  • Nkbhvid
  • Nkbhvid
26 Jan 2026 19:25
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
The ip is 10.10.10.10
I can ping it.
return of ip a:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp4s2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:01:02:f1:ea:a1 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/8 brd 10.255.255.255 scope global noprefixroute enp4s2
inet6 fe80::74db:6330:9bad:59ef/64 scope link noprefixroute
3: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 90:2b:34:64:01:44 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.85/24 brd 192.168.1.255 scope global dynamic noprefixroute enp3s0
valid_lft 3522sec preferred_lft 3522sec
inet6 2001:2012:18ac:2400:a697:d340:a244:6b59/64 scope global temporary dynamic
valid_lft 288sec preferred_lft 288sec
inet6 2001:2012:18ac:2400:922b:34ff:fe64:144/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::922b:34ff:fe64:144/64 scope link noprefixroute
  • ehaskins
  • ehaskins
26 Jan 2026 18:25 - 28 Jan 2026 03:23
First conversion, Axiom CNC Router with RichAuto controls
Category: Show Your Stuff
I just "finished" converting an Axiom AR8 Elite from RichAuto controls to LinuxCNC. I have quite a few details left to tidy up, but it's working.
Configuration and wiring notes are on GitHub , and I made a YouTube video out of the project.
I'd appreciate anyone pointing out stupid mistakes I made.
  • PCW
  • PCW's Avatar
26 Jan 2026 18:17 - 26 Jan 2026 18:19
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
What IP address is selected on the 7I97T?
What does the command:
ip a
return?
  • Nkbhvid
  • Nkbhvid
26 Jan 2026 17:55
Linuxcnc 2.9.4 and Mesa 7i97T was created by Nkbhvid
Hi
Coming from my safe world of Mach 3 and 4 I have now made the jump into Linuxcnc.
OMG its complicated!
I have spend almost a week trying to set up Linuxcnc 2.9.4 (and a couple of other versions) on the mesa 7i97T card.
Is there anybody out there who has made this work?
I can make it ping but thats as far as I can get. From here there is only "board not found"
Is there any known challenges in this setup and will it ever work?
Best regards
Nicolaj Hvid
  • andrax
  • andrax's Avatar
26 Jan 2026 17:54
[solved] XHC-WHB04B-06 rotary knob button feed rate not work
I tested the signals on the rotary control.
The pins for feed.selected light up depending on the selection.
whb.halui.feed-override.scale always remains 0.
whb.halui.max-velocity.value always remains 166.666.
  • cncfreak
  • cncfreak
26 Jan 2026 16:55 - 26 Jan 2026 17:29
Replied by cncfreak on topic asd-a2-e ... lcec driver?
Category: EtherCAT
File Name: ASDA_A2E_2...1-26.xml
File Size:9 KB
File Name: Ethercat_slv.txt
File Size:39 KB
Use this xml file instead. There are all the ios configured.
Also you have to program on each drive the following:
P2-18 -> 0x0130
P2-19 -> 0x0131
P2-20 -> 0x0132
P2-21 -> 0x0133
P2-22 -> 0x0134
P4-06 -> 0x0000
Or use the attached parameter file if you have the asda-soft.
Rename the *.txt file to *.par
26 Jan 2026 16:45
Replied by tommylight on topic MAC address not retrieved (after 2 years stop)
Category: Driver Boards
Rod asked you to post the result of
ip a
in a terminal.
  • sataran
  • sataran
26 Jan 2026 16:41
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
also i have issues accessing the analog and spindle part, don't know if it is linked to the framework or something else.
  • Jocman
  • Jocman
26 Jan 2026 16:40
I don't think I've lost the network.
I've selected the pci card to connect to my network (in fact, I can normally access internet).
BTW, this evening (here's almost 6 pm) I hope to make another try (if my wife allow me  )
  • endian
  • endian's Avatar
26 Jan 2026 16:19
Replied by endian on topic LinuxCNC S-Curve Accelerations
Sounds all sensible to me but I really don't feel competent to comment on the proposed path.
I certainly like the structured approach of your initiative, that is something that has been sorely lacking in other attempts.
I think/hope that Rob will be able to give an educated opinion on it and shape it into a concrete roadmap.
Note that Mitsubishi SSCNET requires a servo cycle <= 222us
forum.linuxcnc.org/9-installing-linuxcnc...cnet?start=70#256576
defenetly is great to have something faster then 1ms .. ethercat can run at 50us with 16axis but this complex calculations are far slower for now
I think 250us is very pretty goal (common industrial standard) at any hardware and then reduce it based at used hardware
  • Mr1576
  • Mr1576
26 Jan 2026 16:10
Replied by Mr1576 on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
HAL file (with @andypugh suggestion) attached, as well as current ini file
File Name: XYYZA2PPTR...1-26.txt
File Size:5 KB
File Name: XYYZA2PPTINI.txt
File Size:3 KB
  • Jerry69
  • Jerry69
26 Jan 2026 15:52
How can I contact juliankoenig87 was created by Jerry69
I am new to this forum. I read a post where he Addis he was retrofitting a Kuhlmann machine with new electronics. I am in United States and have a Kuhlmann with a burnt board and need to get it running again. I think he might can give me some direction.
26 Jan 2026 15:49
Replied by tommylight on topic Kuhlmann engraving machine upgrade
Upload some pictures of it here, also the electronics box and wiring pictures/PDF anything...
26 Jan 2026 15:46
Replied by tommylight on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
No spindle there, attach the hal and ini files here so we can have a look.
  • Mr1576
  • Mr1576
26 Jan 2026 15:41 - 26 Jan 2026 15:58
Category: HAL
@meister, thanks.
I can only get linuxcnc top load if I revert to my original HAL, and with your suggestion the results of the grep spindle command are as in the screenshot
Displaying 7921 - 7935 out of 12651 results.
Time to create page: 0.478 seconds
