Welche Tasten haben die Achsen?
Category: Deutsch
Wenn ich mich recht errinnere werden normalerweise
'[' und ']'
für die 4. Achse verwendet.
Kann man glaub ich auch im Menü nachschauen: 'Help' > 'Quick Reference'[/code]
16 Oct 2024 18:52
Replied by tommylight on topic controller and motors not fully communicating
A close up picture of the BOB and drives might help, maybe the wiring is done differently, or enables are wired to another pin, or...
In the meantime, check if the drives have the same pinout for the inputs, they have writings on one side.
  • Muecke
  • Muecke's Avatar
16 Oct 2024 18:47
Welche Tasten haben die Achsen? was created by Muecke
Category: Deutsch
Hallo zusammen,
ich habe gerade zufällig bemerkt, dass ich mich mit den Pfeiltasten auf der Tastatur bewegen kann (oben unten) [Achse Y] (links rechts) [Achse X], wie kann ich herausfinden, welche Tasten die Achse C bei mir hat?
Ich habe eine XYZC Maschine.
Gruß Mücke
  • acourtjester
  • acourtjester
16 Oct 2024 18:37
New minor problem was created by acourtjester
New minor problem
I am having a very minor problem with a routine I have use for some time with other software. That is to set the router bit a known height above the surface of the material.  I think it is just a setting that I need to change in the setup in Pnnconf for the GIU.  I have attached a PDF with a description and screen shots showing what is happening.  And the G-code that does exactly what I want.
Thanks again for you time and help.
Tom
This browser does not support PDFs. Please download the PDF to view it: Download PDF
File Name: Ohmiczerom...xCNC.ngc
File Size:0 KB
  • spumco
  • spumco
16 Oct 2024 18:34
Replied by spumco on topic Probe Basic - intermittent erratic probing
Category: QtPyVCP
get it sorted?
Hijacked by a 'domestic' crisis last night, no time to test.
I'll have a go tonight and report back.
  • Aciera
  • Aciera's Avatar
16 Oct 2024 18:33
Replied by Aciera on topic c++ compiling error
c++ compiling error
You don't get all the source files with a deb installation, if you want everything then you should clone the git tree and build linuxcnc on your local machine (aka RIP installation)
  • foam man
  • foam man
16 Oct 2024 18:26
Replied by foam man on topic controller and motors not fully communicating
yes, 3 red LEDs. All are lit up when I flip the power switch.
1 12-24v
2 Relay
3 PW5
Also 1 led per driver
  • matasbuk
  • matasbuk
16 Oct 2024 18:07
Adding a DRO and want to integrate with linuxcnc, recommended hardware?
Category: CNC Machines
If you're thinking about absolute encoders and upgrading the steppers, you can also look into ethercat servos, but the encoders would be pre-backlash this way.
  • bkt
  • bkt's Avatar
16 Oct 2024 17:14 - 16 Oct 2024 19:12
Replied by bkt on topic c++ compiling error
c++ compiling error
I see now in my deb installation there is not hal_priv.h file ... is possible? I try to fin it on /usr or /share or other system folder witrh no result ... these can be? In github is present ... why not in my installation?
16 Oct 2024 16:55
Does the BOB (blue board with the big connector) have any LED on?
Is it plugged into a USB on the PC?
  • bkt
  • bkt's Avatar
16 Oct 2024 16:48
c++ compiling error was created by bkt
c++ compiling error
I receive these error when try to use my app written in c++ .... with c++14 linuxmint 22 and Lcnc2.10 ....
/usr/lib/liblinuxcnc.a(iniaxis.o):function iniAxis(int, char const*):(.text+0x235): error: undefined reference to 'emcAxisSetMinPositionLimit(int, double)'
seems there are something not find (library or what else ....) but not understand what is it!! Lcnc is regular install and work .... so not understand what library need after these:
LIBS+=  -Iinclude -I/usr/lib/linuxcnc/canterp.so
LIBS += -L/usr/lib -lnml -llinuxcnchal -llinuxcnc -llinuxcncini -DULAPI -lposemath -Isrc/emc/rs274ngc
  • foam man
  • foam man
16 Oct 2024 16:48
the Probotix controller works well, it's the other one (The first pictures) that does not work. the wires coming to the motors are getting power but the voltage does not change when I try to jog. I'm wondering if whatever wires bring the move signal are not doing their job. Originally I thought maybe it was a programming error, but if the Probotix box works...
  • Lcvette
  • Lcvette's Avatar
16 Oct 2024 16:30
Probe Basic machines won't update after modify in "Designer for PB"
Category: QtPyVCP
also be aware that any changes made will be overwritten if you decide t update down the road with a newer release of probe basic. it may be wise to use the user tabs instead and remain on the stock version if you want ease and simplicity down the road.
we will be implementing some changes that allow certain buttons to be changed via user settings to better fit with routers, such as the flood and mist buttons will be interchangable with vaccum and dustcollector or similar etc.
  • Lcvette
  • Lcvette's Avatar
16 Oct 2024 16:22
Category: QtPyVCP
are you using the designer launchers on the desktop to start qtdesigner? this is necessary for the venv.
one of the users that builds his own debs posted this in the group chat.
TAG="0.5.4-128"
KMBUILD=6
echo Building $TAG
dch --create --distribution stable --package probe-basic --newversion $TAG.stable+km+$KMBUILD KM Build
dpkg-buildpackage -b -uc
  • PCW
  • PCW's Avatar
16 Oct 2024 15:56
Request for Mesa 5i23_7i48_7i52 firmware
Category: Driver Boards
You need to set the pin to output mode.
(all GPIO start-up as input pins)
setp [HMOT](CARD0).gpio.024.is_output true
setp [HMOT](CARD0).gpio.024.out false
Displaying 22666 - 22680 out of 22873 results.
Time to create page: 1.463 seconds
