  • ErrickW
  • ErrickW
10 May 2025 19:04 - 10 May 2025 19:07
Lathe for Sale in Virginia was created by ErrickW
Category: User Exchange
Anyone interested in a 16x40 CNC Lathe? It was a Knuth Servoturn 410 NC lathe. I hated the PLC/Control that was on it so a LinuxCNC retrofit was started. The retrofit is not finished (look at the operators panel) but it does run, and it made quite a few parts for us.
Please contact me soon if interested, it has to be moved very soon. I really do not want to send it to the scrap-yard.
It is currently located at:
Lansing Machine Services Inc. (Closing)
425 Network Station
Chesapeake Va. 23320
  • rodw
  • rodw's Avatar
10 May 2025 18:58
Replied by rodw on topic Ganty sawmill
Ganty sawmill
Its always best to start with the Axis GUI until you get a working config and convert to other (more complicated) GUI's after you have  it working. QTdragon is nice but there are a lot of finer features for convenience that can get in the road for a beginner. I converted to it from an axis config though.
  • rodw
  • rodw's Avatar
10 May 2025 18:35
Replied by rodw on topic 7i96 with THCAD-2 setup on Everlast 82i
Category: Plasma & Laser
Set the divider ratio on the board to 1/32 (Needed for Linuxcnc)
Use the thcad calculator here jscalc.io/calc/NTr5QDX6WgMThBVb
Use the plasma divider ratio of 24:1 (an Everlast Quirk) in linuxcnc
Leave the Everlast divider board as 16:1
If you are getting negative values you have bigger problems than config issues.
Check your encoder velocity in halshow, it should be showing around the 0 volt sticker frequency ( / 32)
With the 9 volt battery, it should show near full scale, Calculate what it should be by hand
  • billykid
  • billykid's Avatar
10 May 2025 18:21
sanmotion rs2a03a0al0w00 was created by billykid
Category: Driver Boards
Good morning, I recovered two years ago some of these drives: sanmotion r rs2a03a0al0w00. I tried to communicate with its R-Setup software and they connected to the PC without any problems even if they gave an encoder error because it was not connected (I don't have motors). A few days ago I tried to reconnect the PC but they don't want to communicate... and yet I set the group parameter to 20 on 01 which is the unit number and 21 to 05 which corresponds to 38,400 I used a PC with native serial, Windows 7, set the serial buffers to a minimum as explained in an article on connecting these drives. If anyone can help me, I thank you in advance. Greetings Mauro
  • PCW
  • PCW's Avatar
10 May 2025 17:35
analog Servo spins on its own when connected to 7i77
Ahh someone was probably trying to fix a problem in the previous control
by adjusting the drive zero.
  • DarkPhoinix
  • DarkPhoinix
10 May 2025 16:59
Replied by DarkPhoinix on topic Which kernel version is best for real time?
If your CNC setup works, then don't worry and just move on.
If you are paranoid, just set your max jitter to some really high value in your config.
Don't worry about stuff unless you need to.
I did it and the situation gets worse! if I only move the linucnc window the steppers make absurd noises and change the speed of movement, they are not yet on the machine they are free.. I don't dare to think what they could do at work!
do you mean this SERVO_PERIOD = 1000000 ?
I set it to 35000000. in the video with glxgear it is again at 1000000.
  • chrstrvs
  • chrstrvs
10 May 2025 16:50
Hello, everybody!
About 1.5 years ago I tried going the Remora route on my NVEM V2 with the STM32F207 and a Raspberry Pi 4. After a steep learning curve I finally managed to get the motors to turn, but experienced an issue where the motors would stutter, or skip steps, for some reason. Despite some kind peoples best effort to help, I was never successful in solving the issue and my PrintNC has been out of order since then.
I finally gathered some energy and wanted to give this another go, so I bought a mini-PC, a Lenovo M93p, mainly because I feel more comfortable using a real PC rather than a RasPi, and because it feels like there is more support for it.
Anyway, I followed all the same steps as the last time to get Remora up and running, but unfortunately the result is the same, the motors turn, but stutters.
1.5 years is a long time in the world of open source firmware development, so first of all I would like to ask if the Remora-NVEM repo is still the latest one for the NVEM V2? Or has the old NVEM V2 been integrated in another repo and has seen some updates since?
My next question would be, if it turns out that I simply can't get the NVEM to work properly, what is the board to buy nowadays? Is it the EC300?
Regards,
Christian
  • kello711
  • kello711's Avatar
10 May 2025 16:44 - 10 May 2025 17:40
7i96 with THCAD-2 setup on Everlast 82i was created by kello711
Hello all. I'm having some issues with getting my THCAD-2 setup with the Everlast 82i. I'm pretty sure I have all the settings correct. I opened the Everlast and set the jumper to the 16:1 divider ratio (as suggested). On the THCAD-2 I used the 10:1 (W1 Up setting) and left the card divider on 1. I used pnfconf to configure the THCAD and got the following settings:
Arc Voltage Offset = 100200.0
Arc Voltage Scale = 0.000199
In Qtplasmac I'm getting a -20 voltage reading instead of 0 V. I set the machine to run a small bit of G code and measured the voltage coming off pins 4,6 from the Everlast. This is consistently getting ~4.5V when running at 40A cut power. When I connected a 9V battery to the I+ and I- directly on the THCAD-2 the power in HALSHOW is jumping all over the place. However, when I connect the wires from the plasma back to the THCAD, I get no indication of any voltage when running a job.
Any help you can provide would be greatly appreciated.
  • zz912
  • zz912's Avatar
10 May 2025 16:32
Replied by zz912 on topic Leaving from TOOL page
Category: Gmoccapy
I would be interested in Norbert's opinion.
  • Onkelmat
  • Onkelmat's Avatar
10 May 2025 16:32
UPDATE
okay, I'm feeling ashamed and stupid.
so the servo drives have 5 potentiometers at their front for several adjustments. guess you already know where this is going...
offset 1 and 2
rpm
P as of PID
and current
i already tried to adjust the offsets with zero effect days ago.
turns out you have to turn the potis like 8 times to get an effect from 60% to 0% offset, you can go both directions so like 20 turns at max. in fact I wasn't adjusting hard enough to get an effect.
and to my defense i bought the machines with minor problems and didn't touch the drives before and x-axis was always spinning like crazy, right from the very first start it ran into hardware endstops.
so it was just a drive someone messed with, before I got it, to get the machine running again.
no more spinning on its own. thanks.
  • Aciera
  • Aciera's Avatar
10 May 2025 16:19
Replied by Aciera on topic Leaving from TOOL page
Category: Gmoccapy
I believe this is the intended behavior.
  • Aciera
  • Aciera's Avatar
10 May 2025 16:14 - 11 May 2025 19:17
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Here is the promised sim config:
File Name: mazak-inte...-dev.zip
File Size:111 KB
To test:
1. unzip
2. 'halcompile --install' the enclosed 'mazak_integrex_200y_kins.comp'
3. start 'mazak-integrex-200y' config and run the preloaded gcode program
If you have any questions, which is likely, just ask.
Text from the enclosed README file:
Experimental simulation of a 5axis Mill/Turn machine (eg MAZAK Integrex 200Y)
Implemented Gcodes:
- 'G67 B':          Moves the B-axis to the 'B'-word position and activates 'HALF TCP Lathe' mode.
- 'G68 B (X Y Z)':  Moves the B-axis to the 'B'-word position then defines and activates a work plane perpendicular the this current tool orientation with the origin at the current WCS (optionally offset by any [X,Y,Z]-Words). This will change WCS to 'G59' where the transformed work offset values have been written to (ie the prior values stored in G59 will be lost!).
- 'G68.1 (X Y Z)':  Defines and activates a work plane perpendicular the the current tool orientation with the origin at the current WCS (optionally offset by any [X,Y,Z]-Words). For change to WCS see 'G68'
- 'G69':            Cancels the work plane set by 'G68' and (currently) switches back to 'G54'.
NOTES:
- This config defines the work-spindle as '$0' and the tool-spindle as '$1'. Example: 'M19 $1 R90' will orient the tool-spindle to 90°. (For real hardware it is recommended to use the spindle encoder-position instead of using 'spindle.1.orient-angle'.)
- 'HALF/FULL TCP MILL/LATHE' modes include tracking of tool-spindle rotation.
- 'HALF TCP MILL/LATHE' modes do not track the work spindle rotation, this is intended behavior.
- 'FULL TCP MILL' mode will track all rotations.
- Tool-offsets must only be changed in 'Identity' mode as it may cause sudden joint movements otherwise.
- Lathe tools must only be used in 'Identity' or 'HALF TCP Lathe' mode.
- Mill tools must only be used in 'HALF/FULL TCP Mill' or 'TWP' mode.
- Due to easier abort handling we currently restrict the use of twp to G54 as LinuxCNC seems to revert to G54 as the default system.
  Abort behavior can be handled by using a subroutine defined in the ini file under [RS274NGC]ON_ABORT_COMMAND'.
- The TWP remap code in this config does not implement virtual rotations (ie no optional 'R' word).
  • zz912
  • zz912's Avatar
10 May 2025 15:44
Category: Gmoccapy
My English is bad. Could you explain your message easier?
  • zz912
  • zz912's Avatar
10 May 2025 15:41
Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
So try this:
        if "G43" in self.active_gcodes:
            self.command.wait_complete()
            self.command.mode(linuxcnc.MODE_MDI)
            self.command.mdi("G43")
            self.command.mode(linuxcnc.MODE_MANUAL)
        self.stat.poll()
        toolinfo = self.widgets.tooledit1.get_toolinfo(self.stat.tool_in_spindle)
        if toolinfo:
            self.widgets.lbl_tool_no.set_text(str(toolinfo[1]))
            self.widgets.lbl_tool_dia.set_text(toolinfo[12])
            self.halcomp["tool-diameter"] = float(locale.atof(toolinfo[12]))
            self.widgets.lbl_tool_name.set_text(toolinfo[16])
Displaying 15166 - 15180 out of 17473 results.
Time to create page: 0.484 seconds
