  • cmorley
  • cmorley
08 Jun 2025 02:02
Replied by cmorley on topic cam_align
cam_align
Category: Qtvcp
version 2.9.4 did not get the change, only master branch.
You will need to save over the camview_widget with the supplied version again.
  • jhandel
  • jhandel
08 Jun 2025 01:13
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
hey @rodw, was there something you wanted to add? looks like you just quoted my original post.... I know you have a lot of experience in this area, i have read more than a few of your posts so would love your input.
  • rodw
  • rodw's Avatar
08 Jun 2025 01:07
Mesa 7i95t connection to Thermal Dynamics 60i
Category: Plasma & Laser
The pierce delay starts from the beginning of arcOK so the delay turning the torch on makes no difference.
The internal relay will need a minimum current of 100 mA and the Mesa board generally can't deliver this. You need to add a pull down resistor as discussed in the qtplasmac docs.
  • rodw
  • rodw's Avatar
08 Jun 2025 00:56
Replied by rodw on topic reference during rotorhoming
At the moment, rotorhoming starts when i power on the machine.
The problem is that i want to home the z-axis first.
HOME_SEQUENCE in ini
  • rodw
  • rodw's Avatar
08 Jun 2025 00:36
Replied by rodw on topic QTPlasmac pierce delay handling
Category: Plasmac
Unfortunately the relay in the unit is damaged and does not close. I ran through the diagnostics in the service manual to come to that conclusion and of course the service manual recommendation is to replace the inverter board which is half the cost of a new unit lol. It's also very difficult to access but some point down the road I will pull it apart and replace the relay on the board if possible. I'm going to try Tommy's suggestions and hopefully that will buy some time until I fix it or sell it and get another unit.
the most likely cause of a "damaged" relay is oxidisation because the current through the relay has  been below the minimum operating spec. Installing a HS10 1 K pulldown resistor is likely to fix the issue after a few operations once the oxide is burnt off. This is covered in the qtplasmac docs.
  • rodw
  • rodw's Avatar
08 Jun 2025 00:28
Feature Request: ramp piercing (aka moving piercing)
Category: Plasmac
new features go into master branch (2.10) so this will never be in 2.9.4
08 Jun 2025 00:14
Replied by tommylight on topic QTPlasmac pierce delay handling
Category: Plasmac
Get a "reed contact" or "reed relay", make some 3 turns of the clamp wire around it.
That is it, cheap simple and never fails.
I am sure it was in the PlasmaC documentation, no idea if it is in QtPlasmaC.
See attached.
  • kworm
  • kworm
08 Jun 2025 00:07
Replied by kworm on topic QTPlasmac pierce delay handling
Category: Plasmac
  • kworm
  • kworm
07 Jun 2025 23:59
Category: Plasmac
Sorry, I did see the previous post but it's from a year and a half ago. I guess I should have asked if it had been merged into 2.9.4 and/or master.
  • PCW
  • PCW's Avatar
07 Jun 2025 23:50
Replied by PCW on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Changing the PWM scale changes the scaling of all PID parameters.
That is, a P term of 10 with a PWM scale of 10 is the same as a P term
of 1 with a PWM scale of 1, In both cases an error of 1 mm generates a
full scale (+ or - 10V)
There is no reason on a torque mode drive to change the default
PWM scale of 10 (a scale of 10 means the PID output is scale in volts)
  • akim14
  • akim14
07 Jun 2025 23:49
QtPlasmaC using w axis was created by akim14
Category: Plasmac
I need help. I tried converting the a-axis to w, making it leaner. However, I keep getting errors like dro_a and torch_a. Is there an easy way to add a w-axis as z2 ? I made it by editing the handler file and ui file  to overcome these errors; however, I can get it to show the z2,  i looked at the QtVCP library there is z2 there
  • Lcvette
  • Lcvette's Avatar
07 Jun 2025 23:25
Replied by Lcvette on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
@andypugh I am updating probe basic lathe conversational section which someone was awesome enough to give me a head start on and it is using your macros and artwork, but looks a bit behind your latest versions. i saw some links to fusion artwork but tells me i am unauthorized when i click the link on the fusion page. are the fusion files available elsewhere? or do i need to be added to the group/project to have access?
Thanks in advance for any assistance!
Chris
07 Jun 2025 22:48
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Attached is the working stuff, full set, but it is not the last i did modify as apparently i forgot to save that on the NAS, hopefully i have not deleted them but in general i have changed the IP address to 10.10.10.10 so i do not have to change network settings when using Mesa boards and some minor tuning.
07 Jun 2025 22:43
Replied by tommylight on topic Toyota embroidery machine - retrofit
Category: CNC Machines
i think i'll keep the potentiometers, because i've never coded a homing with an encoder so this will allow me to improve, and if i never manage to, it's easy to dismantle so i could insert home switches.
Nice. :)
I will try to get my mother to have a look at the pictures, she still uses those machines daily despite being 75 years old.
Displaying 13741 - 13755 out of 17386 results.
Time to create page: 0.602 seconds
