  • phillc54
  • phillc54's Avatar
26 Aug 2024 23:30
Replied by phillc54 on topic Modify Preview Default
The files real name is .axisrc (note the leading dot which makes it a hidden file) and it goes in the users home directory. If it does not exist then create it.
Both commands will work from ~/.axisrc and will be applied to every LinuxCNC config.
  • tbitello
  • tbitello
26 Aug 2024 23:03
Replied by tbitello on topic Modify Preview Default
I understand, but I didn't identify any file called axisrc, just create it? Does it need to be in a specific folder? Will the root_windows command you mentioned be inside this file too?
  • RLA
  • RLA
26 Aug 2024 22:48
Replied by RLA on topic Add Axis
Add Axis
Category: HAL
What a relief!! So in terms of unreliable hardware...its me!!
Thanks again..glad to be able to move on...
Thanks again!
  • PCW
  • PCW's Avatar
26 Aug 2024 22:28
Replied by PCW on topic Add Axis
Add Axis
Category: HAL
Yes, you are missing the:
addf pid.u.do-pid-calcs servo-thread
so the "U" PID pins are there but they are  not functioning
  • RLA
  • RLA
26 Aug 2024 21:36
Add Axis
Category: HAL
I left shop for today but just noticed this in my hal...no reference to new axis (U)...would that cause the error?...thanks!addf hm2_7i96s.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i96s.0.write servo-thread
setp hm2_7i96s.0.dpll.01.timer-us -50
setp hm2_7i96s.0.stepgen.timer-number 1
# external output signals
  • gardenweazel
  • gardenweazel's Avatar
26 Aug 2024 21:21
QTDragon spindle raise issues was created by gardenweazel
Category: Qtvcp
I'm getting this feedback in my logs:
cut
[QTvcp.QTVCP.QT_MAKEPINS][DEBUG]  Calculating geometry of main window using natural placement: 0 0 1920 1080 (qt_makepins.py:200)
[QTvcp][INFO]  Postgui filename: ['qtdragon_hd_postgui.hal'] (qtvcp:431)
[QTvcp][INFO]  Postgui commands: None (qtvcp:443)
[QTvcp][DEBUG]  Calling handler file's before_loop__ function in qtvcp.qt_makegui.VCPWindow object at 0x7fcc7d590790 (qtvcp:414)
[QTvcp.QTDRAGON_HD_HANDLER][b][color=#e74c3c][WARNING]  not connected qtdragon.eoffset-is-active (qtdragon_hd_handler.py:574)[/color][/b]
[QTvcp.QTDRAGON_HD_HANDLER][b][color=#e74c3c][WARNING]  HALUI pause/resume pin(s) connected - spindle lift not available (qtdragon_hd_handler.py:581)[/color][/b]
[QTvcp][INFO]  Preference path: /home/andy/linuxcnc/configs/my_LinuxCNC_machine_QTDragon/qtdragon_hd.pref (qtvcp:420)
cut
Here's part of my qtdragon_hd.hal file:
Line numbers included for readability.
[b]Do I need both lines 41 and 46?[/b] I am using the pause_pin.py optional file.
  28 # connect signals to LinuxCNC's motion component
  29 ########################################################################
  30
  31 net eoffset-clear    axis.z.eoffset-clear
  32 net eoffset-counts   axis.z.eoffset-counts
  33 #setp axis.z.eoffset-scale .001
  34 #setp axis.z.eoffset-enable True
  35
  36 # external offsets for spindle PAUSE function
  37 ########################################################################
  38 net eoffset-clear              qtdragon.eoffset-clear
  39 net eoffset-spindle-count   <= qtdragon.eoffset-spindle-count
  40 net spindle-pause              qtdragon.spindle-inhibit        =>  spindle.0.inhibit
  41 #net eoffset-state              qtdragon.eoffset-is-active      <=  motion.eoffset-active
  42 net eoffset          qtdragon.eoffset-value <= axis.z.eoffset
  43
  44 # This is used in pause_pin.py
  45 net external-pause              qtdragon.spindle-inhibit        =>  spindle.0.inhibit
  46 net eoffset-state    qtdragon.external-eoffset-state <= motion.eoffset-active
  47 setp axis.z.eoffset-enable 1
  48 setp axis.z.eoffset-scale 1.0
  49
26 Aug 2024 21:14
Replied by tommylight on topic z axis inverted in NC file
No file.
And the ini is not set properly for a mill, the Z=0 must be the top point on the machine and everything below must be negative value, or in your case it should be Z min -5.
Despite that, it can work as is if you use the touch off.
And the above "must" is what is normally used, not written in stone.
  • scotta
  • scotta's Avatar
26 Aug 2024 20:47
I've also had no luck with an out of the box STLinkV2. But ColdTurkey has got it to work
pyocd.io/docs/debug_probes.html
"Recent STLink firmware versions will only allow access to STM32 targets. If you are using a target from a silicon vendor other than ST Micro, please use a different debug probe."
If you have a couple of probes you can always flash one with the following firmware.
github.com/scottalford75/Remora-RT1052/tree/main/CMSIS-DAP
  • PCW
  • PCW's Avatar
26 Aug 2024 20:26
Add Axis
Category: HAL
net u-pos-cmd <= joint.4.motor-pos-cmd
net u-pos-fb <= hm2_7i96s.0.stepgen.07.position-fb
  • PCW
  • PCW's Avatar
26 Aug 2024 20:22 - 26 Aug 2024 20:55
No motor control using 7i96A and DM542T drivers
Category: Installing LinuxCNC
Common issues are:
Too short step length (set step length to double the drives minimum)
Insufficient OPTO LED drive (use single ended wiring on OPTO inputs)
Also on later DM542Ts you must select 5V signal levels (via S2)
  • hirst689
  • hirst689
26 Aug 2024 20:19
I have just finished my build of a CNC table. I am using a 7i96A controller driving three axes. I cannot get any of the motor to step.
I built a configuration using PnConf , I have a tandem Y axis. I can get nothing to move regardless of which axis I try.
When I power on the system all the motor lock, as I would expect.
I am driving the DM542T differentially and I have nothing connected to the enable inputs of any of the motor driver, which should mean that they are enabled.
I put a voltage meter across the direction input of the Y axis and jogged it forward and revere. I see the input flipping between -5.95 and +4.95 so I think the direction is working but I seem not the be getting stepper pulses.
Can someone suggest the next course of action. I am a bit lost and disappointed that I spend a good deal of time and money on this project.
Anyway, I am looking for suggestions
thanks
Hirst689
  • RLA
  • RLA
26 Aug 2024 20:16
Add Axis
Category: HAL
So I am new to lcnc...will have to learn halscope...in the meantime out of curiosity...what is the actual feedback looked for that results in error when not found?...
Thanks!
  • rbarry1068
  • rbarry1068
26 Aug 2024 20:00
Replied by rbarry1068 on topic z axis inverted in NC file
jogging the axis works fine. The machine has a homing switch on the Z axis at the top of its motion range. the .nc file is attached for reference.
  • spontarelliam
  • spontarelliam
26 Aug 2024 19:58
Replied by spontarelliam on topic XHC WHB04b-6 - Disconnects / freezes?
Category: Basic Configuration
Alright a few other related forum posts (forum.linuxcnc.org/gmoccapy/34296-xhc-hc04-lost-connection, forum.linuxcnc.org/38-general-linuxcnc-q...-hb04-pendant-issues) convinced me to upgrade LinuxCNC, which appears to have solved the issue.
I upgraded from 2.8 to 2.9.3.
  • CNCGOOS
  • CNCGOOS
26 Aug 2024 19:51
Replied by CNCGOOS on topic Duplicate settings in Pref File
Category: Gmoccapy
I Have runs som programs but error was stil happening. I have no Tool Change don but i have changed the Ofset tabel in G55 and G54.
than i get a duplicatet items in the file
Displaying 23326 - 23340 out of 24300 results.
Time to create page: 0.664 seconds
