  • ALS
  • ALS
01 Jul 2025 19:26
Keyboard Functions was created by ALS
Keyboard Functions
Category: AXIS
Hello, how are you?
I would like to know if it is possible to change the functions of the alphanumeric keyboard to functions customized by me.
For example: by default, the F2 key turns on the machine. Can I change it to any other function?
Tanks
  • workshop54
  • workshop54
01 Jul 2025 19:15
Wait for spindle-halt signal before reversing spindle direction
Category: Basic Configuration
In that case it seems like writing a custom component is the best choice.
I'm just getting into writing custom realtime components, so this might be a nice exersize.
I can post the link here when I'm done with it if you guys are interested.
  • GDTH
  • GDTH's Avatar
01 Jul 2025 18:37 - 08 Jul 2025 17:36
Bios error during lcnc start was created by GDTH
He.
I have a 5i25 in a HP workstation.
The computer works fine until I want start lcnc. It reboots and gives this error tlp poisend on pci slot.
Does anyone have any idea what is going on?
I did have some difficulty getting the card in.
photos.app.goo.gl/Vi21HjgVt7QMj1yf9
photos.app.goo.gl/Nu3xv5JSHQanxng99
  • PCW
  • PCW's Avatar
01 Jul 2025 18:24
homing with Phase Z encoder on MESA 7i96s
OK, that's probably to be expected since there does not seem to be any B axis home switch
and you have setup a homing scheme that requires that switch.
If you don't have a home switch on B, and you want to home to index, you need to setup
Index-only homing:
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
  • JackRay
  • JackRay
01 Jul 2025 17:07
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
my configuration works very well on the x,y,z axes with on/off switches. homming is all done at the same time without any problem. the problem is only on this rotary axis where i have an encoder with which i want to use the Z phase to do my homing.
  • PCW
  • PCW's Avatar
01 Jul 2025 16:17
Do you have a spindle encoder?
(it might be a bit easier in hal knowing the velocity)
Also maybe this could be done in the g code with
m5 m66
  • Tntmold
  • Tntmold
01 Jul 2025 13:40 - 01 Jul 2025 13:42
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
halshow value for cia402.0.csp-mode is true, but the drive parameters (value of modes-of-operation/cia402.0.opmode/lcec.0.x.opmode) is 0.
in the XML file there is
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="S32"/>
in the HAL file there is:
setp cia402.0.csp-mode 1
net x-modes-of-operation cia402.0.opmode => lcec.0.X.opmode
The drive wants parameter 6060 to be 8 for CSP mode. How do I correct that?
  • Aciera
  • Aciera's Avatar
01 Jul 2025 13:08
Is there a built-in way in LinuxCNC to delay or block a direction change until this signal becomes active? Or do I need to handle this myself, for example using HAL logic or some custom component?
I'm not aware of a built in solution but this could certainly be handled using HAL logic (or a custom component)
  • hellvetica
  • hellvetica
01 Jul 2025 11:54
Robot reads the same position every time it is turned on.
Sorry, i realised i didn't upload the correct .hal file
  • Daan96
  • Daan96
  • Daan96
  • Daan96
01 Jul 2025 08:31
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
Slowly all components are coming in to be able to build the control cabinet.
For the drive I have ordered pulleys of 12 teeth to do a test with direct drive.
If this does not work well I will switch to a transmission.
  • Hakan
  • Hakan
01 Jul 2025 08:13
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
The line
should make the cia402 put the drive in csp-mode.
OP is required but not enough. For cia402 drivers, they have their own states on top of OP.
The drive needs to be in stat-op-enabled to start moving.
Easiest is to use halshow and navigate to pins,cia402,0 to check the values from the component.
  • workshop54
  • workshop54
01 Jul 2025 06:38
Hi all,
I have a setup where the spindle drive provides a spindle-halt signal when the spindle has fully stopped. I’d like to make sure LinuxCNC does not reverse the spindle direction (i.e. switch between M3 and M4) until this spindle-halt signal is true.
Curious to hear how others have tackled this.
Thanks in advance.
  • Johnnysacalu
  • Johnnysacalu
01 Jul 2025 05:35 - 01 Jul 2025 05:42
Replied by Johnnysacalu on topic Puesta a tierra
Puesta a tierra
Lo que tengo es esto
Con otro plasma “stamos 125h cnc” con 4 motores paso a paso cada uno con su fuente de alimentación eje z 36v y los demas 60v. Tengo una fuente que me da 5v 12v 24v que alimenta la mesa 7i96s con 5v y los finales de carrera  ESTOP con 24v esta si tiene los mismos negativos y el thc se alimenta de la tarjeta como en el diagrama.
Tengo cables blindados que que están conectados en una sola punta dentro de la caja de controles a un bussbar y de allí va a la tierra de la red AC.
Os explico, mi problema  es que la maquina funciona y corta bien hasta que le pongo el thc “sin configurar ni escala gain ni nada por que en pncconf no me sale para configurarlo y .hal y .ini seme dan muy mal lo intente pero siempre acabo con errores” y me quema el U5 o U7 no se si los dos o solo uno yo cambie los dos y la maquina vuelve a funcionar busque cortocircuito pero no encontre nada asi que pense que seria por la tierra EMI y todo eso
edit:  uso qtplasmac modo 0
Displaying 12781 - 12795 out of 17373 results.
Time to create page: 0.432 seconds
