04 Aug 2025 23:40
Replied by tommylight on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Added 2 more.
@tomapc
@toma.cnc1
@toma.3d
@tomaberisha5688
Reminds me, i have to fix the name on the last one as it was the first one i registered.
  • PCW
  • PCW's Avatar
04 Aug 2025 23:38
Replied by PCW on topic Encoder started misbehaving
Category: Driver Boards
Looks like 7I77 U15 (74LCX04) receives, buffers, and inverts
the ENCMUX signal to generate the EVEN/ODD signals that
enable the 26LS32 even and odd line receivers, so is a prime
suspect with encoder mux issues:
This browser does not support PDFs. Please download the PDF to view it: Download PDF
04 Aug 2025 23:31
Replied by tommylight on topic Interfaces & linear scale for LinuxCNC
SSDs are overrated.
What is that supposed to mean? Any SSD is MUCH faster than a spinning hard drive, so how is this "overrated"
They are mostly good for Windows because NTFS has fragmentation issues.
They are good for all operating systems, not just Windows.
They do reduce boot time, but that is not really useful.
It is useful for everything that needs to be transferred from SSD to system RAM and back, especially when starting any application or closing it, or...
RAM is faster than any SSD, even "slow" DDR 866MHz is faster.
Not a valid comparison so why????
Make sure your RAM is dual-channel.
Yes, this is valid, but requires 2 or 4 sticks of RAM, same size, otherwise it defaults back to single channel.
You can get double speed with no drawback.
Not true, you get more speed, but never double speed, timings, latency, clocks, and some probably 50 more settings and parameters that prevent memory form physically reaching "double speed".
Why not?
Now i must ask, Why?
Why do you keep replying like this?
Again, i admire your will and effort to help others, and some times you do help so thank you for that, but sometimes your replies are like this causing more confusion and noise that is not helpful.
  • rodw
  • rodw's Avatar
04 Aug 2025 23:17
Category: QtPyVCP
Subbed with @tomapc and was already subbed with @toma.cnc1 , i think, will also check @toma.3d.
Thanks Tommy! (9 to go), keep up the good work.
  • Lcvette
  • Lcvette's Avatar
04 Aug 2025 22:52
  • Benb
  • Benb's Avatar
04 Aug 2025 22:16
Replied by Benb on topic Switch relay in a defined x position
If you just want to stop all axes when the cylinder support is extended then you can use “motion.enable” pin.
From doc, motion.enable:
If this pin is driven FALSE, motion stops, the machine is placed in the "machine off" state, and a message is displayed for the operator. For normal motion, drive this pin TRUE.
Practically: you need a limit switch wired to your hardware input. And you would need to add the following hal line to your existing hal file:
net cylndr.extnd   hm2.your-input  motion.enable
(Replace hm2.your-input with the correct address)
What the above hal code does: when hm2.your-input pin goes true the motion.enable pin will be true normal operation resume, when the cylinder is extended the switch opens and stop all axes motion. Assuming that the limit switch is normally open and your hardware input is sinking (positive logic).
04 Aug 2025 21:13
SSD will improve latency a bit, but adding more RAM would also help, 8GB is just fine, but i do not recall how much you already have.
  • Cysign
  • Cysign
04 Aug 2025 21:09
Replied by Cysign on topic Interfaces & linear scale for LinuxCNC
I just ordered a SSD for this old computer. Now that I know it's working, I would like to speed it up :D
Will this also improve latency for linuxCNC or doesn't it matter, since everything is stored in RAM?
  • tsaG
  • tsaG
04 Aug 2025 21:02 - 04 Aug 2025 21:03
Replied by tsaG on topic Probe Basic ATC Questions
Category: QtPyVCP
Thanks for the quick reply. On installation, I copied the "macros_metric_sim" folder into my "subroutines folder" from the "rack_atc_sim" folder, is this correct?
Manually clamping / unclamping works (so it seems to use the "clamping" and "unclamp" Gcode).
I attached my machine config (currently a bit messy as I switched from a custom Rack tool changer (which worked so far), to the probe basic one and I think I found one issue (which I fixed). For some reason, I had the following line included which broke something.
REMAP=M6   modalgroup=6  prolog=change_prolog   ngc=toolchange  epilog=change_epilog
Removing this at least lets me click "Store tool in Rack". However, it doesn't do anything except for setting the active tool to "No tool loaded". It doesn't move my spindle. Clicking "Ref Rack Data" (still don't know what it does) gives me the "Unknown M Code used: M13").
  • PCW
  • PCW's Avatar
04 Aug 2025 20:44 - 04 Aug 2025 20:48
Replied by PCW on topic Is my wire diagram correct?
Does iocontrol.0.emc-enable-in go false when you request an Estop with your switch?
How is the input common on your isolated inputs connected?
Assuming this is a 7I95/7I96/7I96S, the isolated inputs on  these  cards
will work with input voltages from 4V to 36V
  • MarkoPolo
  • MarkoPolo
04 Aug 2025 20:27
Replied by MarkoPolo on topic Modifying qtdragon screen
Category: GladeVCP
It would be better to ask this question in the qtvcp section.
Qtdragon doesn't use Glade. You won't need Qt Creator either.
To modify the .ui file, install Qt Designer.
Marek
  • JackRay
  • JackRay
04 Aug 2025 20:16
Replied by JackRay on topic Is my wire diagram correct?
Hello,I am responding to your answer because I have a problem with my E-stop. The E-stop on my Axis interface always remains on Off“net estop-out <= [HMOT](CARD0).inm.00.input-04”“net estop-out => iocontrol.0.emc-enable-in”. Whether my emergency stop button is pressed or not, my limit switches work very well. I have a 12V power supply for the whole system. Is a 24V power supply required? Thank you
  • JackRay
  • JackRay
04 Aug 2025 20:15 - 04 Aug 2025 20:19
Hello,
Thank you
  • Lcvette
  • Lcvette's Avatar
04 Aug 2025 19:54
Replied by Lcvette on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
lol...that will not be in my todo list..lol that is an external offering. you could spend a couple hours and get it working. it is just a matter of editing the surface map ui file, subroutine update file, custom_config.yml, and getting all the widgets and what not in synch with expectation, once that is done it should work as expected. its a fairly simple setup regarding what is in probe basic. it is all usertab based so you do not need a dev install to perform the edits. everything is externally accessible via the existing qtdesigner stock installation (from terminal run: editvcp probe_basic, then select open and point at the surface map usertab directory and find the surface map ui file), a decent text editor such as vscode or sublime etc for the subroutines and yaml file updates. I have not looked at how it connected to the graphical portion, but i would imagine once the names all are correct it should work great. if you plan on using it you would have a much better grasp on how it is used than me as i have never used it before and haven't mentally imagined using it so the process flow is lost on me.
  • PCW
  • PCW's Avatar
04 Aug 2025 19:16 - 05 Aug 2025 14:10
Replied by PCW on topic RPi5 and 7C81, manual control is choppy
Category: Basic Configuration
For the PID settings for a hardware stepgen, P should normally be
1/Servo-thread-period so 1000 for a 1 ms servo thread period,
and FF1 should be 1.000.
The physical meaning of these setting is this:
P=1/Servo-thread-period means correct any detected position
error by the next servo thread invocation.
FF1= 1.000 means set the base stepgen velocity to LinuxCNCs commanded
velocity (to center the operating point of the PID loop on the current velocity)
This means the P term has little to do besides correcting for minor time base
differences between LinuxCNC and the hardware.
Displaying 11431 - 11445 out of 17264 results.
Time to create page: 2.136 seconds
