  • PCW
  • PCW's Avatar
10 Aug 2024 23:17
Trouble getting PWM to work with 7i92TF and BoB but steppers working fine
Category: PnCConf Wizard
You would need to use 7i92t_5abobx2d.bin firmware to match that BOB
  • avive
  • avive
10 Aug 2024 23:13 - 22 Aug 2024 20:41
Replied by avive on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I'll get these motors and drivers any day now. I'm gradually figuring out the configuration. And I have a question, why specify these empty blocks? Will it work without them?
EDIT: Yes, they are needed.
  • Lcvette
  • Lcvette's Avatar
10 Aug 2024 22:56
Replied by Lcvette on topic Trajectory Planner using Ruckig Lib
@Grotius
the model/gcode is in inches for that last video..lol  maybe try it in inch to see the correct moves?  :D :D :D
i couldn't tell if the machine was moving..lol
  • fsabbatini
  • fsabbatini
10 Aug 2024 22:48
Replied by fsabbatini on topic Cylindrical mapping
Cylindrical mapping
Category: Show Your Stuff
Exactly, i did implement it, i dont know why the video is not embbeded. This is my second attempt
youtube.com/shorts/X_OvO9vH9e8?si=9NnEw1TGMq_6w-eU
Attached the kinematics file, you will find two kinematics ,it works out with kinematics switch.
Basically is a custom lathe i built that is has X, X', Z axis with motorized tool where X and X' works together to form a Y axis, this would be kinematics 0.
Kinematics 1 is this cilindical mapping, where it must work in combination of:
  -First reference de spindle
  -C axis is always present but not used until kinematics 1 is activated (but spindle encoder is always linked to joint.xx.motor-pos-feedback pins in hal
  -Remapped Gcode G7.1:
      G7.1 Rxxxx for activating the transformation on specified diameter
      G7.1 without R to deactivating the transformation
Any questions are welcome
  • ContinenteCNC
  • ContinenteCNC's Avatar
10 Aug 2024 22:25 - 11 Aug 2024 00:45
3W LED CNC Soldering Machine was created by ContinenteCNC
This is my high power (3W) LED soldering machine. It holds the LED in place, displaces solder and heat the connection with a regular soldering iron.
It uses mostly ngcgui to handle the logic. It has some basic features like resoldering failed joints and a couple more.
It also displaces thermal greese with a interchangeble module. This video also shows how led's are placed in bulk.
It's unfortunate I can't open the source for this project because I did it for a company. But, anyway, it is quite simple to replicate. Nothing fancy. I hope it helps someone.
  • itsbrian
  • itsbrian
10 Aug 2024 21:33
Hi everyone, I've managed so far after all these years to get all the info I need on these boards by being a lurker, so thank you everyone for all the knowledge on here. I'm at a crossroads with this one though as I'm still quite new with the mesa boards.
I have the following BoB below and can confirm I can get the PWM working using software stepping by setting it on Pin 1 in the Stepconf wizard.
When setting this up using the Mesa board (7i92TF), I followed the guide below which works perfectly fine for running my steppers.
forum.linuxcnc.org/49-basic-configuratio...rallel-port-bob-g540
What needs to be changed on my setup to get this working? Mind you the config on my mesa board is whatever came straight out of the box.
My intention is to use this PWM signal to control a laser since I mainly control my spindle manually (or RS485). I'm currently testing this potential laser setup right now with an LED. If this helps, one thing I also noticed differently between software stepping and the mesa board, is that during PC boot the LED is already lit versus when it is connected to parallel port it is not.
I've attached my INI and HAL file for the mesa config. Any help would be appreciated, thanks!
  • PCW
  • PCW's Avatar
10 Aug 2024 21:07
Replied by PCW on topic 7i97t with 7i84d connection problem
Category: Driver Boards
There are many things that need to be setup to match
your hardware so no generic hal/ini file set will work
on an unknown machine without editing. Things needed:
Setting up inputs  for limit/home
Setting up the encoder scaling and direction
Making sure that the position feedback is negative
rather than positive (positive feedback=runaway)
Tuning the PID loop
Setting up spindle controls
Setting up generic outputs (coolant etc)
etc etc
Why the 7I84D does not work with your pncconf created
is unknown but there are some simple diagnostics
The precise error messages will help here also.
On easy way to capture these is to run LinuxCNC
from the command line. When this is done, the errors
will be printed in the terminal so can be copy pasted
to the forum.
  • Krulli_Fräser
  • Krulli_Fräser
10 Aug 2024 20:46
Replied by Krulli_Fräser on topic 7i97t with 7i84d connection problem
so loading Lcnc with these files should at least work but my inputs and outputs are not connected to software pins correctly?
Editing the hal files is something that can be looked up and is documented well by many people so once I get to that stage I will probably get everything to run given enough time.
My initial problem of not seeing the 7i84d pins needs more info from the machine after posting "mesaflash --addr 10.10.10.10 --device=ETHER --sserial" to the terminal?
  • natester
  • natester
10 Aug 2024 20:36 - 10 Aug 2024 20:39
The LinuxCNC "Rigid Router" an open-source dual z-axis gantry machine
Category: CNC Machines
Hi all, I recently designed an open-source CNC router. My goal was to make a rigid, medium-format CNC router that can self-manufacture new machines and not require any specialized equipment for squaring the build.
All the design files, LinuxCNC configuration files, and build info are on my blog:  blog.nathantsoi.com/article/rigid-router-cnc
The design is based on 4590 aluminum extrusion and CNC machined parts that self-index on the frame, so no extra alignment tools are necessary:
I used closed-loop servo motors, but steppers should also work fine.
Here is the back of the X-Axis:
I also decided to use an old computer with an onboard parallel port, to save on cost. I built all the electronics into an old mac pro case, which looks pretty rad.
I also added a cheap PCIe parallel port and used it as an input-mode device for an MPG jog pendant that I also designed:
Finally, I added a button panel with physical buttons matching the GMocappy soft buttons and some potentiometers to control feed rates, which is really handy when I need to quickly change the feed rate or stop the running program.
I hope this is useful for folks who are interested in building their own machine from scratch.
  • PCW
  • PCW's Avatar
10 Aug 2024 20:19
Note that  7I97T and 7I97 hal files are interchangeable
with the exception that the 7I97T analog out resolution
is best with the PWM frequency set to 75 KHz and dither
enabled.
The zipped example files comprise a complete configuration
but of course there are many machine specific setup things
that need to be added/changed to match your specific machine.
  • Krulli_Fräser
  • Krulli_Fräser
10 Aug 2024 20:09
I can download the file now, great.
I am completely new to LCNC and have never done a conversion so everything is a mystery to me. I haven't found an example of a retrofit with a 7i97t as it is a relatively new card.
I'm quite certain that I've omitted some crucial steps in setting my mesacards and the pc up. Perhaps I was a little too optimistic about the kind of configuration work i need to do.
Could you roughly break down everything I need to do from opening the box of mesa cards to having a completed hal file?
  • PCW
  • PCW's Avatar
10 Aug 2024 19:57
The zip file contains a basic 7I97 configuration file set (hal and ini files)
File Name: basic7i97_...8-10.zip
File Size:4 KB
The 7I97T PWMgens need to be set in offset mode
(as shown in the example hal file)
  • rodw
  • rodw's Avatar
10 Aug 2024 19:55
Replied by rodw on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
It seems like you guys need to build a folder watcher,
The operating system has methods to do something if the contents of a folder changes.
Python has an interface to this. There are a number of examples on the web. Here is one to get you going
thepythoncorner.com/posts/2019-01-13-how...-filesystem-changes/
  • rodw
  • rodw's Avatar
10 Aug 2024 19:47
Ethercat installation from repositories - how to step by step
Category: EtherCAT
The script just adds the Ethercat repositories/
Just folllw the steps in post 1 to install Ethercat.
  • Krulli_Fräser
  • Krulli_Fräser
10 Aug 2024 19:40
Thanks for the reply, unfortunately it raises more questions than it answers. I won't get back to the machine before the morning but i will first try the command you suggested and post the result.
I can't seem to download your file, and even if I could I don't know what to do with it.
On which of hte cards do I need to set the pwmgen to offset mode and how would I do that?
Displaying 24121 - 24135 out of 24494 results.
Time to create page: 0.580 seconds
