05 May 2025 03:41
Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
OK, check what tool it is outputing, several years back i had such an issue with it but on windoze, it would ONLY output tool 6 instead of 1, no matter what i did or change or how many times i reinstalled it...so i installed LinuxCNC. :)
  • hermann1976
  • hermann1976's Avatar
05 May 2025 02:51
Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
Hello everyone,
I have a problem where, after changing the diameter or Z offset in the tool table for an active and loaded tool, the values ​​aren't immediately applied. Even if I click the "Apply" button.
I have to explicitly unload the tool and reload it with M6.
Unfortunately, I can't figure out how the Apply button works.
Maybe someone here can help me. Thank you very much.
  • rodw
  • rodw's Avatar
05 May 2025 02:44
Lcnc & Ethercat data types, Ethercat automated hal pin setup.
Andy wants to replace 32 bit  pins with 64 bit pins in 2.10. Some people don't agree with this as it could result in unexpected consequenses (me included). for example I can see it breaking the Ethercat driver.
Re memory storage, its really defined by the CPU byte and register size so there is not any benefit in storing 8 bits. eg. the CPU will load 64 bits at a time into its registers so 8, 16, 32 or 64 bits will all probably take the same amount of storage on a 64 bit system.
  • RNJFAB
  • RNJFAB
05 May 2025 02:37
Category: Plasmac
thanks Tommy,
Using the same linuxcnc post in sheetcam that i have been using for ages.
  • rodw
  • rodw's Avatar
05 May 2025 02:27
Replied by rodw on topic Zero Pierce delay After pierce Only
Category: Plasmac
yes it works if you use 2 tools one with piercing delay and one with 0 delay.
I'm using the tool from sheetcam (tempoary tool created from file). so i need 2 files or edit the file after pierce and reload.
what I'm thinking is just press a button and make the Pircing delay 0,
In the Sheetcam processor, there are some variables at the top of the file to select between Sheetcam and qtplasmac tools. Sorry about that but had to humor Les at Sheetcam seeing its distributed with his software (and he wrote the post.)!
There is also a script that lets you import a Sheetcam  toolset into qtplasmac
05 May 2025 01:55
Replied by tommylight on topic Zero Pierce delay After pierce Only
Category: Plasmac
Temporary materials were meant to be temporary, QtPlasmaC and PlasmaC before were not built with a temporary materials workflow in mind.
Nothing more permanent than a temporary solution! Quote from someone on the internet...he/she was bloody right! :)
I absolutely and strictly use the materials in PlasmaC/QtPlasmaC, using anything else is asking for trouble.
I have modified the Inkscape gcodetools to output the required plasmac-feed-rate in gcode, and that was it.
05 May 2025 01:48
Replied by tommylight on topic rotary vs motion : velocity
The thing is, a round 20mm tube is roughly 63mm in perimeter (or in this case the distance the machine must move) while a 100 round tube is 314.15mm in perimeter, so if you have the same rotation speed, the 100mm will travel much faster under the spindle.
The easy way to avoid any of this is to have multiple normal configurations for each diameter, and use Y as rotary but in hal it remains linear. Not using A.
I have several rotary plasma machine in use with this type of configuration, so normal 2D CAM (Inkscape with gcoodetools), and just run the configuration for the diameter being cut.
05 May 2025 01:36
Replied by tommylight on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Ah using Linux to entirely tune the feedback loop?
Yes, the position loop is in LinuxCNC.
Velocity loop is usually on the drives when motors also use tacho generators.
Am I right in thinking that if you run analog signal and rely on linuxcnc to close the loop, all tuning happens within Linux, as per your link?
No auto tuning through the drives etc?
Yes, again only the position loop is handled in LinuxCNC, velocity and torque loops are handled usually in the drives, although LinuxCNC can also handle all of the above on it's own.
The tutorial is for using older existing drives, whenever possible i try to use them as they are very good quality and rarely fail, and most of the tuning is already done in the drive as they were in use and working perfectly fine.
  • snowgoer540
  • snowgoer540's Avatar
05 May 2025 01:29 - 05 May 2025 01:31
Replied by snowgoer540 on topic Zero Pierce delay After pierce Only
Category: Plasmac
You could just stop using temporary materials and let the materials in QtPlasmaC be your master.
Then you only have to perfect settings in one place. Furthermore for your situation you’d go to another tab, change the delay,  do your pieces go back to the tab change the delay again and run the program. No editing gcode files necessary.
05 May 2025 01:28
Category: Plasmac
Might not be the issue, but you should really avoid using Mach3 post processors for LinuxCNC, if you use any for plasma, it will shows each consecutive cut on screen lower and lower. Try something with 200 cuts! :)
If you must, use the plainest post processor, mill should do probably, again with no gcode for tool changes n'stuff.
  • djdelorie
  • djdelorie
05 May 2025 01:21
rotary vs motion : velocity was created by djdelorie
I have a cnc router with a laser and a rotary axis.  I modulate the laser output (using the laserpower HAL) according to motion's requested vs current velocity, so the laser power is reduced during starts and stops.  Works fine for XY work.  For XA work, I'm running into the "which F" problem.  I'm using inverse time mode for the gcode but... how do I get inverse speed for the laser modulation?  motion.current-vel follows the F rule - it's inch/min if there's linear moves, else it's degrees/min.  If you do a coordinated move, you lose the angular velocity info.
In my case, I know the Z value will be "accurate" as far as "how far from the rotary axis are you" *in this case*.
Is there a way to do this in HAL?  Preferably without writing my own laserpower module ;-)
Or is there a better way to modulate laser power with a rotary axis?
Or should I just assume "it will work out" because the acceleration for X and A is synchronized, so reading either velocity fraction would suffice?
  • RNJFAB
  • RNJFAB
05 May 2025 00:44
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
SO.......
wifi adaptor died on the mac I'm using for the cnc.
Easy, new Mac.
load linuxCNC 2.9.4.
forget to save a backup of old config (dumb ass !!!)
Spend last night making a whole new config for the machine.
Save a backup on usb this time and place in a safe place.
Having a few glitches, hopefully sorted soon.
  • RNJFAB
  • RNJFAB
05 May 2025 00:35 - 05 May 2025 00:37
Category: Plasmac
Just downloaded and installed 2.9.4.
Having a few issues with the loaded job.
It cuts once then deciding it wants to show the job 2500mm low on the Y axis. Although it will still cut where it is supposed to.
Also throwing error codes if i change any of the .tap file through the edit option.
Is there a new one I need to install?
  • PCW
  • PCW's Avatar
05 May 2025 00:08
soft limit error after x homing, does not home y
Looks like your min and max limits on X and Y (and joints 0,1) are reversed.
  • Micro2000
  • Micro2000
04 May 2025 23:42
Replied by Micro2000 on topic soft limit error after x homing, does not home y
File Name: Micromill.zip
File Size:419 KB
Displaying 15571 - 15585 out of 17471 results.
Time to create page: 0.317 seconds
