  • meister
  • meister
11 Aug 2024 20:58
Happy Sunday, everyone!
Got my MPG functional in RIO. Everything works; encoder counts, selection knobs, led, fairly happy about that. Not entirely sure what else I need on that motion control board, probably nothing.
cool, did you change anything in the hal for this, or did everything work via config ?
if you had to do something to the hal please let me know, then I'll see how I can integrate it
I wasn't completely idle today either :)
very experimental and only of limited use,
but this example works:
            "type": "wled",
            "pins": {
                "data": {
                    "pin": "WLED:DATA"
            "signals": {
                "0_green": {
                    "net": "(halui.machine.is-on and !halui.mode.is-auto and !axisui.error) or halui.program.is-paused",
You'll have to find out for yourself what's so special about it,
I only say HAL of hell :P
  • AndyDM01
  • AndyDM01
11 Aug 2024 20:17 - 11 Aug 2024 20:18
Ethercat installation from repositories - how to step by step
Category: EtherCAT
carpal-tunnel syndrome maybe ?
anyway in my language we don't write it that way
  • AndyDM01
  • AndyDM01
11 Aug 2024 20:15
Category: EtherCAT
so far so good, got the first signs that the software is working ok on the first machine I have to retrofit, thank you to everyone for contributing... I think i really used something from everyone and I will ofcourse due time post my own track to the walhala of linuxcnc when i get to the point of managable cnc machine under total control (for all 3 machines !) ... if i don't die from carpal-syndrome , haven't typed this much since i left the plc/automation world
  • AndyDM01
  • AndyDM01
11 Aug 2024 20:02
I have serious questions about some stuff I didn't find an answer for
Category: EtherCAT
A: I would really apreciate it  if someone could explain me how the ethercat / cia402 gets recognized by linuxcnx ... because of what is inside of the linuxcnc-ethercat?
B: I finally got the green light to retrofit 3 of our trade-in plasma machines (everyone with budget is switching to laser!) and one off the machines runs on mach3 ... inside the mach3 there was some extra M15 & M16 created to make the torch go up and down with the D6(?) postprocessor
X axis was normal nema34stepper, Y axis was normal nema34 stepper driver BUT the Z axis was a pneumatic cilinder on/off function , hence the M15 and M16 needed for the Z axis to drop to start cutting... how do I i create this M15 and M16 in linuxcnc-ethercat ?
btw... the more I get into Linuxcnc... the more disappointed I feel that I didn't get a change 5-10 years ago.
THX to everyone for the time you put into this forum... it has been a lifesaver
  • fsabbatini
  • fsabbatini
11 Aug 2024 19:44
Replied by fsabbatini on topic Cylindrical mapping
Cylindrical mapping
Category: Show Your Stuff
I took a picture of the first kinematics on the file, Y axis is interpolation of X an X’
When second kind is active (Y axis is mapped to C and physical Y is not moved)
  • fsabbatini
  • fsabbatini
11 Aug 2024 19:40
Cylindrical mapping
Hi Spumco!
So yes, at the end of the video link I shared you can see how it looks like, but basically you write the code as if you write it in a plane where the Y axis is mapped to the C axis to a particular diameter (specified with R parameter when calling G7.1)
Example
G0 z0 y0
Y100
Z100
Z0
Y0
That would map the Y axis on the C axis, easy thing (tomorrow I need to machine some parts and I will post the gcode and the finished part)
PD: attached a picture of the new panel working (still missing the label strips)
  • ustaL
  • ustaL
11 Aug 2024 19:33
Replied by ustaL on topic Mesa Configuration Tool
Category: Configuration Tools
Hello,
I assume I'm in the right place, but sorry if not.
I saw a lot of videos like 7i92 and easy-peasy setups and decided to use PC+Mesa instead of smth like SZGH-CNC990(1000)TDb-*.
I have a lathe with the servo (HLTNC HL-T3D driver + motor brake) in Spindle + 2 step motors (for now, but same servos in the future in each axis) + step for ACT for another spindle (milling) + at least 2 optical rulers + encoder for spindle (optional, because I'm going receive position from driver for now and rely on this info, but then going to switch to dedicated spindle encoder).
So I bought 7i95T. And install LinuxCNC and... Pncconf wizard doesn't work with new boards because of PIN naming (as I understand) and this is only the beginning. That's why I need (correct me, if I'm wrong) MesaCT. Am I in the right direction? Or do I have to fix somehow Pncconf (the main problem is that XML connector name is NOT "P1", but "STEP/DIR+ENCODER+I/O" and python to int convert issue)?
  • Mecanix
  • Mecanix
11 Aug 2024 19:25 - 11 Aug 2024 19:54
Additionally. If you are designing a Motion Control Board and want to ensure 110% isolation between the domains, the "go-to" part is the ISO7760DBQR (imho). Tested that all of today. Will endure a lightning, two typhoons, and a russian EMP bomb (granted all that are tiny!!). Others; the part's INs/OUTs are HIGH impedance and so no need to pollute the entire board with pullup resistors. 5V-to-3V3 translation at 25Mhz == PASS. Solid square wave with little to no under/overshoot.
The ISO7760 part was specifically engineered for system automation and motor controls, therefore you can officially ditch those half-useless ancient and medieval 'optocouplers' ;)
e.g.
  • Mecanix
  • Mecanix
11 Aug 2024 19:23 - 11 Aug 2024 19:35
Got my MPG functional in RIO. Everything works; encoder counts, selection knobs, led, fairly happy about that. Not entirely sure what else I need on that motion control board, probably nothing. And so time to finalize the routing and send out a prototype PCB to test with!! Not that the breadboard set-up doesn't work, it's just a hazardous messland all over my benchtop // flying wires much lol \\
  • SilverRain
  • SilverRain
11 Aug 2024 19:08 - 11 Aug 2024 19:10
NativeCam on LinuxCNC 2.9.3 was created by SilverRain
Category: NativeCAM
Удалось ли кому-нибудь установить NativeCam на LinuxCNC 2.9.3? Две недели бьюсь с проблемой Python 2.7, а теперь ругается на GTK... Сил нет.
  • papagno-source
  • papagno-source
11 Aug 2024 18:03
Replied by papagno-source on topic refclockSyncCycle question
Category: EtherCAT
I left the refClock value at -1 , but it gets worse.
The vibration problem is present at every restart of LNXCNC.
So I reset it to 1. It would probably be better to set it to 2 ?
  • ContinenteCNC
  • ContinenteCNC's Avatar
11 Aug 2024 17:58 - 13 Aug 2024 15:29
Hydraulic Pipe Bender Retrofit - BLM C88 was created by ContinenteCNC
This is a retrofit from a little while ago. It is a massive Italian pipe bender from the '80s.
In principle, it is a simple machine in terms of kinematics, but the size is intimidating. It had dozens of powerful hydraulic actuators and sensors, most of which would destroy themselves if actuated in the wrong sequence.
Two axes were driven by servo motors. We had to keep the old analog servo drivers, which was a requirement. They have resolvers and translators to encoder-like signals in each driver.
The 'bender' axis is hydraulic and uses a proportional valve for control. It is massive, and it’s hard to describe the sheer force this machine has—quite scary.
The kinematics were implemented in G-code, and the final result consists of several O-codes and routines working with custom HAL components to make everything function. In the end, it was about a second slower than the original one.
I had the opportunity to work with a great company that handled everything else. I just had to do the CNC work. It was a three-week job, working an average of 10-12 hours a day. It was worth it. The machine is working flawlessly.
This piece below is one of the most complicated ones in terms of logic. To avoid collisions, the machine has to release the pipe, bend it, hold it once again, and then push it to the last bend. The operator only has to input the dimensions, and the code is able to figure out on its own if there will be a collision and choose a way to avoid it.
This is the typical speed the machine runs
  • RLA
  • RLA
11 Aug 2024 17:50
Hardware needed to switch from mach 3 6 axis to linuxcnc 9 axis
Thanks...I am really looking forward to using this...board should arrive this week...have one issue in the meantime...same pc I had xp on for running mach3...installes linuxcnc with debian 12 from website...something makes it restart and I have to re login..hp compaq with 4.96 mb ram 1.8 ghz...250 plus gb disc space...I do not think it happened when I ran as live boot a few times before installing to disc...
Thanks again!!
  • Moutomation
  • Moutomation
11 Aug 2024 17:37
Replied by Moutomation on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
The code written by Aciera works, but I'm having problems with permissions right now. I created a common folder between Windows and Linux. I can't give permission to this folder on the lşnux side, even though I used the chmod 777 command.
Displaying 24076 - 24090 out of 24494 results.
Time to create page: 1.047 seconds
