  • Benb
  • Benb's Avatar
18 Aug 2025 22:32
Replied by Benb on topic Simodrive 611
Simodrive 611
The Simodrive 611 is a versatile and universal drive system. It can operate in an open torque loop configuration, allowing LinuxCNC to manage the positioning loop. To achieve this setup, connect your encoders directly to the Mesa card, route the analog control signal (±10 VDC) from the Mesa card to the drive, and wire the drive enable signal between the Mesa card and the Simodrive.
Keep in mind that you'll likely need access to the Simodrive configuration software to properly set up and tune the drive parameters.
  • Clemens
  • Clemens
18 Aug 2025 21:15
Hi Scotta,
it's the actual measured position. I use e.g. G0 Z0 and measure the position with a dial gauge. The value on the dial gauge drifts away
  • ihavenofish
  • ihavenofish
18 Aug 2025 21:10
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
First ATC parts came in. wooo. Really good machining and finishing.
Also working on an 8 tool ISO20 tool magazine. Can use the turret on iso20 sadly, but this will work well enough and still be very small and save a lot of money over hsk25
18 Aug 2025 20:57
EtherCAT RC Servo Motor & PWM Output Interface Board
Category: Show Your Stuff
there was no "same content"
every 3 boards are different
Oh cr@P! :(
Sorry, can you please upload them again.
And what did i miss?
Again, i am really sorry for the mess, they did seem the same form a quick glance and the tittles were very similar.
  • scotta
  • scotta's Avatar
18 Aug 2025 20:44
Hi Clemens,
When you say "drift away" do you mean actual measured physical position or the position reported by LinuxCNC?
The Remora firmware feeds back the steps generated to LinuxCNC, so the axis position feedback can be calculated.
  • scotta
  • scotta's Avatar
18 Aug 2025 20:40
Replied by scotta on topic Remora - Can't get it out of estop....
Yes, I think so. The 3D printer market will determine the evolution of controller boards.
STM F4 boards are well supported.
The Devs are actively working on a newly refactored Remora-core and HALs for various MCU series to move away from Mbed. This will bring support for H7 boards which are in beta testing at the moment.
  • emresensoy
  • emresensoy
18 Aug 2025 17:41 - 18 Aug 2025 17:51
  • my1987toyota
  • my1987toyota's Avatar
18 Aug 2025 15:57 - 18 Aug 2025 16:20
Replied by my1987toyota on topic Compleatly off line Voron image possible ?
Category: Additive Manufacturing
Every day it just gets worse   I guess the new slogan will be " If you can't beat them, ban them."
  • scsmith1451
  • scsmith1451's Avatar
18 Aug 2025 15:46
Replied by scsmith1451 on topic Set program zero using XY positioning laser
Sorry about the gibberish. The image I pasted looked ok before clicking <SUBMIT>. It reads:
"Named paramter #<_ini[laser]laser-offset-x> not defined"
Regards.
  • scsmith1451
18 Aug 2025 15:18
Still no go.
Here are my ini variables:
[LASER]
laser-offset-x = -3.2017
laser-offset-y = -0.2124
Here is my oword macro:
o<auto-xy-zero> sub
;   ( Move table to program start)
    G91 G0 X#<_ini[LASER]laser-offset-x> Y#<_ini[LASER]laser-offset-y>
    G10 L20 P0 X0 Y0 A0        ( Set X/Y/A DROs to zero )
o<auto-xy-zero> endsub
m2
This is the EMC_Action_MDI class in the gvcp-panel.ui
  <object class="EMC_Action_MDI" id="auto-xy-zero">
    <property name="command">o&lt;auto-xy-zero&gt; call </property>
  </object>
and the related button configuration in the same file:
                  <object class="HAL_Button" id="auto-set-xy-zero">
                    <property name="label" translatable="yes">Auto X/Y Zero</property>
                    <property name="related-action">auto-xy-zero</property>
                    <property name="visible">True</property>
                    <property name="can-focus">True</property>
                    <property name="receives-default">True</property>
                  </object>
When the button is clicked, I get the following error message:
[img]data:image/png;base64,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[/img]
A close inspection of the error has [laser] rather that [LASER] which would account for the message if usage is case sensitive.
Otherwise, I have no idea why the ERROR message is being generated.
Also, before I tried to combine both the offset moves and zeroing the DRO, your guidance to home the machine, turn on the laser and then jog to the desired location worked like a charm. However, since I've tried to implement the oword macro, the machine is back to not allowing jogging with the laser on. No idea what may have caused that!
Any guidance would be greatly appreciated.
Regards,
18 Aug 2025 14:19
No triple posting.
Two posts with the same contents were deleted.
Thank you.
18 Aug 2025 14:10
Replied by tommylight on topic Compleatly off line Voron image possible ?
GitHub is gone, totally now since it's CEO resigned a few days back, so now it is fully controlled by MicroShaft!
First thing to download and save is CloneZilla, and use it to make images of Klipper/Mainsail/etc and LinuxCNC AFTER setting up properly everything.
As for Orca Slicer, Super Slicer, etc, and FreeCAD, KdenLive, etc, those always have AppImages for download, so hoard those.
18 Aug 2025 14:02
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
  At this point I am starting to hoard software programs as well. Who knows how long before "They" decide
to start blocking open source stuff .
Very good idea, especially since i have nearly 5TB of free space on my NAS.
  • PCW
  • PCW's Avatar
18 Aug 2025 14:01 - 18 Aug 2025 14:05
System hangs repeatedly with certain combinations of operations
Did you "addf" the lut5 function to the servo thread?
addf lut5.0 servo-thread
  • kor
  • kor
18 Aug 2025 12:52
Replied by kor on topic pc for linuxcnc using ethercad and Mesa
What do you think about the PeeliCeeli N150 and what would be recommendable RAM and SDD size? 16gb RAM and 512 SDD sounds like plenti to me.
Best
kor
Displaying 10921 - 10935 out of 17145 results.
Time to create page: 4.252 seconds
