  • Quarter20
  • Quarter20
13 Jul 2025 01:48
Y axis A slave help request was created by Quarter20
My machine is using the Y and A motors off a parallel port breakout board. I went thru the step config wizard and set up X, Y, and Z configuration and included the A motor pins while doing so. Im really not sure how to proceed as I need Y and A to both home at the same time? Does anyone have a solution for this application?
 Thanks in advance for your help and support!
Quarter20
13 Jul 2025 01:35
  • Fusseldieb
  • Fusseldieb's Avatar
13 Jul 2025 01:10 - 13 Jul 2025 01:12
Running two LinuxCNC instances in parallel was created by Fusseldieb
Hi there,
This is my first post here, and I haven't really found a "definitive" answer to my question.
Is it possible to run two LinuxCNC instances in parallel?
I have two CNC machines and would like to run two separate jobs on both machines. Nothing shared - just two jobs and two machines, really.
I already redirected the port 5005 to a different one for the other instance, but HAL still complains about using duplicated ressources. As I've read in another thread, using two computers and a third to control the other two seems... counterintuitive, to say the least.
Where lies the problem? Is there any way to overcome it?
Thanks in advance!
  • DMNZ
  • DMNZ
13 Jul 2025 00:03
Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
yip, looks like the whole crypto mining industry is controlled by zynq 7010
dont' forget you would still need a breakout board which will move you much closer to a price of mesa board if you are after hostmot2.
  • Esaber
  • Esaber
12 Jul 2025 23:25
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
So I replaced the u33 and still no luck.
I guess I’ll have to continue replacing the other parts.
  • MaxEkb77
  • MaxEkb77's Avatar
12 Jul 2025 21:38
Replied by MaxEkb77 on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I contacted support - they said it was normal.
I'm trying to work on my milling machine - I haven't found any problems yet.
  • HACNC
  • HACNC
12 Jul 2025 16:44
Deckel FP4 ATC Ablaufplan was created by HACNC
Hallo,ich brauche für ATC ein Ablaufplan  / Macro oder script
LG Heiko
12 Jul 2025 16:02
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
Anyone here know how to delete the files from internal memory on the Fanuc i160 ?
Having a strange issue (not the first time on Fanuc) where everything works, even copying files from the USB to internal memory, loading said program and ... well this is where it gets fuzzy as it will run the first cut/program we copied into memory no matter what O number program we load.
Even stranger, can not delete those files, no matter what or how.
Had a panic attack last night and went to the hospital at 4AM as i was so pissed off, i can figure every damn thing on that huge machine inside of a day, but can not delete something i copied to it!!!
I refuse to believe that it only works with files on another PC as we are being told, there must be a way to use it's internal memory as it is using it to make the first cuts we copied.
Manual is for an older version without GUI, it helped for some stuff, but for this failed miserably as there is no delete button where it should be.
Maybe somewhere in the System menu???
12 Jul 2025 15:01
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
You forgot to add the debounce names to loadrt and addf near the top of the hal file.
12 Jul 2025 15:00
Used Laptops tested with LinuxCNC and Mesa Ethernet boards
www.youtube.com/shorts/ciVcxrlmMIA
Screen is full HD, so 1920X1080 pixels, and is still usable for fingering despite the small size. :)
  • tokomak
  • tokomak
12 Jul 2025 14:55
Replied by tokomak on topic Xilinx Zynq 7010 fpga crypto windfall boards
let's port hostmot2 to this board
  • tokomak
  • tokomak
12 Jul 2025 14:40 - 13 Jul 2025 09:27
Hello everyone, I got interested in this topic and found this post
  • GeckoWorks
  • GeckoWorks
12 Jul 2025 14:23 - 12 Jul 2025 14:36
Ah, so there's hope.
I am looking at T450/460/470 with touchscreen as I am planning on putting this on a small lathe with ProbeBasic. Perhaps, the screen will be too small but it should be fine to get me started and I do need a laptop PC for other stuff once in a while.
12 Jul 2025 13:46
Some WiFi adapters do work, some do not, there is no easy way of figuring out except testing.
Replacing the RT kernel does work though, i had to change to 6.13 for WiFi to work.
Strange as T470 has 4.19 RT (i think) kernel and WiFi works.
  • GeckoWorks
  • GeckoWorks
12 Jul 2025 13:26
So, I noticed no wifi on any of the Lenovo laptops... That's a bummer as I was hoping to sync files and not have to transfer with USB sticks anylonger.
Is it only the internal wifi that's not working and whetjer popping in a USB wifi adapter would work?
Displaying 12286 - 12300 out of 17352 results.
Time to create page: 0.583 seconds
