  • andypugh
  • andypugh's Avatar
06 May 2025 15:21
Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
If you edit the tool table, save the changes, re-load the tool table in the GUI and then issue a G43 in MDI then the tool diameter really should change.
Maybe it's the "reload tool table" step that is missing?
  • andypugh
  • andypugh's Avatar
06 May 2025 15:15
Replied by andypugh on topic Need help with Linux 2.5 on a CNC lathe
Is the Z limit switch also a home switch?
halshow (in Axis menu - Machine - Show Hal Configuration) will let you explore whether joint.2.*-lim-sw-in is not working properly.
  • vre
  • vre
06 May 2025 15:10
Replied by vre on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Category: Installing LinuxCNC
When i start this pendant must push continuous mode button for jogging with
wheel is not press continuous it changes feedrate override.
How can fix this ?
  • Groovecooper1
  • Groovecooper1's Avatar
06 May 2025 15:01
Replied by Groovecooper1 on topic Need help with Linux 2.5 on a CNC lathe
Been getting this error a lot, and again, the machine will not home.
  • grijalvap
  • grijalvap's Avatar
06 May 2025 14:22
Replied by grijalvap on topic Zero Pierce delay After pierce Only
Category: Plasmac
I was not awere of this working mode, it can be useful because you can use  sheetcam drawings or generate in QTplasmaC.
but still need change pierce delay in tool.
  • onceloved
  • onceloved's Avatar
  • Tntmold
  • Tntmold
06 May 2025 13:52 - 06 May 2025 13:55
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
I am unable to get the motors to move, they are open loop steppers.  This is my first use of linuxcnc so I don't know much, but I tried power on, then home and got the following:
phil@SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
note: MAXV max: 3.333 units/sec 200.000 units/min
note: LJOG max: 3.333 units/sec 200.000 units/min
note: LJOG default: 1.000 units/sec 60.000 units/min
note: jog_order='ZX'
note: jog_invert={'X'}
task: main loop took 0.059970 seconds
task: main loop took 0.075473 seconds
task: main loop took 0.050344 seconds
Can't run a program when not homed
task: main loop took 0.019042 seconds
task: main loop took 0.052011 seconds
joint 0 following error
emc/task/taskintf.cc 976: Error on joint 0, command number 110
task: main loop took 0.036446 seconds
task: main loop took 0.045782 seconds
task: main loop took 0.078341 seconds
task: main loop took 0.050362 seconds
Can't issue MDI command when not homed
task: main loop took 0.018336 seconds
task: 746110 cycles, min=0.000007, max=0.078341, avg=0.001059, 14 latency excursions (> 10x expected cycle time of 0.001000s)
Were can I get a definition of command number 110?
  • snowgoer540
  • snowgoer540's Avatar
06 May 2025 13:18
Replied by snowgoer540 on topic Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
I’ll try to take a peek after work today
  • Hakan
  • Hakan
06 May 2025 13:07
Ls L7nh CİA402 servo Drive ethercat op and preop problems
Category: EtherCAT
Hi, that looks like a lot of network problems to me. I don't actually know what the problem is, it's a guess.
First, check this one out
which uses a different dcconf statement and a watchdog statement. It's worthwhile to try.
If that doesn't work.
What computer and network card do you have? Can you post the output of the commands "uname -a" and  "lshw -C network"?
Have you tried changing to other network cables?
Tested with only one drive attached?
Tested with another ethernet card. Intel cards works the best for me. If you have a free pci-e slot it's easy to test with a Intel i226 card.
  • WelshQ
  • WelshQ
06 May 2025 12:39
My TOS MCV 1000 machining center Retrofit with Siemens 611
Category: Show Your Stuff
Hello , its been a while but did you succeed in running the simodrive ?
I have the same setup on an Eumach 1050 Heidenhein TNC 407
Nice to know it works for you before I embark on the same mission
  • andypugh
  • andypugh's Avatar
06 May 2025 12:36
EL2502 and EL2535 PWM Ethercat BECKHOFF Modules
Category: EtherCAT
What's the application of EtherCAT PWM output? ie, where would you use that rather than analogue output?
  • hermann1976
  • hermann1976's Avatar
06 May 2025 12:27
Replied by hermann1976 on topic Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
Basically, I agree with you. Specifying some basic settings at the start of the program makes sense and is done that way. However, it's confusing when the machine is always in different states during different phases, such as after the control system starts, during program execution, after a program abort, after a tool change, and so on. For me it's not clear why the tool length should disappear when a program is aborted? I can't see the reason or the rationale for this.
But I have a solution for this.
However, we're getting away from the actual question:
How can I ensure that the radius is updated in the tool info window when applying the tool table after editing? Are incorrect half pins connected here, or where are the functions triggered by the "Apply" button controlled? When milling with radius compensation, the value from the info field is used. G41/42 accesses this value.
When programming, I use radius compensation (finishing, fits, etc.) whenever possible and sensible. This allows for easy adjustment of the dimensions without having to change with the CAD program.
  • Aciera
  • Aciera's Avatar
06 May 2025 12:19
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I'm still working on it.
Having the tool pointing in the x direction instead of the z direction in the home position has turned out to be a bit more of a headache as Linuxcnc applies the tool offsets internally.
TCP with xyz tool offset and tool spindle orientation is done. The kinematic for Tilted work plane also works but the transformation of the work offset still needs some work.
Let me figure this out first and I'll post a new sim config so you can have a look at it. Then we can have a look at customizing the gcodes for your specific needs.
  • DarkPhoinix
  • DarkPhoinix
06 May 2025 12:10
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
first thing i went to google and searched for this:
Google help me
I didn't find anything to configure the steps, I attach my configuration. After the modification the stepper doesn't move anymore I also tried to give it this combination:
    "Thread": "DMA",
    "Type": "DMAstepgen",
        "Comment":            "Y - Joint 1 step generator",
        "Joint Number":        1,
        "Step Pin":         "P1_24",
        "Direction Pin":     "P1_31",
        "Step Length":        2,
        "Step Space":        3
I attached the txt file I sent to NVEM
  • Todd Zuercher
  • Todd Zuercher's Avatar
06 May 2025 11:53
Replied by Todd Zuercher on topic Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
I've always felt it was best to always explicitly set G43 Hn in the g-code program, but I came from a back round of programming primarily for Fanuc controlled machines before using Linuxcnc. Never assume the state of the machine. Inserting a handful of g-codes at the start (preamble) or every tool change is cheap insurance.
Are you using the diameter offsets (G41/G42)? If not, I'm not sure that the tool diameters are really used for much of anything unless G41 or G42 is active. If you are using the diameter offsets, generally you would be turning them on and off in your code for different situations and the new offset would be activated at the next G41/G42 call. Myself I almost never use them, and program from the tool center with the CAM program. About the only time I use them is for compensating for resharpened tools (which I rarely use.)
Displaying 15451 - 15465 out of 17468 results.
Time to create page: 0.396 seconds
