  • PCW
  • PCW's Avatar
02 Aug 2025 20:39
Replied by PCW on topic Interfaces & linear scale for LinuxCNC
A 7I95T combines the functions, or a 7I96S+ a 7I85, or 7I85S can do it in two cards
  • Cysign
  • Cysign
02 Aug 2025 20:29
Replied by Cysign on topic Interfaces & linear scale for LinuxCNC
Sure, but I would get rid of the LPT-port requirement and could use any computer, not only this specific one (if broken one day...).
Which Mesa card would be your go-to in 2025?
And is there a card combining outputs (for the stepper drivers) as well as inputs for linear magnetic encoders or would this be a combination of two cards?
  • MaHa
  • MaHa
02 Aug 2025 20:11
SolidCam error in output gcode for thread milling.
Category: Post Processors
N25 G0 X0. Y0. Z25.
N26 M99
O3
N27 G91 G0 Z-23.
N28 G1 Z-12. F300
When i Look at this lines, there is incremental rapid from Z25 to Z2 and feed move incremental to -10
The moves with G3 are all incremental G91, so a pitch of 1, with lead in and out exactly to Z0
Line 44 switch back to abs G90
  • snowgoer540
  • snowgoer540's Avatar
02 Aug 2025 19:59
Replied by snowgoer540 on topic PlasmaC Voltage Divider
Category: Plasmac
Sounds like it did not get an Arc OK signal.
The criteria is different depending what Mode you are using:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:modes
  • Sekai
  • Sekai
02 Aug 2025 19:44 - 02 Aug 2025 19:53
Hi .
I'm trying to output an operation with thread milling but the gcode output for z position is static.
(THM_DRILL.NGC)
( 2-AUG-2025)
N1
N2 #12=1
N3 #13=0
N4
N5 #14=1
N6 #15=0
N7  G21 G49 G0 G54 ( ABS mm clr_Z_offset rapid_motion )
(MSG, Óñòàíîâè T1.
N8 M9 (turn all coolant off)
o106 repeat [#14]
o105 repeat [#12]
S3500 M3
G0 X0. Y0. Z25.
N9 M98 P2
N10 g0 x0 y0
N11 g92 x-#13
N12 o105 endrepeat
N13 g92.1
N14 g90
N15 g92 y-#15
N16 o106 endrepeat
N17 g92.1
N18 g90
N19 M30
O2
N20 (
N21 (THM-DRILL - THREAD)
N22 (
N23 G0 X0. Y0. Z25.
N24 M98 P3
N25 G0 X0. Y0. Z25.
N26 M99
O3
N27 G91 G0 Z-23.
N28 G1 Z-12. F300
N29 G41 G1 X7.379 Y-1.516 F800
N30 G3 X0.286 Y8.692 Z0.12 R6.15
N31    Z1. I-7.665 J-7.176
N32    Z1. I-7.665 J-7.176
N33    Z1. I-7.665 J-7.176
N34    Z1. I-7.665 J-7.176
N35    Z1. I-7.665 J-7.176
N36    Z1. I-7.665 J-7.176
N37    Z1. I-7.665 J-7.176
N38    Z1. I-7.665 J-7.176
N39    Z1. I-7.665 J-7.176
N40    X2.835 Y-7.176 Z0.88 R-10.5
N41    X-6.15 Y6.15 Z0.12 R6.15
N42 G40 G1 X-4.35 Y-6.15
N43 G0 Z24.88
N44 G90 M99
The Z axis stays at 1 mm.
I did discover if you open the machine editor of youre machine and go to Working Style => General and you put Software Transform to YES , the gcode output gives the corect z output:
N16 (
N17 (THM-DRILL - THREAD)
N18 (
N19    X0. Y0. Z25.
N20    Z2.
N21
N22 G1 Z-10. F300
N23 G41
N24 G1 X7.379 Y-1.516 F800
N25 G3 X7.665 Y7.176 Z-9.88 R6.15
N26    Z-8.88 I-7.665 J-7.176
N27    Z-7.88 I-7.665 J-7.176
N28    Z-6.88 I-7.665 J-7.176
N29    Z-5.88 I-7.665 J-7.176
N30    Z-4.88 I-7.665 J-7.176
N31    Z-3.88 I-7.665 J-7.176
N32    Z-2.88 I-7.665 J-7.176
N33    Z-1.88 I-7.665 J-7.176
N34    Z-0.88 I-7.665 J-7.176
N35    X10.5 Y0. Z0. R-10.5
N36    X4.35 Y6.15 Z0.12 R6.15
N37 G40
N38 G1 X0. Y0.
N39
N40 G0 Z25.
The problem is there is no more subroutines, the o call does not exist anymore so is M98 , M99.
The post processor is from here: github.com/G-S-E/SolidCAM-postprocessor-for-LinuxCNC
  • MaHa
  • MaHa
02 Aug 2025 19:33 - 07 Aug 2025 19:59
Replied by MaHa on topic Flex Gui preset buttons
Category: Flex GUI
Thats what i got so far
  • zzrzzr
  • zzrzzr
02 Aug 2025 19:06
Replied by zzrzzr on topic PlasmaC Voltage Divider
Category: Plasmac
I tried it again without changing anything and the plasmacutter started without firing at startup. Then I loaded the materal and tried to make a cut through 10mm mild steel. The torch fired, but the machine didn't move. And the torch went on and of a few times.
Why does that happen ? And why doesn't the machine move ?
  • ihavenofish
  • ihavenofish
02 Aug 2025 18:35
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
more fun
i think im almost ready to order the atc parts.
  • atrex77
  • atrex77's Avatar
02 Aug 2025 18:23 - 02 Aug 2025 18:25
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
i think i found the correct solution for this problem in the pico examples
  • GDTH
  • GDTH's Avatar
02 Aug 2025 16:23
modprobe: ERROR: could not insert 'ec_master': Key was rejected by service
Category: EtherCAT
Hello
i am trying to setup ethercat on linuxcnc 2.9.4.
I use these instructions
when i want to start the service it gives an error:
these are the conf params i set:
MASTER0_DEVICE="dc:4a:3e:52:df:de"
DEVICE_MODULES="generic"
i based it on this:
 ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 xdpgeneric/id:15 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether dc:4a:3e:52:df:de brd ff:ff:ff:ff:ff:ff
    inet 192.168.8.103/24 brd 192.168.8.255 scope global dynamic noprefixroute enp1s0
       valid_lft 42941sec preferred_lft 42941sec
    inet6 fe80::5746:54a6:d185:a5cd/64 scope link noprefixroute
3: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 88:c9:b3:bb:01:3c brd ff:ff:ff:ff:ff:ff
4: wt0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1280 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 100.113.80.7/16 brd 100.113.255.255 scope global wt0
Does anyone know where i went wrong?
I did first install it and find out that i was on a sercure boot, so i disabled it in the bios.
Kind regards,
Andries
  • Pieter69
  • Pieter69
02 Aug 2025 15:48 - 02 Aug 2025 16:33
Replied by Pieter69 on topic how to jog dual gantry before homing
Category: Basic Configuration
ok, thanks i check it out.
worked perfectly. 1,5mm difference. Is there a way to compensate for this directly in pncconf. the Y2 sensor is reached 1.5mm faster then Y, so Y2 should move 1.5mm further in the homing sequence?
  • TheTinkeringMechanic1
02 Aug 2025 15:45
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
I was wrong!. It can read rpm in both forward and reverse after watching spindle-vel-fb-rpm in halshow.
  • skunkworks
  • skunkworks
02 Aug 2025 15:38
Replied by skunkworks on topic Display motion.current-vel ?
Category: Plasmac
I was surprised at how close it was to the set voltage (based on the cut height setting.) Well thought out.
I have not played with this plasma in ages - it was initially setup by me before eoffsets.. It worked good - but this was much easier.. :)
sam
  • PCW
  • PCW's Avatar
02 Aug 2025 15:29
Replied by PCW on topic PlasmaC Voltage Divider
Category: Plasmac
Sounds like you may have the spindle ENA polarity backwards.
  • PCW
  • PCW's Avatar
02 Aug 2025 15:25 - 02 Aug 2025 15:26
Replied by PCW on topic how to jog dual gantry before homing
No, if you setup immediate homing, no home move or sensors are involved,
LinuxCNC simply takes the current position as home.
Displaying 11476 - 11490 out of 17284 results.
Time to create page: 0.415 seconds
