30 Apr 2025 16:21
Replied by tommylight on topic Can I home X and Y axes simultaneously?
From the "machine" menu, choose "homing" then the axis you want to home.
  • DarkPhoinix
  • DarkPhoinix
30 Apr 2025 15:45 - 30 Apr 2025 15:46
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Yes i have, but not a default config, it is for NV something or another.
Do you get the dropped connection?
Do you get joint errors?
No the connection is stable( joint error only 3 video Youtube+stresstest+rustdesk remote desktop) but i have bad stepper movement.
Try to put:
[JOINT_1]
DIRSETUP   = 150000
DIRHOLD    = 150000
STEPLEN    = 150000
STEPSPACE  = 150000
 and
[STEPGEN]
#150000
DIRSETUP   = 150000
DIRHOLD    = 150000
STEPLEN    = 150000
STEPSPACE  = 150000
and
[STEPGEN]
#150000
STEPGEN_DIRSETUP   = 150000
STEPGEN_DIRHOLD    = 150000
STEPGEN_STEPLEN    = 150000
STEPGEN_STEPSPACE  = 150000
and
[STEPGEN]
#150000
STEPGEN_1_DIRSETUP   = 150000
STEPGEN_1_DIRHOLD    = 150000
STEPGEN_1_STEPLEN    = 150000
STEPGEN_1_STEPSPACE  = 150000
my driver is a  TB6560 (only for testing not final hardware)
all conf not change the movement
the work is linuxcnc classic engrave test
  • RotarySMP
  • RotarySMP's Avatar
30 Apr 2025 15:41
Replied by RotarySMP on topic Lathe project
Lathe project
Category: Turning
Nice clean up.
  • liutas4x4
  • liutas4x4
30 Apr 2025 15:38
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
Problem 1: gelöst
Wie hast du das Problem gelöst?
Ich habe den gleichen Fehler.
Eugenius.
30 Apr 2025 15:20
Yes, set the same home sequence for both in the ini file.
  • Aciera
  • Aciera's Avatar
30 Apr 2025 15:18
  • IB_CnC
  • IB_CnC
30 Apr 2025 14:51 - 30 Apr 2025 15:20
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
I think it has to do with the 10 bucks stepgen PCB, it also happened before I removed the physical pushbuttons and soldered wires to it.
It's not a big issue, but would be nice if it responds faster.
I have to double check the stepper driver dip switch settings.
If no luck i think it might be possible to put a relay on the EN+/- wire, between the PCB and the stepper driver and just leave the PCB ON constantly, only changing direction by switching the DIR and activating the stepper driver via the Enabled signal.
That could solve it, will test later on. It would send out pulse signal constantly, but can't think of a reason why that would be an issue.
  • PCW
  • PCW's Avatar
30 Apr 2025 14:49
AC Servo tuning - Joint 0 following error at high velocities
Category: Basic Configuration
With the above setup is it possible to achieve 15,000 mm/min feedrate within 20 micron positional accuracy and +- 20 micron repeatability? I doubt whether the control loop is fast enough to reach this speed and accuracy ?
The main control loop in this case is in the drive, its velocity feedback loop.
The position control loop in LinuxCNC can run more slowly and maintain
high accuracy and repeatability. Note that at 15000 mm/m you move only 250
microns per ms, so it takes only relatively crude velocity commands to keep
within 20 microns. Note that as you increase acceleration, tuning becomes more
difficult as you run into various physical limits.
  • grijalvap
  • grijalvap's Avatar
30 Apr 2025 14:49 - 30 Apr 2025 14:55
Zero Pierce delay After pierce Only was created by grijalvap
Category: Plasmac
Hi, yesterday I used the Pierce only funtion in  1 inch plate, it worked very well, I saw the inconvenient of having to edit the file to change pierce delay to 0.0 after pierce only.
I wonder if we can have a control to override the pierce delay vaule and make it zero, maybe the same button that changes from Normal Cut to Pierce Only can has the funtions Normal Cut - Pierce Only - After Pierce.
  • cmorley
  • cmorley
30 Apr 2025 14:16
Category: QtPyVCP
Any idea why such a long delay between pressing a button and the actual move?
30 Apr 2025 14:14
Replied by tommylight on topic [SOLVED]linuxcnc Latency test ambiguous results
30 Apr 2025 14:11
In your ini file, you have limited max_output to 8, should usually be 10.
Here is a detailed tuning guide:
Do read it fully first so you know what parts to pay more attention, no skipping steps.
And do let me know if something there can be explained better.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
30 Apr 2025 14:10 - 30 Apr 2025 14:15
Is there a bug in the carousel component or am I doing it wrong ATC Denford
Hello, I'm starting to restore a lathe from scrap.
My problem is ATC (we'll get to the original ATC when I start the model)
Test model:
Step PIN8 dir PIN9 LPT stepper motor
Microstep 1600
4 pockets
1 gome sensor (pocket 1)
Head lock by left rotation (example video from the web)
Component linuxcnc.org/docs/html/man/man9/carousel.9.html
Basic lathe configuration
Symptoms:
T1M6 after starting linuxcnc looks for HOME and rewinds (strangely but it does rewind)
Each successive tool, e.g. T3M6, no longer rewinds
When I start from T2 M6 it passes HOME (activating it) but no longer rewinds while in position
My observations:
Dir changes but there is no movement. which means that there are no pulses flowing to PIN 8.
M66 waits for READY signal even though nothing is happening. Only after time has elapsed does the DIR state change and then it is READY
all files below
As you know I am not strong in HAL and in English please write as if to a child
O<changetool> sub
(debug, Tool change to T#<_selected_tool>)
M68 E0 Q#<_selected_tool>  ; Wybierz kieszeń
M64 P0                     ; Włącz karuzelę
G4 P2
; Czekaj max 15s na ready (z timeoutem)
M66 P0 L3 Q15
; Jeśli timeout, zatrzymaj karuzelę i zgłoś błąd
O100 if [#5399 EQ 0] (if timeout)
  M65 P0
  (msg, Toolchange FAILED - Timeout)
  M99
O100 endif
M65 P0                     ; Wyłącz karuzelę
(debug, Tool change OK)
O<changetool> endsub
M2
[code][code]loadrt stepgen step_type=0,0,0
loadrt carousel pockets=4 encoding=counts dir=1 num_sense=1
addf carousel.0 servo-thread
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxvel 100
setp stepgen.2.maxaccel 150
setp stepgen.2.position-scale 1
net astep stepgen.2.step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
#net adir stepgen.2.dir => parport.0.pin-09-out
net adir carousel.0.motor-rev => parport.0.pin-09-out
#Konfiguracja carousel
setp carousel.0.scale 400
setp carousel.0.width 10
setp carousel.0.fwd-dc 10
setp carousel.0.rev-dc 100
setp carousel.0.rev-pulse 10
#Połączenie carousel z stepgen
net carousel-pos-cmd carousel.0.counts-target => stepgen.2.position-cmd
net carousel-counts carousel.0.counts <= stepgen.2.counts
net carousel-ready carousel.0.ready => iocontrol.0.tool-changed motion.digital-in-00
#net carousel-dir stepgen.2.dir <= carousel.0.motor-rev
net carousel-enable carousel.0.enable <= motion.digital-out-00
net carousel-enable stepgen.2.enable <= motion.digital-out-00
net carousel-pocket carousel.0.pocket-number <= iocontrol.0.tool-prep-number
net home-signal carousel.0.sense-0 <= parport.0.pin-10-in
#Toolchange
all files below
[/code][/code]
  • Spyderbreath
  • Spyderbreath's Avatar
30 Apr 2025 13:22
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I seem to of been wrong about converting the ST-link to DAP. I just went back and watched the video again and there were originally 2 steps in doing the conversion, but there is the post below that video - forum.linuxcnc.org/18-computer/44828-rem...rd?start=2050#321860 - that says to just use that one file?
I am now very confused and the computer says the converted ST link is an unrecognized device and it does not show up. I can not communicate with the link plugged into the USB
At this point I truly do not know what to do.
Displaying 15946 - 15960 out of 17460 results.
Time to create page: 0.424 seconds
