  • Konstantin
  • Konstantin
03 May 2026 13:24
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
@andrax
I created a new configuration using your templates for .ini and .hal files from the A6 Absolute Homing topic. The .xml file is mine and I deleted all of the SDO configurations. The axis is named "X" as you suggested. Attached are the configuration files.
The names of the pins are according to your .hal file, nothing is changed there. I had to make some changed in my .xml file to match.
Now, I opened and closed LinuxCNC a few time and the coordinate of the axis seems to save after each time the machine is closed. When I press "Home All" button the axis is immediately set homed and coordinates does not change.
Let's start with the custom CiA402 homing step by step. I attached two pictures one from .ini and the other from .hal file. What I described as "default" is the default configuration settings as if homing was executed. My question is, when I uncomment the "CiA402 homing" rows in both file, should the "default" rows be commented?
  • Rickey_H
  • Rickey_H
03 May 2026 13:02
Is the Digital Dreams UC300 supported? was created by Rickey_H
Howdy!  I have a DD UC300 installed in my CNC router.  I use DrufelCNC as my software interface. I like the software, but it is limited in features, support and is too expensive for a licensed copy.  I read an old thread indicating that a USB interface has a latency problem and that only the ethernet version (EC300) is supported by reflashing the controller.  Is this true?  Should I upgrade to the EC300 or is there support for the UC300?
Thanks in advance,
Rick
  • MaHa
  • MaHa
03 May 2026 11:44 - 03 May 2026 19:01
Replied by MaHa on topic spinbox problem
spinbox problem
Category: pyVCP
The entry for python is missing in ini file. In my config, its after [RS274NGC]
Make shure toplevel.py is in the path, and  stdglue.py if needed for remap
[PYTHON]
PATH_PREPEND= /home/jef/linuxcnc/configs/Python/
PATH_APPEND=  /home/jef/linuxcnc/configs/Python/
TOPLEVEL= /home/jef/linuxcnc/configs/Python/toplevel.py
Edit:
I was wrong with the python entry. PYVCP panel works without that
  • rodw
  • rodw's Avatar
03 May 2026 10:21
Replied by rodw on topic spinbox problem
spinbox problem
Category: pyVCP
The problem is that python 2.7 which you use was deprecated with the release of Debian Bullseye in favour of Python 3. The only solution is to rewrite you scripts using Python 3. Python 2.7 and 3.0 are not compatible.
  • HansU
  • HansU's Avatar
03 May 2026 09:24
Can't read gcode text in dark mode when editing.
Category: Gmoccapy
You could post your INI-file, a screenshot or whatever command you use to start your G-code editor.
  • RotarySMP
  • RotarySMP's Avatar
03 May 2026 08:36
03 May 2026 05:03
ATC lathe - Clasic Ladder, Stream Deck, Remap M6 My setup
Djakuju bardzo.
Should be "thank you very much" in Polish language, is that correct?
03 May 2026 05:01
Replied by tommylight on topic Gibbscam Post Processor
Did you check if it has a post fro EMC2 as that was the old name for LinuxCNC?
Post processors should be fairly easy to edit/modify, so you can give that a try.
03 May 2026 04:56
Replied by tommylight on topic spinbox problem
spinbox problem
Category: pyVCP
Google translation:
I just upgraded my mortiser from Linux 2.5.4 to 2.9.5, but the problem is that Spinbox signals are no longer working. I read that there was a change in Python, I tried several Python scripts and changed Post-GUI Halfile, but nothing changed. Can you help me?
What is the exact error you get?
  • andrax
  • andrax's Avatar
03 May 2026 04:51
Sanitycheck my plan: ethercat + stepperonline A6
Category: EtherCAT
How did you manage to connect to the drives?I’ve installed the software, but I can’t get a connection
  • PCW
  • PCW's Avatar
03 May 2026 04:46
Firmware request: 7i95T with 4 PWM generators on P1
Category: Driver Boards
7I95T firmware with 6 PWMs on P1
(If you need just 4, use num_pwmgens=4 in the driver command line)
File Name: 7i95t_p1_6pwmd.zip
File Size:295 KB
  • Accipiter
  • Accipiter
02 May 2026 23:58
Replied by Accipiter on topic MESA card (LAN) failing to connect.
Thank you. Will try to pursue your suggestions tomorrow.
  • ffffrf
  • ffffrf
02 May 2026 23:51
How complex would this DIY Swiss style lathe conversion be to set up hal/ini?
I definitely hear you on the stock waste and that may be a good reason to increase my guide bushing axis to be 18 inches, however, I have a method where the actual full headstock length will not be all waste, based on how my stock will insert into the drive servo, I will get about 40% of the tag 5c headstock as usable stock, so knocking it out from 5 inches to around 3 inches.
So you are saying that with a traveling steady rest and gang tooling, I should be able to have every lathe side cutting tools (ignoring drills and boring bars for now) be able to cut right at the entrance of the bushing? I am trying to imagine this. If it is possible, in that case, during a tool change, I just need the guide bushing axis to retract the stock all the way back, and only then cause the cross slide to move to the new tool location, then the stock pops back out of the bushing and cutting proceeds? I need each lathe tool to have its cutting edge right at guide bushing entrance.
My issue is with each tool holder, your actual cutting edges will not all line up, for example, I dont want my 55 degree side cutter to be cutting right at the bushing, but my parting tool has to cut 5mm beyond the bushing just based on where the cutting edges line up in my taig tool holders.
Also, if I add a Y axis and live tooling, in that case would you recommend the W axis?
  • TheTinkeringMechanic1
02 May 2026 22:33 - 02 May 2026 22:54
Replied by TheTinkeringMechanic1 on topic Can't read gcode text in dark mode when editing.
Category: Gmoccapy
How do I tell what one it is?
Displaying 3991 - 4005 out of 12541 results.
Time to create page: 0.323 seconds
