  • Soccer Kid
  • Soccer Kid's Avatar
15 Apr 2025 06:30
  • timo
  • timo
15 Apr 2025 06:10
Replied by timo on topic ENCODER_RATIO function implementation.
I am hobbing without any special UI for a while now. I change invert.0.in pin manually. There are some other parameters that I would have to change manually, when using "additional" rotation for Pfauter method. But I barely touched this, mainly because of mechanical setup issues.
I really would (should) give it another try, but my patience was not high enough. I am interested in improving the situation on my machine.
@boogie, please keep us update how it is going. :-), maybe I can finally get there.
As I understand it the UI that Andy made runs as "sub window" in the Axis UI and provides the special inputs and some features.
Greetings Timo
  • rodw
  • rodw's Avatar
15 Apr 2025 05:19
Replied by rodw on topic Problem with THC
Problem with THC
Category: Plasmac
I just discovered that my formula and the one in the QTPlasmaC documentation ids not correct for the THAD2. Those formulas work for the previous release of THAD.
PncConf has the correct formula by the looks of it. Does any have the correct formula for me?
Have you looked at the THCAD2 manual? the formula is in it,
  • rodw
  • rodw's Avatar
15 Apr 2025 05:14
Replied by rodw on topic How to pass parameters .comp file
Category: HAL
This example in the docs is similar to what you want
linuxcnc.org/docs/stable/html/hal/comp.html#_out8
  • theslawek
  • theslawek
15 Apr 2025 05:01 - 15 Apr 2025 05:02
Need help making rotary axis behave like second spindle
Ah, I see. I'm not sure I want to dive into something cutting edge. Caxis.comp just sounds intimidating because I haven't read up enough about it yet.
The INI and HAL I attached is a traditional XYZA setup. A is controlled with degree command sequence like below for turning decorative spindles for example.
G00 Z3.3000
G00 A0.0000 Y0.0000 S20000
M3 S20000 (regular 10HP spindle)
G4 P1.5
G01 A359.9011 Y0.0001 Z2.1250 F200.0
For applications when I need the ACTUAL spindle and rotary to spin non-stop (like a spindle) (as in my YouTube video), I envision loading a XYZ+A_Spindle type config where I can issue this instead.
G00 Z3.3000
M3 S100 $1 (additional rotary axis now turning like spindle)
G4 P1.5
G01 Y0.0001 Z2.1250 F200.0
  • cmorley
  • cmorley
  • Soccer Kid
15 Apr 2025 03:34
Replied by Soccer Kid on topic Axis 2 - touchscreen version of old friend
Category: AXIS
Your work is excellent and simplifies the understanding of not understanding Linux. Thank you very much!
  • theysayzmajtome
  • theysayzmajtome
15 Apr 2025 03:09
Replied by theysayzmajtome on topic Retrofit plasma and Hyperterm max 100 HF/HV problems??
Category: Plasma & Laser
My idea for ohmic probing.
See attached pictures
Kind regards
  • notJamesLee
  • notJamesLee
15 Apr 2025 02:47
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
okay maybe i am missing something.
I turned the switch to C, cranked up the voltage (my desktop power supply goes only up to 31 for some reason) and there is no change in the amount it spins for 'one' revolution. Still about 1.125 and pulling .25a.
The control method dip switch (6) is set to open control mode.
one thing that dawned on me, and maybe this speaks to me not quite understanding what is meant by pulse/rev, is that if the driver is set to default, all switches 1-4 set to on, there is not difference between the behavior when its set to 1600.. Even though the steps the arudino is sending are the same. this confused me even more.
  • pgf
  • pgf
15 Apr 2025 02:03
Converting a working mill configuration to an equivalent sim
I don't want to start disconnecting hardware for this. It's really just to see, while I'm sitting in my living room, whether the g-code is "mill ready".
In the end, I just took a copy of /usr/share/doc/linuxcnc/examples/sample-configs/sim/axis/axis.ini , and I'm using that. I have a pretty basic mill. I had to adjust the limits in the .ini file, and I realized that since I'm simularing I could bump the velocities way up, and it's been useful, so far.
What kinds of things are you worrying about, that will "wreak havoc"?
  • Soccer Kid
  • Soccer Kid
15 Apr 2025 01:44
Replied by Soccer Kid on topic Program linuxcnc?
Program linuxcnc?
very good idea!
  • spumco
  • spumco
15 Apr 2025 01:38 - 15 Apr 2025 01:58
tormach 1500mx modifications, 4th axis, fast I/O expansion, auxilary spindle.
Category: PathPilot
Thanks, I was hoping that would be the case. Do you have any brands/models you would recommend?
Quite a few ethercat servo drives have onboard IO available.  Some of the IO are identified in the manuals as limit switches or similar, but there's no reasion you couldn't use the IO for some other purpose.  It'd just get mapped to LCNC as general purpose IO and could be read or set via M-codes.
And some drive have pluggable terminal blocks instead of the fiddly D-sub connectors for the IO pins.  No need to chop up a cable to connect to the field IO.
I don't have a brand recommendation, but it wouldn't hurt to download a few user manuals or spec sheets and see if there are IO speeds provided.
Just an example... the Leadshine EL7 series could be had for around $400-500 and has easily wirable IO.  You could pick one up and cook up a test rig with some sensors and relays and see if it'll work fast enough for your needs.
EDIT
This is, in fact, what I think Tormach is doing on the 1500MX.  From a video I watched, it looks like they are using Inovance SV660N drives, and have bought/fabb'ed a breakout board for the drives' extra IO. Instead of sourcing an ethercat IO module (like PCW mentioned) for user-installed IO, they're using thier existing USB IO module.
Each SV660N has digital 5 inputs and 3 outputs, so looks like they've got 25/15 available.
Pic of the 1500MX panel below.  Note that all the drives have a D-sub ribbon cable to the center IO breakout board.
  • JohnnyCNC
  • JohnnyCNC's Avatar
15 Apr 2025 01:14
Replied by JohnnyCNC on topic spindle with encoder
Category: Basic Configuration
My top spindle speed is 5400 RPM and that plate is .032" aluminum. If it does cause vibrations, they are too small for me to notice.
  • rickjmain
  • rickjmain
14 Apr 2025 23:53
Replied by rickjmain on topic Mesa 7i96s firmware for Index (2.9 release)
That worked perfectly, thanks!
Displaying 16831 - 16845 out of 17471 results.
Time to create page: 0.391 seconds
