  • NT4Boy
  • NT4Boy
05 Jun 2025 16:54
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Hello, This is likely the wrong spot to ask this question, but as its one of the first things I've machined using linuxcnc on the machine...
The profile I've machined is essentially circular and should be symmetrical, and the bore clocks in at X0,Y0.
issuing a G0 X0, Y0 gets me back over the bore and it repeatably clocks in.
The finished machined part has a Y offset of 0.2mm.
This may be a programming issue, but I have noticed a random Y -28.11 offset in the tool table for the tool used.
If that entry was doing what I thought it should, then the mis-machining would have been 28.11 and not 0.2. However, could this entry have caused the issue?
On a three axis mill, is there a purpose for the X and Y offsets in the table?
  • hans48
  • hans48
05 Jun 2025 16:46
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo liebe Gemeinde
Der Nörgler ist wieder mit einen Problem da. Ich möchte den Werkzeug Längen Tester Innstallieren. Habe mir das Video von Talla83 angeschaut, dieser hat aber eine andere Mesa Karte gehabt. Kann man das auch für die Mesa 7i96s nehmen? das nächste wird noch da Handrad aber das muss ich erst besorgen (möchte es Kabellos machen daher ein China Produkt). Habe Peter (Talla83) angeschrieben aber keine Antwort bekommen.
Gruß und nochmal ein Danke für eure Hilfe.
Hans
  • PCW
  • PCW's Avatar
05 Jun 2025 16:05
MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ?
Category: Driver Boards
This Benezan config looks correct:
File Name: 7i92t_benezanx2d.zip
File Size:235 KB
Benezan breakouts have step/dir swapped but this version has
the ability to swap the default step/dir pins with a hal parameter
  • SwitchWitch
  • SwitchWitch
05 Jun 2025 15:49 - 05 Jun 2025 17:29
Replied by SwitchWitch on topic xml and hal - I am lost
Category: EtherCAT
Yes - I hit power and lcnc thinks it is moving. The servo stays in PreOp.
My mistake - the changed files were not copied into the folders.
Now I have success - I have errors
twopass:pass0: loadusr -W lcec_conf ethercat-conf.xml
twopass: load_the_modules cmd=<orig_loadrt motmod servo_period_nsec=1000000 num_joints=3 base_period_nsec=100000 servo_period_nsec=1000000 num_joints=3 unlock_joints_mask=16 num_dio=6 num_aio=3>
waitpid failed /usr/bin/rtapi_app motmod
/usr/bin/rtapi_app exited without becoming ready
insmod for motmod failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt lcec>
waitpid failed /usr/bin/rtapi_app lcec
insmod for lcec failed, returned -1
Debug file information:
Note: Using POSIX realtime
cia402_homecomp: dlopen: /usr/lib/linuxcnc/modules/cia402_homecomp.so: cannot open shared object file: No such file or directory
<commandline>:0: waitpid failed /usr/bin/rtapi_app cia402_homecomp
<commandline>:0: /usr/bin/rtapi_app exited without becoming ready
<commandline>:0: insmod for cia402_homecomp failed, returned -1
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: update_joint_homing_params
LinuxCNC Ethercat crashed with signal 11
-- STACK TRACE START
0    /usr/lib/linuxcnc/modules/lcec.so(+0xfc8c) [0x7feb9d9b0c8c]
1    /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7feb9e68a050]
2    /lib/x86_64-linux-gnu/libethercat.so.1(ecrt_slave_config_pdos+0x2f) [0x7feb9d97452f]
3    /usr/lib/linuxcnc/modules/lcec.so(rtapi_app_main+0x40a) [0x7feb9d9b1f38]
4    /usr/bin/rtapi_app(+0x10cd7) [0x55e898f48cd7]
5    /usr/bin/rtapi_app(+0x1162e) [0x55e898f4962e]
6    /usr/bin/rtapi_app(+0x11c2c) [0x55e898f49c2c]
7    /usr/bin/rtapi_app(+0xc974) [0x55e898f44974]
8    /usr/bin/rtapi_app(main+0x70f) [0x55e898f4444f]
9    /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7feb9e67524a]
10    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7feb9e675305]
11    /usr/bin/rtapi_app(_start+0x21) [0x55e898f44861]
-- STACK TRACE END
Waiting for component 'cia402' to become ready........Waited 3 seconds for master.  giving up.
6457
Stopping realtime threads
Unloading hal components
lcec: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
trivkins: not loaded
tpmod: not loaded
<commandline>:0: unloadrt failed
Mmmhh - in my understanding just the cia402_homecomp.so is missing - could this be right?
05 Jun 2025 15:44 - 05 Jun 2025 15:50
What's up with guys posting random stuff about PUMA and bitcoin all of a sudden?
Moved to "off topic...."
Those are scams as pretty much if someone gets a hold of your crypto wallet and move assets to another wallet, even god can not get those assets back.
The same guy posted the Puma thing, most probably malware when clicking on the link, basically if you click on it, your PC is not yours anymore as they have full control and all the info within. Yes, even credit card info if you ever ordered something online.
Puma were quite good at one point in time ... long ago.
In general:
-never click on links, ever
-never click on e-mails, ever
-never open any websites, except what you know for sure is OK
With e-mails it is very easy, if someone you know or work with sends you an e-mail, ALWAYS call them to confirm it is from them, otherwise delete WITHOUT opening. This is extremely valid for whoever uses Outlook or any Microsoft stuff/windows/office.
Etc, etc.
Edit:
Same person posted about online casinos just now
Always from the same provider in UK through a VPN or Proxy in Florida, USA.
  • snowgoer540
  • snowgoer540's Avatar
05 Jun 2025 15:36 - 05 Jun 2025 15:37
Just report it and we will delete it, one of us usually notices it but it’s not always easy when it’s posted on existing topics. I for one do not read every post.
  • Kieran
  • Kieran
05 Jun 2025 15:27
Replied by Kieran on topic xml and hal - I am lost
Category: EtherCAT
Hmmm.... so linuxcnc starts with no error, you hit power on (F2?) and servo doesn't come to life? does linuxcnc think its moving when jogging?
  • javanree
  • javanree's Avatar
05 Jun 2025 15:05 - 05 Jun 2025 15:08
PWM going into an analog converter indeed
Current config is like this
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 2000.0
setp pwmgen.0.scale 22800.0
setp pwmgen.0.offset -0.0710526315789
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm     <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps     <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-at-speed    => spindle.0.at-speed
net spindle-cw <= spindle.0.forward
  • SwitchWitch
  • SwitchWitch
05 Jun 2025 15:01
Category: EtherCAT
I went the same way but without success. I combined my working files (Beckhoff modules are working as they should) with the ones from MobiusToast. No error on startup but unfortunately no possibility to jog the axis as well. forum.linuxcnc.org/ethercat/54965-steppe...ervo?start=40#329744
  • SwitchWitch
  • SwitchWitch
05 Jun 2025 14:58
Replied by SwitchWitch on topic StepperOnline A6 Servo
Category: EtherCAT
After having a functional setup for my Beckhoff modules I tried to combine my files withe the ones from MobiusToast to tryout the settings for one of my servos. He mentioned that the files are working for him an that the one axis would at least be moveable.
Surprisingly I have no errors when starting but the servo stays in PreOP and the axis or the motor is doing nothing when jogging the axis.
What could be missing or what could be my mistake(s)?
  • PCW
  • PCW's Avatar
05 Jun 2025 14:54
17 VFD spindle PWM (0-2000Hz)
Is this PWM (for a PWM --> analog converter)
or a rate (0 to 2000Hz frequency output)
  • wusel0464
  • wusel0464
05 Jun 2025 14:21 - 05 Jun 2025 14:36
Replied by wusel0464 on topic Reading variable from ini no longer works?
Category: Qtvcp
Hello,
In my view, not necessarily the best idea.
For my part, I felt very useful and pleasant to comment.
It works in other places too.
And I also see no problem that everything that comes after a double cross is simply a comment if it is in the same line. The possibility of creating extra comments lines remains.
The only thing I can think of is that I recently edited the INI and because the comments could have inserted without switching on the milling machine, I can't think of anything else.
What I really miss is an understandable change overview between really every single versions or the place where I find something.
This has done the problem.
Sorry for the sometimes unhappy choice of Google translator, my modest English is even worse.
All the best and best regards, Frank
  • kworm
  • kworm
05 Jun 2025 14:16
Feature Request: ramp piercing (aka moving piercing)
Category: Plasmac
Sorry to post on a old topic but I wanted to see if this functionality was in qtplasmac in the 2.9.4 install or if you need to be running from the 2.10 master?  Also, has anyone done moving piercing in Fusion360 CAM?
05 Jun 2025 14:06
Replied by tommylight on topic Toyota embroidery machine - retrofit
Category: CNC Machines
Forget the pots, you can do without them, might need adding a home switch.
And also open the possibility of working with roll's of material, meaning not being limited to a certain length.
Displaying 13831 - 13845 out of 17416 results.
Time to create page: 1.229 seconds
