  • nanowhat
  • nanowhat
17 Dec 2025 16:01
Unsupported access to an object was created by nanowhat
Category: EtherCAT
I'm trying to change a drive's home offset via SDO (can't be done via PDO). Executing the command 'ethercat download -p2 -t int32 0x607C 0' returns "SDO transfer aborted with code 0x06010000: unsupported access to an object"
Obviously it doesn't work. Why doesn't it work?
Everything I've found online simply parrots the failure code and doesn't say why.
  • DemonClaW
  • DemonClaW
17 Dec 2025 14:55
Replied by DemonClaW on topic No linuxcnc widgets in designer
Category: Qtvcp
I have the installed version of linuxcnc on the 2.9.7 version, ive tryed to follow the orders of previes posts but they are to old and much of the links dont work anymore, if i run it from terminal the only output i get is that the plugins for LED, Buttons etc. is missing
  • vibram
  • vibram
17 Dec 2025 14:51 - 17 Dec 2025 14:59
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
well done its working !
I need the distributed clocks working if i want it to be compatible with LinuxCNC ?
  • Hakan
  • Hakan
17 Dec 2025 14:34 - 17 Dec 2025 14:37
Category: EtherCAT
I saw that one, that was a new one to me.
How about not solving it, and instead go around it?
Add a PDO say scale as rxpdo? I mean anything useful, you don't need to do anything with it, just a place holder.
Then you don't need that declaration in main.cpp.
I have always had rxpdos so had not encountered that before.
I can try to see what's going on in the code a bit later.
Meister, I think it is how you go from the comfort zone with Twincat to the deep waters in linux.
I read and write eeprom with "ethercat sii_read" and "ethercat sii_write", the EEPROM_generator
gives me directly the eeprom to download in bin format. The tool you refer to can be used
to take an arbitrary xml file and turn into eeprom format for downloading. It's very useful,
one of the tools to keep in the toolchest.
  • cmorley
  • cmorley
17 Dec 2025 13:58
Replied by cmorley on topic No linuxcnc widgets in designer
Category: Qtvcp
What version of linuxcnc are you using?
Is it an installed version or a run in place version?
What specifically have you tried?
If you run qtdrasigner from a terminal, what does it print?
  • dfarnainekl
  • dfarnainekl
17 Dec 2025 12:12
Replied by dfarnainekl on topic Can't get EL4001 to work - all other devices work
Category: EtherCAT
Thanks Hakan for the inputs.
After not finding any obvious issues using your suggestion, I did what I should have done in the first place and used TwinCAT to test the terminal.
And as it turns out, the terminal seems to be the issue despite being sold as working, I can't get it to output anything with TwinCAT either.
So I will get a new one and try again.
  • vibram
  • vibram
17 Dec 2025 11:24 - 17 Dec 2025 11:25
Category: EtherCAT
Hello,
I updated the GIT.
I managed to flash my eeprom correctly however with the current I-m stuck in with this compilation issue:
ecat_slv.c.text.RXPDO_update+0x1c): undefined reference to `rxpdo'
I just cleaned the cb_get_inputs(void) and cb_set_outputs(void) compared to the working code and put my eeprom file in folder soes-esi
In order to compile i can add this in main.cpp
[code]// Definition of rxpdo needed when MAX_MAPPINGS_SM2 is 0
uint8_t rxpdo_buffer[512];
uint8_t *rxpdo = rxpdo_buffer;
but if i do so, I-m stuck in ERR PREOP step
[/code]
  • meister
  • meister
17 Dec 2025 09:34
Category: EtherCAT
A little tip for non-Windows users: you don't need TwinCat to read, write, edit or convert .bin/.xml esi files.
github.com/multigcs/esitool
  • vibram
  • vibram
17 Dec 2025 09:20
Category: EtherCAT
Hello
Thank you for pushing me :)
I took back your project and build with the SPI2, flash you r eeprom and it worked well, im in OP mode in free run.
As I'm a beginner, my goal is to have a working base (basically yours...) and edit in order to adapt my needs.
Now I have the SPI working well, I will try to integrate my encoder from thise base
  • DEVILHUNTER
  • DEVILHUNTER
17 Dec 2025 08:23
Replied by DEVILHUNTER on topic MESA 7I76 / 7i76e Model
Category: Show Your Stuff
Apologies for reviving this old topic but found a mistake on the diagram that may generate a lot of frustation to anyone trying to use it.
Pin AI3 is missing, so all other digital input pins from so on are displaced 1 position.
Unfortunatelly even if moderators delete the link in both  #98901  and  #112565  on the forum, the diagram is still appearing as one of the first searchs on search engines. Not sure if OP has a way to change the picture on his cloudfront account.
  • unknown
  • unknown
17 Dec 2025 07:50
Advantech PCM 9362 freze when opening latency-test
Yeah wifi can be an issue sometimes.
It might be worth looking into some of the services that maybe running not is not required for a cnc machine, CUPS is one for example.
  • Sekai
  • Sekai
17 Dec 2025 07:29 - 17 Dec 2025 07:42
I disable hyperthreading and now it show max 16us and it never froze.
Edit: btw i think i know why it froze.
I had a wifi card put in but now i remove it.
And the latency is better without it.
  • Sekai
  • Sekai
17 Dec 2025 06:17
The missing firmware module can safely be ignored.
The above post can be safely ignored as well.
Tho if it is something you can do and can afford, I would recommend looking at the riocore/LinuxcncRIO project as that can connect via ethernet, is creates step/direction in hardware and as such only requires a servo thread. Another plus being you don't require a RTAI kernel. Just mentioning as this might be worth investigating. The developer is very generous with his time as well and the project is very active.
I'l try riocore/LinuxcncRIO later
Last night i did clean install of Debian 12.12
And downloaded :
RTAI Kernel 5.4.258
RTAI modulesernel 5.4.258
LinuxCNC package for RTAI kernel 5.4.258
Now when installed the kernel the message with i915 did not show up.
After a night of latency-test the numbers are ok.
Hyper threading is active that why it say 2 cores.
  • zoeper
  • zoeper
17 Dec 2025 05:27
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
I missed the "shared home and limit" option.
Thank you for pointing that out!
  • frayja2002
  • frayja2002
17 Dec 2025 03:41 - 17 Dec 2025 08:42
USB pendant button to zero axis was created by frayja2002
Hi all
I have a DragonRise USB board that I am using for a pendant.
Currently I press and hold a button for the speed & then an X Y or Z axis button to jog.
I would like to be able press a zero button & one of the axis to zero that one.
I did see this code for the ini file....
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = "G10 L20 P0 X0"
MDI_COMMAND = "G10 L20 P0 Y0"
MDI_COMMAND = "G10 L20 P0 Z0"
but I am not sure how to call it from my hal file.
I have attached my ini & the USB part of the hal file.
Any pointers in the right direction would be appreciated.
Thnks
Alex.
After mucking about for a while I would like to be able to do something like this (i think)
setp zero-mux4.in0     99             # Setting this input  prevents motion unless one of the other buttons is pressed.
setp zero-mux4.in1     02             # Zero X
setp zero-mux4.in2     03             # Zero Y
setp zero-mux4.in3     04             # Zero Z
net zero-btn0        <= zero-mux4.sel0    <= input.0.btn-base
net zero-btn1        <= zero-mux4.sel1    <= input.0.btn-trigger
#net zero-axis         => zero-mux4.out    => halui.mdi-command-(zero-mux4.out)
Does this sound like how it should be done.
Displaying 9571 - 9585 out of 12679 results.
Time to create page: 0.339 seconds
